TVs keeps showing channel 21 nothing less - Televison & Video
I have an lg tv model 37LC2DB - EC I lost all my channels and can not auto programme so I did a factory reset now it says not programmed how do I get my digital TVs channels back
lg tv factory reset, not programmed? ' Yahoo Answers
Sep 21, 2011 - I performed a factory reset for my lg tv like I was told to do by the ... to get set for digital and now it keeps flashing not programmed anyone know ...
In my lg smart tv showing not programmed how to program ...
My lg smart tv keeps saying its not programed it wont switch on .... And after all is done, then run Error Checking/Chkdsk using the instructions in the link below. How To Run ..... We got a new lg smart tv was up and running now says not programmedwhat to do .... I have tired Auto tuning and Factory resetting. but no luck.
LG TV Signal Diagnostics, factory reset and manual tune ...
? 25:30
Sep 29, 2011 - Uploaded by 1976stuart1976
LG TV Signal Diagnostics, factory reset and manual tune - Post Digital .... one the net ran for a bit and now its telling me im notconnected and I ...
Jan 20, 2016 | LG Televison & Video
I have two TVs, a Toshiba in my living room and a Sylvania in the bedroom, both of which are connected to Time Warner cable. They are both older version televisions, not flat screens or plasma. The Sy
You haven't specified here about the channel capacity or both of your Televisions. Is both of it can receive 100 channels. If not, the tuner to both will have the difference. There are sets with which can receive only 50 channels, 90 channels, 120 channels etc: Older versions of TVs will have only low channel capacity. Present ones are of channel receiving capacity up-to 320.
If the channel receiving capacity to your TV is low [as it is older models]; there is nothing more to do. Electro help
Nov 16, 2014 | Toshiba Televison & Video
Dish remote 2 changes channels on both tvs and dish remote 1 changes channels on both tvs
Is the receiver in dual mode? Go to the receiver, open the door, and hit the mode key. If both TVs are still showing the same thing, then the issue is not the mode.
Go to TV 2 (the one without the receiver) and make sure the TV is tuned to channel 60 or 73. If it is still showing the same thing, go to TV1 (the one with the receiver) and hit Menu, system setup, Installation, modulation (menu 6-1-5). make sure the modulation for tv2 matches which channel you put your tv2 on.
Still showing the same thing? check the back of the receiver, the RCA cables (red/white/yellow) are plugged into the TV1 ports not the TV2 ports.
Showing different things but the remote still changes channels on both tvs? Go to TV1, hit menu twice, near the bottom there are two boxes each with a number. This is the address for each remote (tv1 and tv2). On the TV2 remote hold sat until it stays lit, choose a number different than on the screen, touch pound (#), the sat light blinks three times, hit record, the number on the screen should change to match the one you typed in.
Still being silly? Call a priest, you have a poltergeist!
Oct 24, 2013 | DISH Network IR Remote Control
I have bpl tv model FYR 21 NEPTUNE and there is a problem in its colours uniformity. due to les green colours of pictures reflects the purple colour. please tell me the solution for setting its colours
my tvs volume has been increasing suddenly on serving the channels mostly above 20th channel recently the picture disappeared it shows red line in the middle but volume is present quickly give me the solution
Sep 29, 2010 | Televison & Video
Does the norcent lt 2722 model have an hd tuner built in?
Yes,all LCD tvs have tuner build in.To recieve DTV free air channels without a converter box.Full HD tvs can get show in mode 1080i,here are some channels play show in 1080i mode are CBS,NBC,CW.
Feb 05, 2010 | Norcent Technologies LT-2722 27 in. LCD...
Sound goes out on random cable channels..only on this tv
It might not be your TV it might be you Cable Provider. Get them to look at your cables in your home
Aug 25, 2009 | Sanyo DP19648 19 in. LCD TV
We have an older tv with an indoor vhf/uhf antenna. We have hooked up the converter box according to directions and even watched a video showing how to hook it up. However, with the tc on channel 3 and...
Sounds like a connection problem, if coaxial connection was made and box is turned on, then something should show up on channel 3. If rca composite connection was made something should show up on video 1 or 2. Make sure box's power button is pushed to 'ON'.
Mar 24, 2009 | Insignia Digital-to-Analog Converter for...
HDTV converter box only brings in 3 channels
We have a pretty good signal when we use the antenna but when we hook up the converter box we get no channel weak signal no channels we have a amplipher on it it does not help .
Nov 22, 2008 | Insignia Digital-to-Analog Converter for...
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
