Question about Sewing Machines
US SIZE 5 KNITTING NEEDLE. WHAT SIZE IN AUSTRALIA
  • Sewing Machines Master
  • 12,009 Answers
Converting a 7mm knitting needle to inches
Converting it to European needles would be the same size needle. If the needle is too thick for the pattern, try using a 6mm or 5.5mm. check your gauge/tension and make a test swatch. then you will be able to figure out a needle size for the pattern.
It's not the needle size that counts so much as the gauge or tension. for a proper fit etc. hope this helps.
Jul 22, 2017 | Sewing Machines
What does a size 13 knitting needle convert to in cm?
A size 13 knitting needle converts to O.225 cm or 2.25mm
Jun 03, 2017 | Sewing Machines
What size is a knitting needle of 150 cm
point 9 cm, i. e. 9 cm
That is the conversion of size 13 knitting needle and has nothing to so with 150 cm
Needle size conversion chart
The size chart converts to mm. A unit chart converts that to the quoted CM.
Jun 02, 2017 | Sewing Machines
What size needles for bulky/12py wool?
It depends on your project. You need the size needle that will give you the stitch width and stitch length called for in the pattern. The pattern calls for a specific gauge, so you'll need to try out different needles, knitting a swatch on each needle size, and counting the number of stitches across and down to match the pattern specification. Does the pattern not give you a needle size? Needles come in either straight or circular in all various sizes as long as you stay within the same brand needle. (Needle brands differ from one to another, so try to stay within only one brand.) So a straight needle size 6 should be the same size as a circular needle size 6 (of the same brand).
However, although it may call for a specific size needle, you will still need to knit some test swatches because knitters usually knit looser or tighter, so one needs to adjust the needle size to accommodate those differences, ie someone who knits tightly may get 8 stitches to an inch, but a loose knitter may get only 6 stitches. But if the pattern says to cast on 48 stitches in for row 1, that means the 8 stitch gauge will yield a project that measures 6 inches wide (48/8=6). But a 6 stitch gauge will yield a project of 8 inches wide (48/6=8). The result would be one project will be 2 inches wider than the other.
But that is only half of the problem as you would still need to measure the number of rows per inch to get the length of the project. If there are more rows to the inch than specified, a garment with say an armhole that may be too small. If there are fewer rows to an inch, the result may be an armhole that is way to big.
Be very careful with your pattern and yarn selection. You will be much more successful if you stick to the number ply and yarn weight specified in the pattern, ie if the pattern calls for 2-ply 2 oz yarn, there may be some particularly difficult issues with substituting a 4-ply 4 oz. yarn. You may end up with a project that will not fit. For instance, you wouldn't want to use a heavier yarn to knit a baby garment. Baby garments usually call for baby yarn which is a specific ply and weight.
How to Measure Your Gauge in Knitting
earthguild com
3 Things You Might Not Know About Knitting Gauge Adjustment
Oct 30, 2016 | Sewing Machines
I Just finished the back of a sweater and it is way too big. Does that mean my needle is too large? My gauge was correct.
If the gauge is correct, the sweater should be the right
size. When you check the gauge, you need to check both the width and length. If you knit loosely, it will also make the sweater too large. You can try knitting tighter or decrease the needle size until the gauge is correct both directions.
Oct 21, 2016 | Sewing Machines
Could I use 4 ply instead of 3ply In a dolls knitting pattern
You should probably do a test to make sure that the pattern using 4-ply yields the same size as it would using 3-ply, otherwise your finished item will not be the correct size. Most patterns have a test pattern to make sure your results are what the resulting pattern should be, ie knit a swatch of the pattern and measure it against what it should be according to the pattern instructions. You may need to change the size of needle to get the best result.
Sep 27, 2016 | Sewing Machines
How do I cast off in knitting?
Take a needle several sizes larger than the ones you have used for the knitting - so the loops will be larger and the edge looser, knit the first two stitches onto the larger needle then use the tip of the other needle to lift the first stitch over the second one and right off the needle, so it is looped over the second stitch, but is no longer on the needle.
Knit another stitch and repeat the lifting over. I f you are casting off all the stitches continue to the end of the row and then cut the yarn, pass the end of the yarn through the last stitch and draw it up.
If you are only casting off part of the row then move the last stitch onto the right size needle and continue knitting on the stitches left in the row.
Dec 03, 2014 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
