Question about Whirlpool Refrigerators
Whirlpool gold french door bottom freezer ices up and causes fridge to run warm. I have taken it apart and defrosted several times. Fan works, drain is not clogged. What could be the cause of this?
  • 221 Answers
The self defrost function is not working. Depending on the age and model you have a heater, bi-metal defrost thermostat.....and either an electronic control or defrost timer. One of these parts has failed. Need a model number to tell you more.
Posted on May 02, 2017
  • 1073 Answers
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
Krazytech
  • 725 Answers
SOURCE: Kenmore Refrigerator Mod 70162990
It is under the evaporator you will have to remove the back cover... let me know if you want to do it and I will step you thru it...
Posted on Sep 01, 2008
  • 1314 Answers
SOURCE: My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Posted on Sep 11, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Defrost Drain clogged
Take a spray bottle with VERY hot water and spray it down the drain line
Posted on Jun 02, 2009
Testimonial: "Good advice. Wife called repairman before I could apply. Repairman did same thing, but with pressureized."
  • 125 Answers
SOURCE: My whirlpool French door fridge is leaking all over the floor. The drip pan underneath is bone dry. I can't find the drain hole inside the fridge to see if it is clogged. Is letting it thaw for tw
there is a water tube connection at the bottom of door on hinge side that has a spring and allows it to swing with door. it also has a fitting there so the door can be removed.it is the tube running inside the door to the ice water dispenser. if it has one, it can leak at the fiting
Posted on Jul 07, 2012
Jul 07, 2012 | Whirlpool GX5FHDXVY Stainless Steel (248...
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Too warm both freezer and fridge recently ice cubes melted when opened a lot.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 28, 2009 | Admiral Refrigerators
Kenmore refrigerator will not cool. Freezer works
Aug 27, 2009 | Kenmore Refrigerators
My Daewoo FRS2021IAL has a warm fridge
Aug 26, 2009 | Daewoo Refrigerators
Whirlpool Side By SIde Refrigerator Freezer stopped cooling
Aug 24, 2009 | Whirlpool GS6NBEXRQ Side by Side...
It looks like whirlpool refrigerator compressor's replay failed and refrigerator is not freezing.
Aug 23, 2009 | Refrigerators
2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Aug 18, 2009 | Refrigerators
I have the same problem .i took apart the inside of
Most/many times this is a clogged up or restricted defrost drain system, but once in a while the drain system has been cleaned and everything appears to be good but you still get ice in the defrost drip tray and such and the drain freezes over. Some manufacture designed kits to help and some home made remedies. http://www.applianceaid.com/defrost_drain_freezes.html
click the link given above
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Mar 02, 2009 | GE GTS12BBPLCC Top Freezer Refrigerator
Ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
Refrigerators Logo
43 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
