Question about Sony Televison & Video
Audio sony bravia, works for apps but not tv
Sony bravia TV audio doesn't work for TV mode (att cable) I did reboot the router. audio doea work for netflix app, hbo go etc
  • 630 Answers
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Posted on Nov 08, 2009
  • 4338 Answers
SOURCE: Just purchased a Vizio 37" HDTV with Netflix app
The Vizio does not have Internet capabilities. You need to hook up a computer via the VGA or HDMI port. Then youor computer controls what you do with the intenet.
Posted on Dec 03, 2010
  • 150 Answers
SOURCE: I just got this Vizio
Before you go to any more trouble troubleshooting potential hardware and/or connection issues, look at this page of reviews on Dell's site, taking special care to read 'Review 8' by an owner named 'Milwsport'.
Posted on Feb 27, 2011
Testimonial: "thanks for the quick informative response!"
  • 1284 Answers
SOURCE: the tv goes on but the apps display with netflix,
Try restetting the TV by unplugging for 2 minutes then retrying it. If it still fails then there is most likely a failure on the main board in the TV
Posted on Jul 27, 2011
  • 3320 Answers
SOURCE: i want to update my netflix and hulu apps to the newer versions on my vizio E3D420VX TV
Updates will come from netfix and hulu. look for update option when on those sites.
Posted on Apr 01, 2014
The inputs on our sony bravia are all not working
go to the tvs setup menu and try to reprogram the channels back into it..usually happens after a significant power surge..
Jan 19, 2014 | Sony BRAVIA Televison & Video
I have Sony Bravia KDL-46HX800 3D TV. My Ethernet connection stopped working. I can't get IP, my Sony blueray player doesn't have such problem (it is connected to the same net. switch). TV say
use a straight thru to connect directly to the router. Cross overs are typically used when connecting PC's directly together or daisy chaning routers or switches. Try a different port on the switch? Also from a pc, go to the DOS prompt and try and ping your TV. If your TV IP settings are all correct, and your network equipment is working, your should get a response from pinging your TV. If you don't, I would suspect a problem with your TV Enet port.
Jan 05, 2013 | Sony BRAVIA KDL46HX800 46 1080p LED 3D TV...
I recently got a DAV-HDX576WF system. Everything works well but I dont get any sound from the left side when in TV mode, Im using a fiberoptic cable for the sound from my TV
Failure of a digital feed can't be channel-specific. The bitstream either works or it doesn't.
It sounds more like an analog audio feed with a failing channel cable. What path does the "TV" audio follow before it gets to that fibre optic cable?
I'd draw the sound from the Cable Box and bypass the TV.
Jul 03, 2011 | Sony BRAVIA® DAV-HDX576WF Theater System...
How to connect camera to sony bravia tv.
Connect your camera in RCA cable (the one with a red, white, yellow connector for audio/video connection). Then connect it to your Bravia TV.. Set your Bravia TV in video mode, (the mode when you're playing DVD player in your TV)..
Note: Your video mode depends on where you connect your RCA cable. There are up to 3 video mode, Video-1,Video-2,Video-3
Then turn on your camera..
May 22, 2011 | Cameras
40" Sony Bravia has intermittent audio failure.
I have a KDL-46VL130 with the same problems. Audio on the HDMI connection turns on and off intermittently when I have it connected with my ATT Uverse rcvr. I check w/ Sony online support and they led through the standard troubleshooting process ... which I knew going in would not fix the problem. Ultimately they told me to try a new HDMI cable first, or try a different video source for the HDMI, other than my ATT U-Verse reciever and see if the problem persists. Having seen other articles on this issue, i am almost certain that is not going to fix the problem... and to think that I paid $2000 for this thing.
Dec 13, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Connect cablebox/dvr to sony bravia
try yellow cable into the green y input.
The problem is that av output is going into component in
If the green port doesn't work I read on another forum that
you may be able to use a dvd recorder unit to take the av in and then it can re transmit the video to an output as component out on some dvd recorders.
Apr 29, 2017 | Sony BRAVIA® DAV-HDX576WF Theater System...
Blue screen, have AUDIO ON ALL CHANNELS!
Make sure video cable is connected on right socket. for instance AV1. test cable box on other tv to see if it is transmiiiting picture. If so make sure your tv is tuned to cable box if using RF cable or on slected av mode where av cable is connected
Apr 07, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Feb 08, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
Nov 05, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Open Questions:
Televison & Video Logo
22 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
