Having trouble installing the exhaust to the portable AC. received 2 round unit adaptor instead of a round one and a square one. help
    Top Expert:
  • Televison & ... Master
  • 46,577 Answers
Get it from the manufacturer or manufacturers service agent
depending on the size , there are square to round poly pipe fitting used for rainwater drain pipes available at the local hard ware shop so check them out to see if the sizes will do
Posted on Apr 30, 2017
Protron pdv 288 AC adaptor (need part from wall to converter) (USA)
Hello Javargas - Your unit will work fine with any generic 12V DC 3 AMP AC adapter. It's probably marked somewhere on the back of the unit (at least the 12V part).
If you have trouble finding one with 3 AMPs you can buy universal ones that will dial up automatically the voltage/amps the unit needs.
The generic kind can be had for about $20 (USD) while the second kind usually sells for around $35-40.
Happy movie watching.
Mikeywaf
May 16, 2011 | Protron PDV-288 7" LCD Portable DVD Player
Parts for Amcor Portable Air Conditioner
Your parts can be found at amazon, click here and take a look: Finally charging for our multi device world. I hope this was helpful. Cheers
Apr 30, 2010 | Amcor AF9000E Portable Air Conditioner
Have lost the cable that connects to computer. Besides the power, there are 2 sockets on the back. Tried a cable from the square socket to USB but computer doesn't recognise that a device is connected....
The round socket sounds like the power port, and the square one should be the USB as you thought.
Please respond with the scanner make/model and one of us can verify the connections required.
Joe
Dec 20, 2009 | Canon CanoScan D1230U Flatbed Scanner
Exhaust fan running slow
sounds like the compressor is turning off cause of high pressure. check the coil that the exhaust hose connects to, if dirty clean it. if the fan is not blowing enough air threw the coil the unit will build up high side pressure and cut out, but will turn back on when pressure drops. if that dont help, maybe the fan motor is bad or needs taken apart and oiled.
May 31, 2009 | Maytag Portable Air Conditioner M6P09S2A
No power
fb_dl
1)If you have a friend or know someone who have basic knowledge with electronics better ask that person to check your charging adaptor ( AC to DC adaptor) In the adaptor itself it indicates the DC voltage output it produced(ex. 3V / 4.5V / 8.5V /12 V )
2) if you don't know someone having knowledge with electronics, check the Voltage specs. of your adaptor , voltage polarity and the Dc jack size. You can alternatively purchase adaptor having the same specs.,polarityand dc jack size in a cheaper price.It's also adviceable to carry with you ,your portable player upon purchasing new adaptor so you can actually see if you have problem with the adaptor itself or the player does.
cheers.
mark
Jan 16, 2009 | Insignia NS-PDVD10 Portable DVD Player
How to find rectangular to round transition adaptor
They used to sell them at sears. Its a common duct item for vents. Try home Depot.
Jan 13, 2009 | Samsung SMH7178STD Microwave Oven
Faulty AC adapter
Same called Sears Placed and order Paid 136.95 plus shipping Tax total $168. 12 weeks no part with no due date
Apr 21, 2007 | Protron PLTV-32 Television
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
No power via batteries
The batteries are put in wrong, or there no good, or the dc jack in the back still has the plug in it for the ac adaptor. You see theres a small switch on the jack inside the unit that switches from the ac adaptor to the batteries, when the jack is iserted. Also if the plug is not pluged into the jack, then there could be a bad jack or a broken solder connection on the jack inside on the printed circiut board. good luck
Jul 03, 2006 | GPX TVB544 5 in. Portable Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
