Question about Garden
My new troybilt tiller tines start turning as soon as I start it. And I can't get them to stop. Need help.
  • 10865 Answers
SOURCE: Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Posted on Apr 25, 2009
  • 69 Answers
SOURCE: Roper tiller 26 inch front tine Pulley/belt diagram
I am not sure either, but I think that it would be alot cheeper to buy a new tiller, than to use your strenght fixing a old tiller that you didn't bother to keep the instructions for (no, I am not trying to be harsh. I am trying to be nice. and I am not sure about it coming with instructions, they usually do.)
29259605.jpgSorry, that is the closest picture that I can get.
Here is a link that may help. (IDK, because it is blocked where I am at.)
Posted on May 14, 2009
SOURCE: Tines are locked
When you throttle up, does the engine bog down and stop?
Posted on Jun 03, 2009
  • 138 Answers
SOURCE: Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Posted on Aug 21, 2009
  • 48 Answers
SOURCE: Tiller tines will not turn. Engine runs fine...
Well hopefully it's not the transmission, as sometimes these tend to go. Another common but cheaper repair are the two bearings where the tines connect to the unit.
MORE THAN LIKELY.. The bearing is located above the worm gear housing, the part connected to the tines beneath the guard. This removal can be somewhat frustrating but if you remove it and remove the engine flange you'll be able to manually spin the drive shaft and see if it's the worm gear housing/lower bearings or if it's the more likely bearing on the clutch drum or the clutch itself.
Posted on Apr 16, 2010
Drive belt is slipping when under load. How do you tighten the belt. thanks, Ted Troybilt Horse rear tine tiller
hi there, ive been doing a bit of head scratching over this one as i needed to check my facts. i think the belt has a automatic spring loaded adjuster so it sounds as if you need a new belt for it.
good luck
Apr 30, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
I am in need on line of the owners manual for troybilt "8-hp Horse" tiller and fluid capacities and type/weight of oil used in front transmission and rear tine gears. Thank you, Sincerely, Wm....
This is as close as I could come to your exact model from this site. This is for a 8HP Briggs Horse model with rear tines. I hope this can help you. This site (the manuals site) needs to update to newer models. First a link to the site I use and secondly, the PDF online file of the 8 HP Tiller for you.
Apr 12, 2011 | Troy Bilt 21A682J766 Horse 8 HP Rear Tine...
The drain plug is generally located on either side of the engine near where the block bolts to the frame of the tiller. It can be a square headed plug or an allen socket head plug.
Feb 12, 2011 | Mtd 21a 643b066 Bronco Rear Tine Tiller
Where is the model number on my troybilt rear tine tiller?
If it's as old as mine (circa 1976), it's stamped on the casting right below the T-handle that allows the handle bars to pivot (also the gear case fill cap)
Mar 28, 2010 | Troy-Bilt Pony Garden Tiller
Troybilt tiller Model TB144 NO SPARK FROM PLUG
it sounds like you need a new sparkplug. Bring the old sparkplug to auto zone and tell them to give you the same kind.
Jun 12, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
How do i adjust belt on troy bilt horse tiller
How do I tighten a belt on a troybilt Tecumseh rear tine tiller?
May 04, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Apr 25, 2009 | Craftsman 8.50 Torque Rating Rear Tine...
Tines are locked on my Troybilt Tiller-Edger,
Mar 20, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
