Question about Cell Phones
How to record my voice on the phone - Cell Phones
How to activate voice dial phone feature
Touchscreen phones simplify the wireless world, especially when combined with voice activation. Although making calls using voice commands was an option before touchscreens became available, the method used to set up this feature is different than it is for non-touchscreen units. It can take time to master the set of procedures that will get the feature working.
Step 1
Create a voice tag. Touch "Contacts" on the today screen. This opens the list of contacts on your phone. From here, do one of three things: you can hold your finger on the desired contact and then tap the "Add Voice Tag," you can select the desired contact, tap on "Menu" and then "Add Voice Tag," or you can tap the desired contact to open their personal screen and then hit "Menu" followed by "Add Voice Tag."
Step 2
Record the voice tag on your phone. Touch the phone number to which you wish to add a voice tag then touch the "Record" button. Record your voice tag for that contact. An icon will be displayed to the right of the number when the voice tag is complete. You can listen to your voice tag by touching the "Play" button on the screen or you can delete it to record a new one.
Step 3
Make a voice tag for a program. Tap the "Start" button on the phone. Go to "Settings" and then the "Personal" tab followed by "Voice Speed Dial." Choose the program for the voice tag and record the voice tag in the same manner as you did for the contact. To open the program with the voice tag, tap "Start," "Programs" and then "Voice Speed Dial."
Step 4
Launch a program or make a call. Make a call by tapping "Start" followed by "Programs" and then "Voice Speed Dial." You will hear a beep. Say the voice tag you recorded for the person you wish to call. You can open a program via the same procedure (by speaking the voice tag created for the program).
Step 5
Check the voice tags you created. Tap on "Start," "Settings," "Personal" tab and then "Voice Speed Dial." A voice tag tab appears and displays a list of your voice tags.
Jun 20, 2016 | Cell Phones
Tip
How do i send a voice memo with my blackberry 8830?
The BlackBerry 8830 smart phone, and other BlackBerry phones, come with an application to record voice memos called "Voice Notes Recorder." From this application you can create, store and send voice memos directly from your phone. You do not need to upload the memo on the computer or send it through email (unless the recipient cannot receive multimedia messages).<span><br /></span><br /> <span> <span>Instructions</span> <ol> <li><span>Open "Voice Notes Recorder" on your phone.</span></li> <li><span></span><span>Press the trackball to record the voice memo. Press it again to stop recording.</span></li> <li><span></span><span>Scroll to and select the mail icon while the memo is stopped.</span></li> <li><span></span><span>Select "Send as MMS."</span></li> <li><span></span><span>Choose the contact from the list, or choose "Use Once" and type the phone number of the recipient.</span></li> <li><span></span><span>Add a note to the message if you wish.</span></li> <li><span></span><span>Press the "Menu" button and select "Send" to send the voice memo and message.</span></li></ol></span>
on Mar 12, 2011 | Cell Phones
Recording with a Digtal Voice Recorder
Your telephone does not contain a special connector for this type of device. Besides, I wonder if your voice-recorder has a connector for this, like a mic-in. If there is, you can consider to buy a special electronic device, which taps the audio from the telephone-line and hook it up to your digital voice recorder.
Also, you can do it without this electronic device, but requires electronic knowlegde and tools.
If the phone and the voice-recorder both miss a connector to connect to each other, you can always go for the handsfree-mode of this phone and activate the voicerecorder when there's an incomming call..
Oct 14, 2013 | RCA Executive Series 25404re3-a 4 Line...
HOW DO I PLUG MY Olympus Digital Voice Recorder VN-5500 INTO A TELEPHONE TO RECORD PHONE CALLS
Hi p_cullingfor,
i am afraid that is not possible. the best solution is to hold the voice recorder near the microphone of the phone and record.
i hope this helps, good luck!
Mar 17, 2011 | Olympus VN-2100PC Digital Voice Recorder
How to record voice calls on samsung corby S3653? There is a voice recorder,but it does not function during calls. Which software can I use for recording voice calls?
Jan 22, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
I am having smsung sgh-L700. its not having the feature of recording voice calls . i want to know whether we can do that using some software.
Try recording with the inbuilt voice recorder.To access voice recorder go to main menu and reach the inbuilt voice recorder
Dec 02, 2009 | Samsung SGH-L700 Cell Phone
VOICE RECORDING
razors dont record very well they have to be close up to what u r recording.
May 19, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Nokia N72
to record voice memos, press the menu button, and select OFFICE->RECORDER. To record a conversation, choose RECORDER during a voice call. Both parties will hear a beep every 5 seconds while call is being recorded.
May 16, 2008 | Nokia N72 Cellular Phone
Voice Memos
that is why the phone comes with a manual pls read it
May 09, 2008 | Motorola Mobility MoroKRZR K1m Cellular...
Voice recorder
the voice key is on the side of the display screen same side as pwr hold that moz-screenshot.jpgmoz-screenshot-1.jpgto record your voice let go when finished
Feb 21, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
