Question about Frigidaire Microwave Ovens
My frigidaire convection oven makes a rattling noise. I thought it was something loose in the door because if I push in on the door it stops, but I couldn't find anything loose in the door.
  • Frigidaire Master
  • 20,997 Answers
It is the air circulating fan making something vibrate. Remove the shelves and linings and replace them.
Posted on Apr 30, 2017
Frigidaire microwave plmv168cc1 makes humming noise when door closed
Chances are that the secondary (cook) relay on the control circuit board is shorted, meaning that the oven is actually cooking any time the door is closed.
You can test that by putting in a cup of water, shutting the door, and letting it go for about 30 seconds, then checking the water temperature.
This is dangerous, and can lead to a fire, so please unplug the oven until it is repaired.
The relay can be replaced for far less than the cost of a new control circuit board.
May 31, 2012 | Frigidaire Microwave Microwave Oven
When started,light& turntable operate normally,but no heating by microwave. Transformer normally sounds smooth,but now makes rattle or vibrating noise,like something is loose.
Check the door safety intertlock micro switch for proper behavior. If it is faulty, the oven will think the door is open and will not turn on the magnatron.
Sep 22, 2010 | Panasonic NN-C980 Convection/Microwave...
Odd buzzing after timer stopped, food was still being heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r6uw
Aug 20, 2009 | Whirlpool MH1150XM Convection/Microwave...
Sharp 1874- Door seems to "jar open" and oven stops
if you have a warranty get a new one installed they have to honor your warranty or better yet if they want payment you want new unit sometimes they come deffective from the factory ad you may have gotten one of them
Feb 20, 2009 | Sharp R-1874 Convection/Microwave Oven
Clicking noise whem door is closed
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Otherwise, see this video for help.
Feb 09, 2009 | GE Advantium 120 Convection/Microwave Oven
Convection oven stops every 5 minutes and won't continue
to trouble shoot hold the door securely shut for longer than 5 min to see if it runs longer if it does the you should replace the interlock devise
Dec 25, 2008 | Sharp R-930AK Convection/Microwave Oven
Kitchenaid builtin microwave buzzing
I would recommend changing the diodes as well. This will usually take care of the problem.
Oct 25, 2008 | KitchenAid KEMC377K Convection / Microwave...
Our sharp 957 will now only microwave for 59 seconds then stops and rattles for thirty seconds. The convection option stopped working ages ago. Any ideas please?
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
This is also likely why your convection mode stopped working.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
Sep 27, 2008 | Sharp Microwave Ovens
R-9H66C does not heat.
Yes, it is either a bad door switch or a loose or misaligned door switch holder.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 19, 2008 | Sharp R-963 Convection/Microwave Oven
Wont heat items in the micro or convection
MODEL NUMBER NEEDED
Apparently this is not actually an R-510HK since that model does not have convection mode. Can you reply back with the correct model number? We may have the service manual for you.
A PRELIMINARY OPINION
It sounds like you have loose door switch mounts or possibly loose door hinges.
If the door won't open via the door open button, then the outer cover will have to be removed.
BEFORE YOU RATE THIS
This is a preliminary post, asking for further information (model). Please withhold your rating until we actually offer the solution.
Dec 06, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
331 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
