Question about Clarion SIR-CL1 SIRIUS Radio Receiver
Power cord receptacle on radio has disconnected...
The power cord won't plug into the radio anymore, because the place where the plug goes has become loose and has disconnected. In order to fix it, the radio has to be opened, but I'm not sure how to get it fixed. Any suggestions?
  • 43 Answers
Replace the connector for the power. Requires desoldering loose connector and soldering new connector not recomended for hte DIY
Posted on Jul 25, 2009
  • Mike Johnson Jul 25, 2009
    replace the connector for the power. Requires desoldering loose connector and soldering new connector not recomended for hte DIY
RE: Friedrich SL28N30B Has Faulty LCDI cord ( will not set -reset ). When plug in blue power light comes on then goes out. Cut cord and installed standard 3 prong male Plug end. Same results- power...
It could be that the faulty cord burned your built in gfi internal switch must like a gfi breaker that gets burn off and never resets . Replacing the cord as you did is a smart move since I would never place an appliance on a gfi receptacle .
May 26, 2014 | Dryers
Tip
Installing a 220 VAC Appliance Cord
This advice is on how to correctly install an ELECTRIC DRYER or ELECTRIC RANGE 220-240VAC power cord (US Standards).
3-Prong or 4-Prong – The Difference:
3-prong color code:
BLACK (HOT – 110-120VAC) – May also be referred to as L1
RED (HOT – 110-120VAC) – May also be referred to as L2
WHITE (NEUTRAL – 0VAC) – Usually grounded to the equipment frame via a jumper wire or metal strap.
4-prong color code:
WHITE (NEUTRAL – 0VAC) – DO NOT ground to equipment frame.
GREEN (GROUND) – Attach to equipment frame.
Which One to Use: According to the National Electrical Code (NEC), Article 250, installations after the year 2000, require the use of a 4-prong plug which incorporates a separate ground and neutral wire. If you currently have a home that uses the 3-prong receptacle and cord, you can continue to use it. You will have to upgrade to a 4-prong configuration, however, if you plan on relocating your current receptacle, or if the internal wires of the receptacle become damaged in any way and require repair.
Converting from 3-prong to 4-prong: Make sure you UNPLUG the appliance prior to any repairs. CAUTION: Voltages dangerous to life are still present even with the appliance turned off and still plugged in. Notably in the area of the terminal block where the power cords are installed. You will need to remove the old cord by following these steps:
  1. With the appliance UNPLUGGED, remove the access panel on the back of the unit where the power cord enters.
  2. With the cover removed, you will see a terminal block where the power cord is attached. The terminal wires will be colored with the WHITE wire in the middle, and the BLACK and RED wires on either end. NOTE: There should be a green jumper wire or metal bonding strap attached to the NEUTRAL (white) terminal wire.
  3. Remove the terminal lugs holding the old power cord wires in place. CAUTION: Use care not to drop any nuts or screws inside the appliance.
  4. Remove the bonding strap or ground wire from the Neutral terminal lug. NOTE: If disconnecting a ground wire, make sure you re-attach it to the appliance frame.
  5. Loosen the screws on the strain relief connector that holds the power cord in place and remove old power cord. NOTE: If your appliance does not have a strain relief that clamps down and hold the power cord in place, it is highly recommended that you install one. This prevents chaffing of the power cord against the appliance casing, and prevents the terminal wires from being pulled and broken loose. This could pose a potential shock hazard or cause damage to the appliance.
  6. Install new power cord by threading it through the strain relief connector and tighten down the screws.
  7. Connect the new power cord to the corresponding colors at the terminal block (Black goes to Black, Red goes to Red, White goes to White). The difference is going to be a Green (ground) wire that will connect to the appliance frame. There’s usually a green grounding screw for this. NOTE: If you disconnected a green grounding strap in Step 4., you can connect these two wires at the same point.
  8. Re-install access cover. Turn off the service breaker to the appliance PRIOR to plugging it back in. With the breaker in the off position, plug the appliance in, and THEN turn the breaker on. In the event, something was wired incorrectly, it is far better to have your hands away from the receptacle and controlled from a distance. Safety first.
These steps will work for nearly all appliances that require a 220-240VAC power cord conversion. The power cords are usually rated at 250VAC, 30 amps, and are carried by any hardware store or appliance parts retailer.
ADDITIONAL NOTES:
  1. If you desire to convert an appliance from a 4-prong to a 3-prong, make sure you reconnect the bonding strap and/or ground wire to the Neutral (white) wire at the terminal block.
  2. On some newer appliances, it is REQUIRED that you use a 4-prong plug in order for the timer or clock circuits to function properly due to the way they are configured. Refer to your owner’s manual for the correct recommendation. Even if you currently have a 3-prong receptacle, you still may be required to upgrade to a 4-prong if you encounter this situation.
  3. In many circumstances, new appliances are NOT sold with the power cord due to the various power configurations in homes. Always refer to the contents description on the shipping container the appliance comes with to see what additional items or tools may be required for installation.
I hope this information is found to be helpful.
on Dec 04, 2009 | Dryers
Tip
3-prong to 4-prong Power Cord Conversion.
3-prong color code:
4-prong color code:
on Jul 16, 2008 | Whirlpool LER5636P Electric Dryer
I need a replacement power cord for the 3 wheel Revo scooter. Where can I get one?
The AC power cord is a standard cord used on computers and a number of other electronic devices. They can be purchased at any Radio Shack for about $9. If you have the old cord, bring it with you to match up for the new one. If you don't have the old one, draw a picture of the cord receptacle and bring it to the store. I describe the wall side as a three prong grounded plug and the Revo side of the cord or charger side as a trapezoid shape receptacle. See the link to Radio Shack for the complete picture:
http://www.radioshack.com/product/index.jsp?productId=3875423
Hope this helps.
Mar 19, 2011 | Pride Mobility Products Victory 9 Scooter...
HP a820n No Power-up after City Power Failure
You have a bad power supply. It is not an expensive fix. Remember HP's take HP power supplies. When ordering either look on ebay for your model or order from part supplier.
Aug 22, 2009 | HP Pavilion A820n (PP165AA) PC Desktop
Switching to a 3 wire plug from a 4 wire plug for maytag dryer. what do i do with green ground screw
3-prong color code:
4-prong color code:
ADDITIONAL NOTES:
Aug 03, 2009 | Maytag Dryers
Wont start till I pull on the cord to make connection.checked cord with volt meter,its o.k.help. stampvs@yahoo.com
If you have unplugged the unit and performed a continuity (resistance) check from the end of the power cord to where it connects to the terminal block at the back of the appliance, then the next logical step is to perform a voltage check of the wall receptacle itself. If the voltage at the receptacle is good, but you are having connectivity issues with the appliance plugged in, the receptacle terminals may have become loose, or you may have a power cord that has a loose or broken wire. This intermittent connectivity can cause the receptacle and/or power cord to heat up and cause a fire. With the appliance unplugged, connect an ohmmeter to either end of the power cord and perform a continuity check. Move the power cord to see if the readings are constant. If you have intermittent resistance readings, you have a bad power cord. If the power cord still checks good, then I would recommend having an electrician check your wall receptacle before using the appliance again. If you still have questions, let me know. I hope this helps you.
Jun 19, 2009 | Frigidaire Electric Dryer
How do I change from a 4 prong wire to a 3 prong wire on a kenmore h34t washer
3-prong color code:
4-prong color code:
ADDITIONAL NOTES:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 31, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I need to replace the 4 cord dryer plug that is currently on my dryer with a 3 cord plug because the plug that is in place has 3 receptacles. the replacement 3 prong plug that i bought is not color coded....
lay the cord down flat the center lead of the cord goes to the center screw of the terminal block, connect the left lead to the left tern=minal and the right lead to the right terminal
Apr 11, 2008 | Dryers
Power cord contact loose
You can use tinfoil on the inside of the female connector. this will basically allow it to be conductive. The best solution is to go radio shack and get another plug and soder it in place but this can be a little tricky. So see if the tin foil will work for you.
Jan 14, 2008 | Garmin StreetPilot 2610 GPS Receiver
Clarion SIR-CL1 SIRIUS Radio Receiver Logo
Top Clarion Audio Players & Recorders Experts
John
John
xxxxxx xxx
 Mikey
Mikey
Are you a Clarion Audio Player and Recorder Expert? Answer questions, earn points and help others
