Question about Whirlpool Washing Machines
7144 whirlpool stylemaster part - Whirlpool Washing Machines
Whirlpool stylemaster 4213964 washer will not drain because door sensor broke. Can this piece be repaired/replaced easily?
This is probably mid range difficulty. I could not find specifics on your model (most Whirlpool stylemaster washer model numbers .. at least in the USA ..start with "LA") is a link that will give you an idea of what is involved for a top loading machine. The challenge is getting access to under the top deck of the washer to access the switch. There is usually a combination of unbolting/unscrewing/prying to get access
How to Replace the Lid Switch Lock Assembly on Top Load Washer Repair...
Good luck on your troubleshooting
Feb 17, 2018 | Whirlpool Washing Machines
Why won't my Whirlpool Washer Stylemaster #907675 fully drain?
The pump may be failing. That's where the leak is coming from.
Jul 28, 2014 | Whirlpool Washing Machines
Whirlpool stylemaster 4214289 REV A Leaks water only when using warm and hot selections.
Oct 20, 2013 | Washing Machines
We have a stylemaster #907675 Heavy duty. It will not spin anymore, can you help diagnose?
It is a computer problem and you can get it fixed free, due to a recall by Whirlpool. Call the company and complain. My daughter had the same problem.
Jul 16, 2011 | Whirlpool Washing Machines
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
Jan 08, 2010 | Washing Machines
Whirlpool washing machine agitator problem
Simply buy the "doggies" and install it them
Sep 22, 2009 | Whirlpool Washing Machines
Washing Machines Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal De
