My computer monitor is jittery once in awhile what can be the cauce of that happening and how can i make it stop
  • 102 Answers
Just check your earthing and line neutral sequence in power connection.
also check the sarroundings for electromagnetic distortion.
Posted on Jul 25, 2009
Screen rolls and is jittery
If you have room to install extra memeory, do so and see what happens. If you still have the same problem, it could be that your video card is defective.
Dec 17, 2013 | HP Pavilion dv9820US PC Notebook
1995 toyota 4 runner starting problem once in awhile
Is the starter turning over the engine when it wont start or is nothing happening at all?
I might have your solution if I have more details.
If the engine is turning over but not starting then switch on the ignition and push it to start.If it starts you probably need a new ignition switch.
Please get back to me .Thanks
Aug 04, 2009 | 1998 Toyota Corolla
My problem with this screen is that when I try to go to another web site the whole screen starts flickering and I can't go to another web site. Happens once in awhile, sometimes it works great and then all...
Could be a loose cable inside off the monitor. There is a cable that hooks into the back of the lcd and if that is even loose by a little bit it can make the screen act crazy. If you can get the back cover off of the monitor, try to unseat and reseat that cable to see if the problem goes away.
If you do that and it still exists then the lcd is bad and the whole monitor needs to be replaced.
May 02, 2009 | Acer V193w LCD Monitor
Dell LCD monitor quickly goes sleep, on, off over and over
I would recommend that you try it on another computer to see if you are able to reproduce the results. If that is the case you should look at any new drivers, software or updates that have been installed. If the issue continues with another PC, it sounds as though the monitor's power supply is possibly failing. in that case I would suggest you simply replace the whole monitor. Unless you are not shy with a soldering iron. ;) good luck!
Nov 19, 2008 | Dell E197FP LCD Monitor
Help
Signal lost usually means the cable is lose that connects the monitor to the back of your computer.
with the computer off and unplugged , disconnect the monitor cable from the video port on the back of the computer and physically inspect the pins to make sure they are not bent on the monitor end.
some monitors have the same plug on both ends , so it doesn't hurt to check the monitor side of the cable.
Once the cable has been checked, if the cover is off the computer, i would check all cables and add-in card to make sure they are fully in thier slots and ports.
check memory for the same issues.
If your monitor is a multi-function device , make sure you didnt forget to hit the source button on it , could be on the wrong input.
Oct 23, 2008 | E-Machines eMachines Desktop PC
My screen turn a blue color
What is the problem with your monitor , its shaky or jittery or out of focus ?
Apr 05, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
MONITOR MEDION MD7317 NOT WORKING
i have some 19 inch medion monitors that have the same problem .. they make a lot of noise and the screen might be jittery/fuzzy ... i found the following:
several capacitors in the power supply (inside the monitor) had their tops buldging .. that shows that internal pressure was high in the caps, usually caused by them being hot and thats caused by high internal leakage .. the caps may eventually blow out the tops (explosion vents) .. the caps are designed to do that instead of becoming a bomb ..
all the bad electrolytic capacitors i have seen so far on these monitors, motherboards and other electronics have been chinese made .. they made millions of bad caps over several years ..
almost all the bad caps had buldged tops but not always .. once in a while i see one thats open but not bulbged .. probably venting elsware ..
i changed the obviously bad caps and the monitors returned to like new performance ..
i dont know about the 17 inch but the 19 inch medion flat pro display is not too hard to take apart .. about 30 screws or so ... speakers have to be unscrewed and you have to be careful not to stress cables that go to the push buttons .. of course you have to know how to solder without bridging paths
Feb 02, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
Computers & Internet Logo
284 people viewed this question
David Payne
David Payne
