Question about Tascam Audio Players & Recorders
How do I switch from stereo to mono on my tascam dp02
SOURCE: tascam dp02
hi, might need your services in the future so i will save your site cheers . here is the fix which i found on a tascam forum ( press track edit and arrow up) this re instates factory settings . after i did that the (record) light and (play )light worked although there was no sound thru my h/phones when i recorded aaaagggghhhh switched off the unit fed up. the following day when i switched the unit back on every thing was ok .maybe it required to be shut down?? a bit like a pc, for all the corrections to be installed who knows it must be said that i am a technical buffoon i prefer hitting big rocks with big hammers ,this foray into high tech numbs my brain instantly and leaves me with a twitch .william
Posted on Jul 21, 2008
SOURCE: TASCAM DP02 CF
Try a seperate mike pre-amp, solved my problem. The output of both my dynamic and condenser mikes was too weak for the built-in pre amps in the DP02. Seperate pre-amps are also quieter than the DP pre-amps Turn the seperate pre-amps up first, then use minimal DP02 pre-amp. Good luck
Posted on Aug 29, 2008
  • 16 Answers
SOURCE: Akai LCT2070 Stereo Sound
This tv is kind of got a mind of its own the only time you can adjust it on mine is on cable that comes in stereo actually it usually switches by itsself after it reads the broadcasted sound. Hope this helps.
Posted on Sep 24, 2008
  • 189 Answers
SOURCE: For Tascam DP02 can't record and listen
Assuming your PA is a Yamaha STAGEPAS (although I thought 500 watts per side was the biggest one you could get). Anyway, on your PA's panel you will have the karaoke machine(s) plugged into the CD ins (top of the panel), while closer to the bottom you'll see the 'monitor outs' L and R 1/4 inch jacks. These are where you'd run the L and R from the PA into your Tascam (or L alone for mono out). The monitor outs are line level and are good for independently powered speakers, recording equipment, mixers etc. Just avoid using any outputs labelled 'speakers'.
bd.
Posted on Oct 29, 2008
  • 189 Answers
SOURCE: load imported songs on tascam dp02 cf
Make sure you have the song loaded first. In this case it sounds like you are importing into a new song, so make sure that you have a new song created and loaded prior to importing.
Then go to the menu by pressing the 'MENU' sutton and from there select 'WAVE' and then 'IMPORT TRACK'. You'll see the list of wav files on the fat partition of the CF media displayed. Select the wav file with your beat track on it (use the DATA DIAL or up/down arrow buttons to highlight the right wav file) and press the 'YES/ENTER' button. You'll be prompted for the track to import into. Select Track01 and press the 'Yes/Enter' button again and the WAV file will be read and inported into track 1.
Please note that the wav file should be a 44.1 kHz, 16-bit and a mono wav before trying to import it. If the beat track was created as a stereo wav you'll have to go into a wav editor like Audacity and resave the file as a mono wav file first. Also for a wav with a bit rate higher than 16-bit, the DP-02 is going to truncate the bits rather than dither and this might effect quality adversly so you might want to make sure that the file is properly saved as 16-bit prior to attempting an import to avoid this.
Hope this helps.
bd.
Posted on Jan 12, 2009
I am only hearing audio out of my left headphone speaker when plugged into the Tascam US-122. how can I play back my tracks and have the audio fill both speakers?
you might be using a mono output jack or input jack.....check the jack end...1 ring = mono / 2 rings = stereo
make sure your sending a stereo signal in, then check the L/R balance.
Jul 06, 2011 | Tascam US122 Audio/MIDI Interface with...
I have a Tascam DP-02 8-track all-in-one digital recorder. I've successfully armed and recorded Ch's 1 and 2 to input A and saved the session. When I loaded the session the next day to resume the project,...
i had a look for u on the net only the small yellow ones light up but ill get back to you about the other question as soon as i find a ansew wont be long thanks from chris
Sep 14, 2008 | Tascam DP01 All-In-One Recording Package...
Problem importing files to Tascam DP02-cf
They don't mention in the manual that in addition to being 44.4khz, 16bit, mono, the wav file also has to be at a bit rate of 705kbps. Using Audacity (freeware) you can convert most any audio file into the necessary wav format for the DP-02cf to use.
Jan 24, 2009 | Tascam 2488 Portastudio Multitrack...
Dp02 recording music(from stero)
Sounds like you are using the DP-02's 'stereo mix' inputs here. If so, the signal input from those is only routed to the line out and headphone jacks and cannot be recorded using the DP-02.
To record from a stereo you need to take the left and right aux outs (or some other line out - like the tape outs) from the stereo and put them into the main A and B mic/line inputs on far right of the DP-02's back panel. Then assign them to two respective tracks and you can record the stereo output to the DP-02. Just make sure you use a line level output from the stereo as the amplified speaker output can overpower and damage the inputs on the DP-02. You might need a couple of rca to 1/4 inch adapters to accomplish this.
Hope this helps.
bd.
Jan 14, 2009 | Tascam DP01 All-In-One Recording Package...
Load imported songs on tascam dp02 cf
Hope this helps.
bd.
Jan 10, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam DP-02 cd player...
You cannot rip a CD directly into the DP-02 using the unit's CD drive.
Your choices for doing what you want are:
1.) Rip the CD into .wav files onto your PC using ripper of your choice. Then you'll have to edit the resulting .wav file using a program like 'Audacity' (which is a free one) and convert the stereo wav files into 2 mono wav files. You'll have to save the mono files with dos 8.3 filenames and then import them into the DP02 using the instructions for importing wav files in the manual. To preserve the stereo, import each mono wav file to a separate adjacent track on the DP02 and then pan one left and one right.
2.) You could play the CD on a stereo and connect the stereo outs to the two inputs on the DP02 to record the CD track. You'll need patch cords which are RCA (mini phono 1/8" jack) to regular phono (1/4") to do this.
Cheers,
bd.
Nov 09, 2008 | Tascam DP01 All-In-One Recording Package...
bd.
Oct 25, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam us 144
Stereo requires two different inputs, as the very name implies. If you're using just one mic, it is possible to "pan" that input to both left and right, but is not truly stereo. For true stereo, you must have at least 2 mics, or 2 or more of any other sources...accordianman
Feb 22, 2008 | Tascam US-144 Sound Card
26 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
