How to reset password for distribution switch (3com)
sandeep239
  • 59 Answers
SOURCE: Wants to reset 3824 3com switch via console
You forget the password for the "admin" user account and can no longer perform important management operations. solution.gif Use the password recovery method outlined below to define a new password for the "admin" user account:
  1. Access the Command Line Interface from the console port and enter the user name "recover" and password "recover" to place the Switch in password recovery mode. The Switch remains in password recovery mode for a maximum of 30 seconds, before it returns to the CLI login prompt.
    note.gif You must use the console port to recover the passsword. If you attempt the recovery method using the network, the password will be rejected.
  2. Perform a hard reset on the Switch whilst it is in password recovery mode by switching it off, waiting a few seconds, and switching it on again.
    note.gif You cannot use a soft reset operation to reset the password of the "admin" user account. This will end the password recovery procedure and return you to the CLI login prompt.
  3. When the Switch has rebooted following the hard reset enter a new password for the "admin" user account.
Posted on Mar 05, 2009
botaksetan
  • 80 Answers
SOURCE: How do i Reset or break in to get reset my
The resetting of the password requires the installation of a console cable to the console port.
Be sure the terminal emulator program is set to VT-100 management using compatible, 38400 baud rate, no parity, 8 data bits and Console connection one stop bit.
Use the included cable, or be sure that the pin-out complies with a standard null-modem cable
Once the cable is connected, reboot the switch. Type a Ctrl/C until you enter the failsafe mode. This will be denoted with the prompt: “CFE>”
At the prompt execute the following commands:
CFE> passwrd
CFE> reset -sysreset
At this point the password has been reset.
Posted on Jan 20, 2010
  • 121 Answers
SOURCE: i forgot my admin password
If it's the Power Plus (3C16475BS) model, there should be a reset button inside a small hole on the back. "10 - Recovery Button" Inserting a paperclip or similar to reset. If it's not the Power Plus model and is in fact (3C16475A), this is an unmanaged switch, with no administrative capabilities. You don't need a password.
http://www.3com.com/products/en_US/detail.jsp?tab=features&pathtype=purchase&sku=3C16475BS
Posted on Feb 25, 2011
  • 9 Answers
SOURCE: 3com superstack 3 switch 3300 reset himself randomaly need a solution
take it to the 4s garage, if you want to find out the problem by yourself,you first have some professional tool , there are some diagnostic that always can figure out the problem i can show you: www.xcardiag.com/
Posted on Apr 12, 2012
  • 17 Answers
SOURCE: i have 3Com Baseline Switch
First,"There is usually a small button on routers that can be accessed with the tip of a pen or a paperclip. When you find that tiny button, hold your pen or paperclip down on it for approximately 10 seconds until the router resets itself to factory defaults."
After that, you can contact the manufacturer to get some helps if you still have problem.
BTW,
I work for Ingellen Communication Equipment and we are a large fiber optic equipments manufacturer in Shenzhen.Kindly let me know your specific requirements so that i can help
Posted on Apr 17, 2012
Decrypt 3com password
Use a brute force password solver or at best do a reset
Dec 05, 2016 | 3Com Computers & Internet
HP V1910
I believe this website has the answer you need: (I know it says 3com but HP purchased 3com a few years back) http://www.edugeek.net/forums/wired-networks/97909-anyone-know-how-factory-reset-3com-2824-sfp-hp-v1910-24g.html
Apr 07, 2014 | HP V1910-16g Gigabit Ethernet Switch
I forgot ip address and password and want to factory reset
Connect the console cable, open a connection to the serial port via a utility such as PuTTY, and do the following:
1) Enter the user name "recover" and password "recover" to place your unit in password recovery mode. The unit will remain in password recovery mode for 30 seconds max.
2) Perform a hard reset by removing power, waiting 10 seconds, and then re-applying power.
3) Once the switch has rebooted, enter a new password for the "admin" user account.
4) Enter enable to leave password recovery enabled, or enter disable to turn it off. You are now logged in as the default "admin" user.
Note: If password recovery has been disabled, the only way to recover access is to return the switch to 3com.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
I forgot my admin password on my 3com baseline switch 2226-sfp. i can't remember. Can you please help mo to reset my baseline switch to reset the password only. Thanks jenry
Feb 25, 2011 | 3Com 3C16475A Baseline Switch 2226...
Default password is incorrect or reset doesn't work
The default ip is 192.168.1.1
default user-name and password for the 5 models of 3com are as follows.:
1.
3com default ip: 192.168.1.1
username: n/a
password: admin
or
2.
user-name: adminttd
password: adminttd
or
3com default ip 192.168.1.1
user-name: admin
password: n/a
or
user-name: n/a
password: PASSWORD
OR
5
user-name: root
password: !root
ok try
this
Note that at time you will need to set your local ip of your pc from which you are acess the device to the same range...
That is for example 192.168.1.10
Good luck
uttam
Feb 26, 2010 | 3Com 2816-SFP Plus (3c16485-us) 16x1000...
How do i Reset or break in to get reset my password on 3Com 2948 Baseline Switch 48Port SFP Plus
CFE> passwrd
Jan 20, 2010 | 3Com Baseline Switch 2948-SFP Plus 48-Port...
I do not have the password for 10 3CNJ220s I have inherited. Would like to know if there is a way to either "crack" the units or reset them to the original configuration.
the defautl password was "password" on these devices, 3Com no longer sells them but their support site has the software and manuals free to download. Downlaod the Utility software and restore the facotry defaults and simply start over. Good Luck.
http://www.3com.com/products/en_US/detail.jsp?tab=support&sku=3CNJ220-BLK&pathtype=purchase
Jul 15, 2009 | 3Com NJ220 Networking Switch
Mar 05, 2009 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
