Question about AEG Washing Machines
AEG Lavamat 62800 wash machine motor not working
I have an AEG Lavamat 62800 wash machine that was working perfectly till I overloaded it and it seems the motor will not run. Have drained and unloaded and tried another light load. Fills with water but then goes no further. Where the drum would normally turn a few times, there is no movement, just a soft click click roughly one second apart. Drum not jammed, belt in place, motor spins freely. Drain pump also clean and spins freely. There are no codes displayed. Do I need to reset or something?
5 Suggested Answers
  • 64 Answers
SOURCE: Drum not turning (WFL 2260)
possibly the belt is off/broken? can you hear the motor turning when the drum is supposed to be revolving? If not supect the motor carbon brushes, or some other fault with the motor/and /or circiut, at best it may be a burned out wire to the motor
Posted on Oct 21, 2007
  • 17130 Answers
SOURCE: AEG Lavamat 64810. No error
The fault has been described well by you and it is confirmed that the motor is not running. Now eventhough you have mentioned a clean chit to the control panel I would like you to take a voltage check on the motor when it is in wash cycle.
If the power comes on and there is no motor action then it is confirmed that the motor is fauly. But if there is no output of the voltage to the motor from the controller, the it is possible that the controller is faulty.
If motor is humming and is of single phase type, check the capacitor and replace if motor is humming and not running.
.I am sure you can sort this out having come this far.
Hope my tip helps
Posted on Aug 28, 2010
  • 2510 Answers
SOURCE: my front loader fills with water, pumps and drains
Remove the back panel of the machine and operate it to check that the drive belts are being engaged to drive the drum. Observe the operation from a safe distance when you have the back off as there are live terminals within reach and you could be severely shocked if you come into contact with any one of them. Unplug the machine again before checking anything withing the workings.
Posted on May 21, 2011
  • 48 Answers
SOURCE: Need help
Are you saying it is draining the water properly? Because it sounds as though the pump is faulty. Every now and then you get pup motor that don't short out or stop completely they just don't drain we'll anymore. The drain period on your machine is timed so a slow drain may cause the error. So even though everything is clear and 'working' the pump needs replacing. Another cause would be a false reading from the pressure switch(level switch) but you would normally have problems with fill etc also, so unlikely.
Posted on Jul 09, 2013
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 62800 keeps stopping and displaying error E50. What is the problem and how do I fix it?
Aug 07, 2011 | Washing Machines
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
What means error code "C9" ? AEG Lavamat 76669
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
Mar 30, 2008 | AEG Lavamat W1450 Front Load Washer
I have washing machine AEG 62800 model.
When I tried to start a washing the error E60 was displayed on screen.
The following actions were done:
1. Turning knob to right to first position "COTTON LINES 95"
2. Pressing on all 5 functions except START button (Rinse Hold, Rinse+, Time Saver, Pre Wash, Stain).
Red lights will flash .
3. Pressing on Start button and simultaneously starting to turn clockwise till OFF position.
It will reset error and will release machine.
I'm hoping it will help.
Feb 25, 2008 | Washing Machines
Washing Machines Logo
56 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
