Question about Fujitsu Heating & Cooling
Fujitsu General cassette ac timer light is blinking continuously, ac not working
SOURCE: Fujitsu Heat Pump - problems
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Posted on Aug 08, 2008
  • 288 Answers
SOURCE: HI, I have a Fujitsu ASTA18lCC. Fan working but
trying to get the compressor to operate. it could be a bad capacitor and the compressore wont start or maybe the compressor is burned up
Posted on Dec 15, 2009
Testimonial: "Thanks for the advice. It turned out that we had a blackout after the AC had started playing up. The blackout seems to have sorted out the problem.Thx"
  • 186 Answers
SOURCE: my both red light is blinking continuously what i do help me
both light are blinking at the same time or blinking alternatively ?
if both blinking same time, it's a fatal error.. means it could be something wrong with the carriage or board or encoder belt...
if the light blink alternatively, it means the waste ink counter need to be reset and ink pad need to be replaced.
Posted on May 26, 2010
hvac1960
  • 2133 Answers
SOURCE: My Fujitsu air condition had
The unit is under time setting. You have to cancel the timer by dis connecting the power and restart.
Posted on Dec 08, 2010
hvac1960
  • 2133 Answers
SOURCE: I have a fujitsu AOTR30LCT,
Error c0de-3.Return air thermistor short circuit.
This sensor when it's defective, will not command for compressor for working.
Replace it.(Room air sensor). Helpful?
Posted on Jan 24, 2011
Testimonial: "Thanks that worked called the fujitsu people and they replaced the faulty sensor"
Fujitsu Cassette A/C model AR-SY1. There is a blinking/flashing red light next to a timer like icon. Pressing Filter reset button on remote control does not help.
Those blinks are fault indications. From the number of blinks occur at one time switch on, you can get details about the faulty circuit stage inside the set. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Feb 20, 2017 | Fujitsu Televison & Video
Fujitsu asta24 Lcc timer light flashing all the time even when off no cool air coming thru
A continuous blinking timer light is a "model error" meaning the indoor and outdoor unit is mismatched. If the timer light flashes a number of times, pauses, then repeats, count the number of flashes and then you can work out the error code.
Nov 17, 2016 | Fujitsu Heating & Cooling
O general split ac indoor timer light 5 time blinking .what problem
There's a redlight turned on in the inverter of my O General 1.5 ton AC. What might probably be the problem? Please guide.
Jun 02, 2015 | General Heating & Cooling
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
How to turn off the timer on the Fujitsu AC Model AR-RAC3E?
Hi Rismita,
I hope the following link is helpful for you
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Jan 18, 2015 | Fujitsu Heating & Cooling
WHEN I START A.C. ITS OPERATION AND TIMER LIGHTS STARTS BLINKING AND N OT COOLING
Sounds like a pressure switch may have it shut down. It could be the main circuit board but not likely. Its in the control circuit and will need to be troubleshot
Sep 26, 2012 | General Electric Heating & Cooling
Unit will not operate
http://www.fujitsu-general.com/global/products/index.html
Find your manual and check the code of the blinking green light. It will give you the resolution for your code. If you still have issues, post a comment back on this thread and I will be able to help you. You will need your model number for the website.
Mar 21, 2009 | Fujitsu Heating & Cooling
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
99 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
