Driver for Tevion fs 5000 w10 bit 64 - Office Equipment & Supplies
anandg27
  • 1272 Answers
SOURCE: vista 64-bit driver or windows 7-64 bit driver
Please note that PS121 does not require drives for its configuration. It can be configured manully using a browser:
Step 1:-
1.Connect the PS121 to the router & check the lights
2.Press the diag button with a paper clip, it should give a print out which should include a IP address (make a note of the IP address)
3.Open the browser & enter the IP address on the address bar, it should give you a prompt for a Username & password (Username = admin; password = password), this will show if PS is communicating with the network.
4. Make sure that all the firewalls are disabled (including windows firewall)
Step 2:- (For XP)
1. Go to control panel then go to printer and faxes.
2. Right click on the printer icon go to properties.
3. Click on the ports tab on the top.
4. Click on add port.
5. Select standard TCP/IP port and click on new port.
6. Press next.
7. Enter the IP address of the print server it will show you the port (IP_ip address).
8. Press next.
9. Select the second option custom and click on settings button.
10. Select the protocol as LPR; enter the queue name as q1.
11. Select LPR byte counting enable.
12. Click on ok and press next then click on finish.
Step 3:- (For Vista Computer):
1. Please confirm you are able to print by connecting the printer to the Vista computer directly.
2. Click Start - select Control Panel then switch it to Classic View from left side.
3. Double click on Printers & Click on 'Add a Printer'.
4. Select 'Add a local printer' & Click next.
5. Select 'Create a new port'.
6. Select 'Standard TCP/IP Port' as 'Type of port' then click 'Next'
7. Enter the IP Address of the Print Server in the 'Hostname or IP address' field.
8. Uncheck 'Query the printer and automatically select the driver to use' & Cilck next.
9. Select 'Custom' then Click on 'Settings' on the next dialogue box.
10. On the next dialogue box, select 'LPR' as the 'Protocol'.
11. Under the LPR Settings put in any name for the 'Queue Name'.
12. Check 'LPR Byte Counting Enabled' then click on OK and next.
13. Select the Manufacturer and the Model Number of the printer. If it is not available then click on 'Have Disk'. Click 'Next'.
14. Check 'Set as the default printer' and click next.
15. Try to print test page, it'll print.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Nov 09, 2009
TimeDefensiv
  • 746 Answers
SOURCE: 64 bit driver for EasyCAP DC60
Hi dear, just download the torrent file and get full version your required software or driver full and free.
http://thepiratebay.org/torrent/4949469/EasyCap___Vista_x86_x64_Drivers___Installation_Instructions
http://file.sh/torrents/ea/easycap-dc60-driver-xp-sp3.html
Good Luck
Posted on Dec 08, 2009
MarcusVR
SOURCE: CanoScan N1220U Scanner Windows 7 64-bit Driver
You may use Hamrick VueScan Pro, it installs a driver that makes 1220 to work. Or, if the version of Windows 7 you use support XP Mode, install it.
It's still a good scanner, and mine is working in 7 x64 using XP Mode!
Posted on Jan 16, 2010
JulesPCaut
  • 702 Answers
SOURCE: I need Driver for Tevion USB PC web Camera SN9C103
It might be a sonix webcam that is used by Tevion, I am not sure if they manufacture webcams themselves. Anyway, try a driver finder program. It will use the webcam's hardware ID to find a compatible driver for W7 for it.
Posted on Mar 30, 2010
muntejaya
  • 10421 Answers
SOURCE: printer driver canon W8200 64 bit
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay mnkas
Posted on Feb 12, 2011
Hp elitebook 8440p notebook cant play music through headset/headphone but only through loudspeaker
IN never came with w10 from, HP ever.
facts.
ok, HP told you not to use W10 , HP does not support w10 on this PC, now you can but some things will be dead.
I can list them all but will not now.
musical OS day, ?wow !@
you installed W7 from whom and what, ? MS disks or HP?
you installed w10 from whom? not HP but was MS, so was a fresh install or upgrade install, I cant guess or see what you did, not ever.
why not just run w7 and not upgrade, so HP will give you full support , why not?
head set, so does that mean , 3.5mm phone jacks dead
or are those USB head sets. we cant guess that either.
USB phones will cause chaos if not set up manually, ask.
3.5mm is child's play,
I own many 8540w, laptops.
all run W10 but I had to get the drivers to all dead chip from the chip maker, HP does not have them, because they dont support w10 here, nor do the security software work at all ever, there.
and more, the speaker control panel buttons are dead too...
until i fixed that panel, with a HP w7 force fed driver.
this pc came with XP ,vista or w7 , 32 and 64bit.
so what did you load, 32 or 64 bit, i cant guess that either.
so let me guess,
3.5mm dead, but not internal speakers,
so load this HP driver, off your official HP page.
its shows audio there see that, sp12345.exe
match the BITS (32/64) hint hint
IDT High-Definition (HD) Audio Driver
sp46721.exe (27.8 MB)
this driver is certified on w7 only.
so if it dont work then we go the chip makers site
for a newer driver,
it must be a 4 way match.
OS same
bits same
chip same
and driver to match.
in all cases.
full support here, at HP
link is 64bit. back up one page to get 32'
https://support.hp.com/us-en/drivers/selfservice/hp-elitebook-8440p-notebook-pc/4095872
Oct 21, 2017 | HP Computers & Internet
What driver for benq scanner 5000 model no 6678 9vi for windows 8 64 bit?
The BenQ 5000 Mirascan Scanner is no longer supported and does not have any 64-bit driver available. If the generic Windows 8 scanner driver doesn't work with it, then you will have to replace your scanner with a newer model.
Jul 19, 2014 | Office Equipment & Supplies
Windows 7/64 doesn't list my printer
The cd only has the drivers that were available when the printer shipped. You download the latest one here:
https://www.kyoceradocumentsolutions.eu/index/service/dlc.false.driver.FS1100._.EN.html#WIN7
And yes, it does have drivers for both 32 and 64 bit Windows 7
Apr 01, 2017 | Kyocera Mita FS 1000+N Laser Printer
I need Driver for Tevion USB PC web Camera SN9C103 for OS Windows 7 (64-bit)
Mar 30, 2010 | Gateway Computers & Internet
Trying to install Nikon Super Coolscan 5000 ED, for some reason the installation disc doesn't have the LS-5000 ED driver software...? I am running Win Vista. Any ideas?
I do not believe Nikon made drivers specifically for Vista, but you can use the solution here to make your own driver "inf" file and install some that will work anyway. Please read this and carefully follow the directions. If you are using 32 bit, use the 32 bit drivers. If 64 bit, then 64 bit drivers, when creating the new inf.
Bryan Clark
DVD Your Memories
Slide Scanning Specialists
Nov 16, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
jasbo
jasbo
