Can you replace pump of Richo Aficio MPC2500 with that of Richo Aficio 830DN ?
Am having a constant problem with my Richo MPC2500 pump, so am thinking of using Richo 830DN pump instead
  • 19 Answers
SOURCE: sc code
Go to sp mode press Clear Modes 107 and press Clear Stop for four seconds. Screen will change enter to SP Modes. enter 2109-1 and execute. then enter 2109-2 and execute. That should do it.
Posted on Jan 03, 2009
SOURCE: SC 441 Alert, Richo Aficio CL 3500N
I have run into this several times with these printers. In every case, it has been the CMY PCU. These run about $300.
I have read that by cleaning the PCU, you can get it to work sometimes. So far, I have not been lucky enough for it to work.
Posted on Apr 14, 2009
  • 990 Answers
SOURCE: USED TONER CASE IS NEARLY FULL
Hello sir; There have no waste tone bottle for this machine, but waste toner all stuck in the imaging transfer belt unit, on the right hand side door,pull it out dump the toner out and vaccumn it.
Posted on May 06, 2009
benwabnick
  • 2404 Answers
SOURCE: Where is the black photo condutor on Richo Aficio CL200N located?
I found the manual for your laser printer courtesy of Ricoh:
http://www.ricoh-usa.com/downloads/manuals/printers/cl2000.pdf
Page 5 of the PDF manual talks about the black photo conductor and where its located at.
Posted on May 28, 2009
SOURCE: RICHO AFICIO 650 SHOW ERROR 890
The code 890 do not exist like 880 but, if it is 980? the problem can be in the hard disc...
Incorrect parameter sent to the HDD controller.
First try reset the software… press the point and numeral key simultaneously until automatically it is off the copier, several seconds can pass, the copier back on automatically. The software will have been loaded again.
If the problem persists it proves with another hard disk,
since the other possible solutions already are more complicated; these are:
· Software defective
· SBICU defective
Another problem that sometimes cause erratic errors in these copiers is that it has fallen develop in some sensor having caused short circuits that annul to some times some voltage of the power supply interrupting processes indispensable for software. Example “by developer in the ID sensor” the copier scanned but nothing more. Developer in the sensors of the feeding units produced a code 322 can seem incredible but it is thus.
For it would recommend a deep cleaning of the sectors of the image unit and everything what is under the development unit.
Posted on Sep 02, 2009
My copier machine Richo Aficio 3045 do not supply toner
could be devlp powder is bad. replace and initialize devlp powder. could also do output check and turn toner motor on to make sure it works.
Apr 19, 2014 | Ricoh Aficio 3045, 3035 Kit
After replacing the main motor of my richo afico 2018 the copy result reduces is the cause of mismatch main motor?
Yes, If you have installed a main motor from Aficio 1015 the machine will work and there will be no SC Code displayed, but the machine will print a reduced image.
The part number for the main motor for Aficio 2015 is :
" AX06 0270 Brushless Motor 24V/20W "
Oct 05, 2013 | Ricoh Aficio 2015 Copier
I have a richo copier aficio mp c2050 the toner bottle is full and i need to change it, however i cannot find in any books where the bottle is and how to change it. does anyone know where it is on this...
you can change. You have a door right in front of the equipment. If you open that door you see the toner bottles. You pull the old one and then put the new bottle
Jan 20, 2011 | Ricoh Aficio 450 Copier
Functional problem sc 541 for richo aficio 1022 photocopier
SC541 = The melting temperature measured by thermistor is less than 71 C
The problem lies in the fuser:
- Thermistor fuser defective or incorrectly installed
- Fuser Lamp failure
Solution: Replace Fuser
Jan 05, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Need to reset maintenance count on a richo aficio AP410n laser printer ?
• After the technician replaces the fusing unit, the maintenance counter must be reset with engine SP mode 7-804. • 7-804-1: Transfer roller • 7-804-2: Paper feed roller • 7-804-3: Fusing unit).
Jul 27, 2010 | Ricoh Aficio AP410N Laser Printer
May 28, 2009 | Ricoh Aficio CL2000N Laser Printer
Mar 03, 2009 | Ricoh Aficio CL3500N Laser Printer
k24674
jasbo
jasbo
