Question about LG Refrigerators
Lg refrigerator making yellow ice, model ldc24370
mastatech
  • 478 Answers
SOURCE: makes ice very slowly to none...
You need to turn the freezer side to a cole=der setting to allow ice to freeze faster.
Posted on Mar 12, 2009
daddyo742001
  • 70 Answers
SOURCE: We have a LG bottom
Make sure water is gettig to solenoid vale on back. If so make sure screen is not plugged and solnoid is real opening. May need to test coil on valve. If it is not opening or froze off Ice marker will cycle several times a day as it is temp actuated.
Posted on Jun 29, 2009
carputers
  • 255 Answers
SOURCE: My Lg refrigerator ice maker won't work. The arm
ice is stuck in it, take it apart an clean it/defrost
Posted on Sep 07, 2009
SOURCE: kennmore refrigerator is not making ice,but water
The control light flashes to indicate the infrared beam is being blocked. The flap on the opposite side blocks the beam when the door is open to prevent ice from being dropped on the floor rather than in the ice bin. If you pushe the flap in so it's flush with the liner (use care not to block the hole) the light should go from flashing to on in a steady state. If not, your electronics are bad and would need to be replaced. If the light does glow steady, then the problem is with your ice maker, water valve or ice maker fill tube.
Posted on Dec 23, 2009
  • 44 Answers
SOURCE: My Kenmore refrigerators (model #79177990) ice
Ice inlet tube may be frozen up inside of Fridge. Thaw it out with a hair blower. Shut of water supply and disconnect the water line that goes into the back. Use a flexable item at the connection to see if will go all the way through to the icemaker. I used a zip tie.
If you still don't have water going to the icemaker, you may need to replace the "Water Inlet Valve" at bottom back right of your Fridge. Easy to Do.
Posted on Jun 06, 2010
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
I have a LG refrigerator, Model LFX25971, and ice maker doesn't make ice. What is problem
it may have a plugged water filter or check the valve on the water line to make sure it is on if that doesn't work replace the valve and water line to the refrigerator
Feb 20, 2011 | LG ElectronicsZenith 5989JA0002G ICE MAKER...
LG Refrigerator LFX24971ST - ice naker does not make ice
Arm should not be in up position unless harvest cycle is in progress. Or unless you manually put it there to cut off Ice Maker. Most likely ice maker is defective
Nov 12, 2017 | LG LFX25971ST Bottom Freezer French Door...
LG LFC23760ST ice maker barely making ice
The making of ice may speed up a bit after the whole unit interior and insulation is cooled down.
Jan 28, 2010 | LG LFC23760ST Side by Side Bottom Freezer...
My LG refrigerator model#26945TT does not make ice anymore. Any thoughts what could be issue?
Check the following
  • timer, which is located at the rear side of the refrigerator
  • open the freezer casing and check the thermostat
Aug 07, 2009 | U-Line Refrigerator Ice Maker
MY ICE MAKER FEELER ARM IS STUCK IN THE UP POSITION. CAN YOU PLEASE TELL ME HOW I CAN FIX THIS? MODEL LFX25950SB LG REFRIG
Water is getting into the area where the arm pivots and freezing. This prevents the arm from dropping down when it should. I use a hair dryer to melt the ice in the area of where the arms comes out of the base. As soon as the arm drops, the ice maker will make more ice. This LG in the door icemaker is junk.
Jul 14, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
We have a LG bottom freezer refrigerator we bought in 12/08 and the ice maker is not making ice but still sounds like it is and the water line is open. Freezer is freezing foods ok and the top of...
May 08, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Mar 21, 2009 | LG LRSC26910 Side by Side Refrigerator
LG refrigerator model lfx25950tt ice maker not working
I had the same problem and replacing the filter solved the problem for me.
Mar 16, 2009 | LG Refrigerators
Makes ice very slowly to none...
Mar 12, 2009 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
78 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
