My tv regulary lose screen whilst switch on....eventually restores ...but occurs frequently ???
    New Friend:
  • 78 Answers
You didn't say what type tv, LCD,LED< Plasma, projector, all have power supplies that supply the screens, sounds like you have a component failing . Most all tv's are throw away when they go bad. Friend bought big LED when they came out, two trips by factory repairmen couldn't fix it.
Posted on Apr 30, 2017
Vertical pastel colours error
Did u try to use different monitor and the via /Dvi cable it normally caused by this 2 if you still have the problem than its your graphics card it needs to check for loose connection.
Feb 17, 2014 | Acer (9005210464), (64 MB) Graphic Card
My iconia keeps minimising all windows and then restoreing intermittently
Yes! this is a hardware issue, make a DVD copy of your recovery, this way you will not lose windows and drivers, erase the hard drive and attempt recovery with disc, if same problem occurs replace hardware.
Mar 09, 2012 | Computers & Internet
Arcam avr 300 keeps switching off intermitently, and the red standby light flashes.
I wonder if anyone can help explain what the likely problem will be with my Arcam AV300 amp. Whilst watching TV for no particular reason an extremely loud (what i can only describe as feedback) sound comes out of my B & W speakers for approximately 3 seconds, then silence as the Arcam switches off, I’m then unable to switch it back on for a period of time, (this varies between 5minutes to a few hours) when it eventually switches back on everything seems to be working perfectly. This has happened quite a number of times although it’s intermittent & occurring every 1 - 6 weeks.
Sep 18, 2009 | Audio Players & Recorders
Toshiba LCD TV screen went white and stopped receiving pictures
If it is under warranty begin the process by calling Toshiba warranty department at 1-800-457-7777. Demand that they send you a prepaid label as shipping a TV is expensive.
May 03, 2017 | Televison & Video
My tv-screen is black. Seems there is no connection from the console. Brand new PS3. I might have used the main power switch when system was not at stand by. Is there a way to reset the system to...
I had this same problem but was finally able to fix it (immediately after I posted about it) by keeping my finger on the button until after the second beep.  I had tried this a couple of times before but it turns out I was keeping my finger on there too long.  Try lifting your finger right after the second beep.  You'll need to have a controller connected via a cable, as well.
We had to choose RESTORE PS3 SYSTEM from the options menu. If you choose this you will lose all saved  settings and data.  My husband is going through the new setup process now.  We tried a couple of the other less drastic options from the menu at first, but they didn't work.  After we chose the Restore PS3 System, it took a minute or two for anything to show up on the screen, but it was our last try before taking it in to a pro, so we tried to be patient let it do it's thing and it eventually came up on the screen.
We only got the system a couple of weeks ago and are very casual game players so it didn't bother us to lose saved data, but it is a pain in the **** redoing the setup.  I just hope this isn't a re-occurring problem.
Hope this helps, good luck.
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Jun 16, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Av channel change
Hi, please check if there is enough air flow where tv's ventilation is placed.. Try to keep a pedestal fan close to the tv's air flow holes and check if it happening again.. i think this will mostly solves your problem. If you go with this to your service centre they will simply replace the Tuner,and will give you heavy bill. all the best sreejith
Jul 16, 2007 | Sony KP-41T65 41" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
