Question about Dometic Refrigerators
1984 RM 761 Dometic Fridge and I noticed two wires shorted out coming off of the burner. 1. What is the name of that part? 2. How do I fix it?
    Top Expert:
  • Dometic Master
  • 7,200 Answers
Heater element see if 12 volt or 120 volt
Posted on Oct 06, 2017
  • 51 Answers
SOURCE: Dometic RM 2804, freezer is
Adjust your temp control on the fins inside the fridge move it down it just slides on the fin. You may need a fan on the back of the coil to increase the air flow depending on the heat outside
Posted on Sep 08, 2008
  • 93 Answers
SOURCE: Ignitor on burner #2 keeps clicking even after burner #1 lights
Jenn Air uses a reignition system on their gas cooktops.It is very important that you have a well grounded recepticle. Please check that and please get back to me.
Posted on Oct 29, 2008
  • 62 Answers
SOURCE: Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
Posted on Jul 25, 2009
  • 9 Answers
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
woodchuck789
  • 4070 Answers
SOURCE: freezer works ....fridge doesnt
What is the recall for?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Aug 21, 2009
My 1987 dometic rm2600 works on electricity but not on gas. No light shows.
It is more then likely just a dirty orifice. The orifice is located just before the burner. It is a brass fitting that screws into the burner. It can be cleaned by removing it and soaking it in rubbing alcohol for a half hour then blowing it out. Do not poke anything through it! One cleaned try the fridge again, if this does not cure the problem then it is more then likely your thermostat that has failed. These thermostats are still available. They are a dometic dual stat and can more then likely be found on Ebay for around $100. For any other RV fridge issues please contact ArctiCold Refrigeration We keep it cold with locations accross North America we can help you with your RV fridge problems. ">
Aug 14, 2014 | Dometic Refrigerators
Why won't my fridge light on gas?
It could be a few different issues. It could be a dirty orifice and or burner, it could be a bad safety, or even a thermocouple. If you would like some help diagnosing the problem better please feel free to give Arcticold a call toll free 1-888-782-6665 ArctiCold Refrigeration We keep it cold ">
Dometic RM 2800 Works great on AC but not on LP
Most likely cause is a blocked gas jet in the main burner its rare for the thermostat to be faulty but you cant dismiss it
Jul 27, 2009 | Dometic RM2652 Refrigerator
Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Mar 30, 2009 | Dometic RM2620 Refrigerator
Dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Oct 22, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
37 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
