Question about Pool & Spa
Best filter to remove chlorine and total chlorine from public water system
  • 297 Answers
SOURCE: i have a 18ft x 52 intex pool with salt water chlorinator.green
although you may or may not have enough chlorine in your pool you must also realize that a pool need turned over at least 3 times a day.
an example is if you have 7000gl of water and a 2000gph pump you need to filter at least 10 hours or so.
More important than chlorine is the actual circulation of the water you can have all the chlorine in the world but if you do not have the circulation the water will become cloudy or green this also happens when you have no swimmers for days at a time
the filtration time is over and above the chlorine generating time your 4 hours a night for generating chlorine sound like you are guessing sometimes it may be 4 and sometimes 2 or 6
it depends on # of swimmers a day sun and what was in the pool to start
It is important to have a test kit for ph and chlorine and keep chlorine at 1.0to 1.5 now set your ph
ph will rise and fall with your chlorine level one you have them set good at the first time then ph should stay safe enough and re level as chlorine is kept right
also remeber that the wrong ph causes more problems than wrong chlorine levels
Also make sure your salt is no more than 3000ppm and no higher like some people recommend and no lower than 2500 test kits are available for 10 dollars
all of this can be found on intex.com either in a video or pdf files for water capacity and approximate time for generating chlorine.
to be sure always use test kits
Posted on Jul 12, 2009
  • 297 Answers
SOURCE: no chlorine being produced
although you are close to the amount of salt that is recommended all pools are just different enough that the salt table is just a starting point if you do not have enough salt it is still possible to not trigger the alarm but not produce enough chlorine.
Start by getting a salt test strip kit and get your pool to 3000ppm this may take a day or so since you really need to filter and circulate the pool for 24 hours in between adding salt
Once you get the salt right then move on to generating
also do not worry about total chlorine you just need to concentrate on free chlorine this is the amount available in the pool to do it's job and dont forget to ad a stabilizer to help hold the chlorine level on hot sunny days
Posted on Jun 15, 2010
  • 297 Answers
SOURCE: My saltwater system produces chlorine but disappears fast
first of all your problem is a few things combined.
First lets learn what consumes chlorine
Heat,sun,rain,sun tan oil 3 of swimmers
you may need to run your generator 12 hours some nights it all depends on what kind of day it was and what the chlorine was to start with
Also if you do not have your salt as close to 3000ppm as you can then you are also not generating enough chlorine even if you are not triggering an alarm for low salt
you can not be below 2800 and no higher than 3800ppm
a test kit is available get the strips that reads #'s not the color strips for salt reading
Also you should be using a chlorine stabilizer to help hold the chlorine level this is only a help situation. it will not completly remidy your chlorine level going low if all the elements I mentioned are happening at the same time
Also be carefull not using the pool that is the worst thing you can do. You may go green quick without people in it stiring it up
I also recommend you use a non foaming algaecide every 5-7 days just follow directions for your gallons of water
By the way bromine tests are really not for pools they are designed to work with the hot water and chlorine level of a hot tub
your ph is fine, about in the middle alkalinity is what drives your ph so worry about the ph level and chlorine and you are good to go
Posted on Jul 09, 2010
  • 8404 Answers
SOURCE: I've been reading the blogs and have ascertained
You have about 8588 gallons of water in your pool ... One inch of water contains about 159 gallons in your pool. You should consider a 6 hour turn over rate. I recommend a high rate sand filter with at a minimum 1.5 sq feet of filter area. You need to move about 24 gallons a minute to achieve the 6 hour turn over rate.
Continue your research with these figures at hand.
Thanks for your interest in FixYa.com. If you found this information helpful, please vote ...
Posted on Aug 02, 2010
Testimonial: "Thank you for the information - very helpful"
john224
  • 1378 Answers
SOURCE: I run the filter pump then turn on the salt water
pH will always rise over time when using a salt generator. You'll need to periodically add acid to counteract this affect. As far as low chlorine levels try running the system longer...An average pools circulation system is setup to turn over the pool water once in about 8 hours. Running your system longer should lead to a higher chlorine residual and overall cleaner water.
John
Posted on Apr 26, 2011
I have a sand filter and my levels say ideal but water is real cloudy after adding chlorine
Take a sample to a pool shop and find out. If the pool has been green you may have dead algae floating around, a sand filter will never take that out. You need to flock it or new water. Then there is the toy you call a sand filter, OK when everything is perfect but small filters and pumps just won't handle a very dirty pool.
Jul 08, 2014 | Intex Automatic Salt Water System for ...
Tip
Well Cleaning and Water Well Quality
You have had a water quality test and found that you private well is contaminated with bacteria. The next question is what can you do for water well treatment to make the water well quality acceptable for you and you family.
This question and tip was brought to my mind after getting an email from a brother in law about how to treat his water well with chlorine to kill bacteria is his well. So here is the process that you can use to treat your well if you know or suspect that you may have bacteria in your well water. This can also be used for regular well cleaning also. The chlorine will release the dirt in your well and the water will bring it up when you run the water. Regular treatment with chlorine is very effective at keeping a well free of debris and algae.
Go to your grocery store and purchase gallon of regular strength unscented Clorox bleach. The generic bleaches will work just fine also as long as they are unscented. This will cost only a couple of bucks. Also, if you have a water filter, make sure that you grab a couple of extra filters. The dirt released will plug the filter quickly. A carbon filter is a good idea for removing the last bit of chlorine smell from the water after purging the well of the chlorine.
Take the well cap off of the top of your well. Use a six foot or so long piece of PVC pipe to pour the chlorine through. This will keep the chlorine from getting on the pitless adapter and ruining the brass parts. They do not like each other.
After dumping in the chlorine, run your water at every tap in the house both hot and cold till you get the smell of the chlorine. It is best if you do this when you will not be using your water for at least 10 -12 hours, like at bedtime. Then let it set as long as possible to give the chlorine time to disinfect the piping and water.
After this time, then run the water till you remove the chlorine from the well and the piping. For some wells this will not take long and for others it may take a very long time.
This process has now given you a clean well and a disinfected water system!
This also is a very good way to make sure that you have good clean water, after a water well pump replacement.
http://www.fixya.com/support/r3689163-water_problems_pump_problems
http://www.fixya.com/support/r3690698-pump_problems_water_tank
http://www.fixya.com/support/r3690937-pump_problems_pressure_switch
http://www.fixya.com/support/r3695577-jet_pump_jet_water_pump
on Apr 07, 2010 | Plumbing
In a 52" x 22' Ultraside Intex pool with a saltwater ionizer and a sand pump can I use pool shock to kill algae without damageing the saltwater ionizer system and the sand pump?
There seem to be different versions of algae killer - look for one that specifies that it's safe with saltwater systems (sorry, not familiar specifically with Pool Shock)
Aug 01, 2013 | Intex Automatic Salt Water System for ...
Can i put salt instead of sand in my pump
No you cannot. Sand is used in a sand filter to filter the water to remove dirt. Salt is dissolved in the pool water and a salt water chlorinator produces chlorine using the salt.
Aug 27, 2012 | Intex Pool & Spa
What are the methods for water purification?
Purification methods can be divided up into settling of suspended matter, physical or chemical treatment of colloids and biological treatment.
Aug 23, 2012 | Brita Camping, Backpacking & Hiking
I cannot get the water hardness correct. This is the test results for\r\n8/15/2011-- Total chlorine - 0 --- Free chlorine - 0.5 --- Total akalinity -120 --- PH - 7.8 --- Total hardness - 100 --.The Salt...
Your local pool store will test your water and advise you on what you should do. They will know local conditions and will be able to ask the proper questions on run time, pool size and equiptment.
Aug 15, 2011 | Intex Automatic Salt Water System for ...
Problem is test strips indicate high copper ion (pink) and total alkalinity is low (light tan) Free chlorine is ok (between 0.5 and 1) and ph is good. We have this greenish silt like stuff on the bottom...
1st.. Clean the green (algae) stuff out..
2nd. Clean the filter...
3rd.. Repeat step 1 and 2 until most all the algae is removed..
4rd.. Brush you pool with a pool brush to remove the remaning algae...
5th.. Seems like you have the right chlorine level but not running your filter long enough??? After all steps are completed, run you filter at 8 hrs and your chlorinator between 3 to 6 hrs until your pool clears up.. After that, vacuum again and clean your filter... During the summer months, 4hrs is not enough circulation.. Hope this works for you and good luck.. Please take the time to write a comment if this works for you...Thanks..
Aug 07, 2011 | Intex Automatic Salt Water System for ...
No chlorine being produced
Jun 05, 2010 | Intex Automatic Salt Water System for ...
Cant figure out where to put chlorine/chemicals
add chlorine to the water in the pool you might try a pool supply store for information reguardind ph of your pool and how to mix chemicals
Jun 21, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Cleaning the water system
A possible solution is depending on your water source... Chlorine will kill the algae, mold & mildew but the filter blocks chlorine. What we tell people is if you have chlorinated water, remove the filter (a bypass device may be needed depending on the make/model) and run without the filter for a week or so. The chlorine will kill all that stuff and then you can run the filter again. If you don't have chlorinated water you would have to mix a solution of bleach/water in a tank of some type and then use a pump (usually a Sur-Flo RV type pump) to supply the pressure and run a few gallons of chlorinated water through the system (again without filter) then let it sit 24 hours to kill the gunk. After that hook up to normal water supply and flush the system until there is no chlorine smell. The ratios for bleach/water, etc. are available on the internet if you "Google" the process.
Feb 02, 2007 | Amana SXD524VW Side by Side Refrigerator
Pool & Spa Logo
29 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
