Question about Food Mixers
When a bowler releases his bowl can he follow bowl down and stand and watch till it stops what is the ruling on this
  • 18,271 Answers
Cricket, Lawn Bowls, or Ten Pin Bowling? Just Google it
Bowling Rules of ?????
Posted on Apr 30, 2017
Get the bowl to release from the stand
The only way to unstick it is with more energy. Get someone to hold the motor unit firmly and someone else turn the bowl anti clockwise. There is no magic if it's stuck, just more effort required.
Feb 20, 2015 | KitchenAid K45SS Classic Stand Mixer
How do i adjust the bowl height on an ksmc5os?
I'm not familiar with your model but on stand mixers with crank handle bowl lift there are 2 places for it to be. With bowl lift down there can be s screw straight in from the front on the pedestal just above the bowl lift sliding bracket, the full range of adjustment is half a turn, anti clockwise to raise, clockwise to lower. The other one is a small screw sticking down from under the gear case where the bracket that carries trhe bowl slides up and down. Clockwise to lower, anti clockwise to raise.
Aug 19, 2014 | KitchenAid KSMC50S Commercial Stand Mixer
Kitchen Aid Classic Stand Mixer beater stops when it touches anything.
Very much the symptom of a worm (follower) gear needing replacement. Three are videos of this posted on the net and you can find the Service Manual at:
Jun 09, 2013 | KitchenAid K45SS Classic Stand Mixer
Wobbling on inside of mixer when beater is rotating
If the beaters are hitting the bottom of the bowl, try adjusting the upper-head stop-screw located near the top of the lower stand--it determines how far the head drops down and therefore, the height of the beaters above the bowl bottom. Hope this helps!
Dec 27, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
The top of the mixer began shaking and thumping when running, I realized the tilt head is pressed forward a little too far, causing the basic mixing attachment to press too far down into the bowl, maybe by...
Tip the machine upside down on a towel, centralise the hinge pin and tighten the grub screw that locks it into place. This is right up inside the pedestal, there is only one screw there to see.
Now stand it up and fit the mixing bowl & flat paddle, turn the machine on speed one, if the paddle is tinging on the bowl then we now need to set the head height. Turn the motor off.
Raise the motor up and from the front of the machine look in by where the motor hinges on the pedestal. You can see one screw head there. If it's tinging the bowl then you need to turn the screw anti clockwise enough so that the paddle no longer tings on the bowl.
Once it's stopped tinging put it onto max speed and make sure it still clears at high speed, if not turn the screw until it stops tinging. That's it.
Jan 02, 2018 | KitchenAid K45SS Classic Stand Mixer
I can't get the tilt release to release to raise the mixer . I have a batch of cookie dough in the bowl and I am unable to raise the mixer
Try running the mixer for a few seconds to clear anything out from under the beaters, like a chocolate chip. You can also try pushing down on the beater end of the mixer, press the button and lift.
Nov 01, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Hobart Mixer bowl won't go up
If the worm screw is turning but not lifting the bowl, the bowl lift nut is stripped.
H600 part number is 24198.
To change it, you need to undo the screws down the right side yoke slide to release the yoke. You will need to lift the yoke to reach some of them. If you have some wood place it under the yoke and over the legs to protect the paint. On top of the yoke are two blots holding the keeper plate over the nut. One is the stop screw for bowl height. Don't loose this setting. remove the slide, edge the yoke forward a bit to free the worm. Run the old nut down the worm and off the bottom. When you run the new nut on, all the excess grease and metal shavings will start to build up. Clean as you go, or better still, brush with solvent or similar to clean the worm threads . relubricate, run the nut up above the yoke, reload the yoke and attach keeper plate, reload slide.
To adjust slide, snug screw near bottom keeping slide close to yoke, run yoke to top and tighten top screw just enough to hold slide in place, lower yoke to bottom, gently tap top of slide in a 1/16" and tighten top screw. Run yoke to top of slide. It should start to bind slightly in the last 2 inches of travel, which will stop the bowl from dropping in use. Tighten remaining screws.
May 13, 2009 | Hobart H600 Stand Mixer
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
May 03, 2009 | KitchenAid K5AWH Stand Mixer
Bistro Staned Mixer;Mixing bowl is stuck(?) to base
You have to twist the bowl anti-clockwise to release it from the base. Twist clockwise to lock it when using the beaters.
Nov 23, 2008 | Wolfgang Puck Stand Mixer
Bowl cannot be removed from stand - stuck
Mine is stuck too and it's so annoying. I used terry cloth and hammer the bowl to knock the bowl down (1-2 times and not too hard). I think the bowl is up a bit and over locked when doing bread dough.
Feb 21, 2008 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
113 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
