Question about Samsung Cell Phones
If uninstall an app on 1 device will it uninstall on my other 2 samsung devices
    Top Expert:
  • Samsung Master
  • 47,607 Answers
No
devices while similar are separate
Posted on Apr 30, 2017
clark_styx
  • 282 Answers
SOURCE: DRIVERS FOR DELL XPS M1210
you need the ricoh chipset drivers
Posted on Aug 03, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Samsung YP-U3 not recognised. This device cannot start. (Code 10)
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Posted on Dec 15, 2008
  • 565 Answers
SOURCE: I need drivers for laptop sps 1210
all Drivers for your computer can be found here
u most look what u already got what not
If it helped rate fixya
Posted on Jan 04, 2009
  • 233 Answers
SOURCE: Gateway USB ports stopped working
So maybe you need to install the drivers for the USB device you are trying to connect. Also, with the computer off, try cleaning all USB ports and plugs. You can buy electrical cleaner in a spray can at Radio Shack. Let it dry thoroughly before powering up. But to me it sounds like a driver problem. Unless maybe your USB BUS is going bad.
Posted on Jan 07, 2009
SOURCE: How do I connect my bluetooth device to cell phone
To pair with another Bluetooth device follow the steps below:
Place the Bluetooth device in discoverable mode
From the Home menu screen , touch the Main menu tab, located at the bottom
Touch Settings
Touch Bluetooth
Touch Bluetooth On, unless already on
Touch Trusted Devices
Touch on the desired Bluetooth device
If prompted, enter the PIN, using the keypad (Default is “0000′ unless changed)
Touch Done
The handset will display “Connecting” followed by “Connected”
After a successful connection is made the handset returns to the Trusted Devices screen
Press the Home functions key to return to the Home menu screen
Try the steps yourself now.
will be expecting your comment.
Take care.
<a href='http://neverstill.com/openx/www/delivery/ck.php?n=aa90d9b4&cb=INSERT_RANDOM_NUMBER_HERE' target='_blank'><img src='http://neverstill.com/openx/www/delivery/avw.php?zoneid=25&cb=INSERT_RANDOM_NUMBER_HERE&n=aa90d9b4' border='0' alt='' /></a>
Posted on May 31, 2010
The process com.google.process.gapps has stopped on Samsung galaxy core prime phone. How do I fix.
If it doesn't happen repeatedly i wouldn't worry about it. If you continue to encounter the issue, you can uninstall google apps by going to my apps in the play store. If it does not allow you to uninstall google apps, you can "uninstall updates." Once done, reboot your device and update via google play.
Dec 27, 2016 | Samsung Galaxy Cell Phones
Tip
How to Close Apps on a Samsung Galaxy
1) Go to the Home screen of your Samsung Galaxy device.
2) Press and hold down the "Home" key on your device. This action will display a list of all applications you have recently accessed.
3) Review the list of applications to determine which apps you want closed.
4) Tap and drag each app you want closed to the right or left. The apps you drag off-screen will automatically be closed.
  • If you want all apps closed, tap on the "Remove All" icon located at the bottom right corner of your screen.
on Jan 10, 2015 | Samsung Galaxy Cell Phones
How do I delete all my google apps
You can remove apps from your device if you don't want them anymore or you need to clear memory space. If you uninstall an app you paid for, you can reinstall it later without buying it again.
Uninstall or disable apps
  1. Open your device's Settings app .
  2. Tap Apps or Application manager.
  3. Tap the app you want to uninstall. You may need to scroll to find the app.
  4. Tap Uninstall or Disable.
Uninstall vs. disable There are two ways to remove apps depending on whether you downloaded the app or if it came preinstalled on your device:
  1. Uninstall downloaded apps: If you downloaded an app from Google Play, you can completely remove it from your device.
  2. Disable preinstalled apps: Some apps come preinstalled on your device. You can disable these apps, but you can't remove them completely. After an app has been disabled, it will be hidden on your device.
Note: Disabling a system app may cause other apps to misbehave and will delete your associated data for that app.
You can find more information here:
https://support.google.com/googleplay/answer/2521768?hl=en-GB
Dec 05, 2016 | Tablets & eReaders
How can I remove metropolitan police scam that has blocked my samsung galaxy 2 tablet ? Am in safe mode and found suspicious files but cant delete them !
In safe mode, go to settings> apps, look around for any unfamiliar app. It's usually called Badoink or hidden as Adobe flash player. Click on the app and click uninstall. If it's not letting you use the uninstall option, go into security> device administrator and click on whichever to deactivate it then go back to your apps and it should allow you to uninstall it
Jun 13, 2016 | Samsung Galaxy Tab 2
How do i uninstall apps that are on my phone multiple times
That depends on which phone you have!
https://support.google.com/googleplay/answer/2521768?hl=en-CA
For android...
Uninstall, disable, and delete apps You can remove apps from your device if you don't want them anymore or you need to clear memory space. If you uninstall an app you paid for, you can reinstall it later without buying it again.
  1. Go to your device's Settings app .
  2. Select Apps or Application manager.
  3. Touch the app you want to uninstall. You may need to swipe right or left to find the app.
  4. Touch Uninstall or Disable.
  • Uninstall downloaded apps: If you downloaded an app from Google Play, you can completely remove it from your device.
  • Disable preinstalled apps: Some apps come preinstalled on your device. You can disable these apps, but you can't remove them completely. After an app has been disabled, it will be hidden on your device.
Mar 01, 2016 | Cell Phones
I need to know how to uninstall muliple apps of the same thing
Mar 01, 2016 | Kyocera Sprint Echo Android Dual Screen...
How do I uninstall apps on my Samsung Galaxy phone?
Samsung Galaxy s2: Uninstalling Apps that came with the phone (no computer):
Hello. Not every app will be able to uninstall if it comes with the phone. If you are not using them, they aren't doing anything to your phone except taking up a small amount of space. Remember, if an app is uninstallable that came with the phone, you will not be able to get it back, even if you factory reset the phone.
If you are sure you want to try and uninstall or disable apps on your phone.. this is the procedure:
Settings > Application Manager > (slide the screen all the way to the right) ALL > (tap on the app(s) you want to uninstall or disable (next to Force Stop button there's either an Uninstall button or there's a Disable button
To remove the ones that are not uninstallable, you will have to ROOT your phone. Note if you ROOT your device and you mess up on the instructions, you can potentially mess up your phone making it unusable. Also, if you ROOT your device, you will not be able to get any kind of servicing help from the manufacturer. (this is for advanced users). Once you ROOT the phone, you will have administrator rights over all files on the device, if you accidentally uninstall an application that you think you do not use, but the phone needs to have, you can mess up your phone. Think about this need to uninstall these apps before deciding that it is a must do. This may be more trouble then it is worth. Why not just DISABLE them instead. Remember: Should you want to sell your phone.. if you uninstall an app that came with the phone, you can not get it back even if you Factory Reset the device.. It will be gone forever.
A lot of people are obsessed with disabling and removing apps when it is not necessary.
HowtodownloadanddeleteAppsonaSamsungGalaxyS2-O2GuruTV.mp4
Feb 07, 2016 | Samsung Cell Phones
How do I get my LG 7.0 tablet out of safe mode?
Get an Android Tablet out of safe mode
Use the following steps to get out of safe mode.
    1.Restart your device by holding the power button, then tap Power off.
    2.Tap Ok to confirm.
    3.Power the device on. Your tablet should now be out of safe mode. If the device is still in safe mode use one of the following methods.
      ·Uninstall the last application you installed:
      1.From the Apps menu, tap on Settings.
      2.Tap on the app and then tap on uninstall.
      3.Restart your device.
      ·Perform a factory data reset:
      1.From the Apps menu, tap on settings, and then tap backup and reset.
      2.Tap on factory data reset, and then tap reset tablet
      3.Tap erase everything to format your tablet back to factory default configuration.
Nov 21, 2015 | LG 8GB G Pad 7.0" Wi-Fi Tablet Black
How do uninstall gallery 1.10.19 back to factory stock gallery on my Samsung galaxy exhibit.. it won't show up our go back even after I press uninstall update from application app
If it have the Uninstall Updates enable, then probably you have auto update enable in the PlayStore. Make sure auto update is not enable at least for that app, then go back and uninstall update. If it doesn't work,and you still want to get that app to factory setting, then you need to hard reset your device.
Feb 18, 2015 | Samsung Cell Phones
Apps that installed how to remove it
1-Go to app store on your device
2-Search for Uninstaller
3-Install, and run the application
4-Delete desired applications
Feb 09, 2014 | Samsung Computers & Internet
Cell Phones Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
