Question about Golf
Have eza gz golf cart .was using cart ther was loude noize cart wont ford or back ?
  • 1,162 Answers
Computer or controller has died, or both.
Posted on Jul 24, 2017
  • 6 Answers
SOURCE: electric golf cart, mash the pedal won't move
you have a broken belt .
Posted on Jun 03, 2009
  • 3 Answers
SOURCE: Can I leave my 2004 ezgo golf cart charger plugged
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
Posted on May 15, 2012
  • 77947 Answers
SOURCE: My 2003 FORD Expedition wont'n start a weird noize is coming from the fuze box
That kind of noise is almost always from a dead battery. Remove the battery and take it to a Autozone parts store or other store like them and have them test it on a special battery load and cell tester they have. The test is free.
Posted on Jun 19, 2012
  • 24 Answers
SOURCE: Golf Cart Wiring
James can you trace the wires back to the source? Sometimes there are 12v accessories such as a fan or radio on those that would require you to hook up the wires on the positive and negative from two connected batteries to get a 12v output. So in your video, all you would have to do is move the small black wire to the negative of one the batteries connected to the one with the yellow bungie. The red wire should be okay where it is. Trace the wires back if you can, but hopefully this helps. Good luck, sir.
Posted on May 24, 2013
Myezgo 2007 golf cart wont charge thr batterys bill has the same cart his charger wont ework either
Check your batteries under load, then check the wiring. Make sure the black and white charging wires are connected to the mains. If all good then check the pins in the charging receptacle.
May 31, 2017 | Golf
How to fix accelerator that doesn't come back off. When you push on it you have to pull it back off. On cub car golf cart.
Probably a broken return spring or just corrosion. You would have to get under the cart to see if this is the DS model. If it's the precedent model, It is one unit in the floorboard.
Mar 18, 2017 | Golf
What type of oil does the yamaha golf buggy use ?
Mike, Yamalube 4-cycle oil or quality SAE 10w-30 motor oil, is the oil for use in your cart. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
what kind of oil 2 use
What Type Oil and Amount is used in Yamaha G22 Max Gas Golf Cart
What type of oil does Yamaha golf cart take
Aug 07, 2016 | Golf
Troubleshooting a golf cart - > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
Jan 24, 2016 | Golf
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
Do you need a driver's license to drive a golf cart?
Licenses are not prerequisites to driving a golf cart.
Jan 14, 2013 | Golf
Jun 19, 2012 | 2003 Ford Expedition
Neewer eza-c1 manual
EZA-C3 Manual, only difference is the plug that fits the camera...
Jan 30, 2012 | Cameras
Golf Logo
368 people viewed this question
Top Golf Experts
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
