Question about Vtech Lands Phones
My vtech cordless phone which is connected with internet and wireless to centurylink has no dial tone. Works fine at neighbor but not here. Internet and wifi working
SOURCE: Cordless phone 25881
Sounds like a power problem.
This model of phone will work as a regular corded phone when no ac power is available.
IE the cordless function is only available when you have electricity.
- is the ac adapter plugged into a working outlet.
- is the ac adapter working.
- is the ac adapter pluged into the base.
hope this helps
Posted on Jan 21, 2008
  • 21 Answers
SOURCE: Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Posted on Jan 26, 2008
  • 53 Answers
SOURCE: Laptop cannot connect to internet outside company domain using wifi at home
typically at home you don't need any proxy settings configured within internet explorer. often in a work environment proxy settings can be applied.
if you think thar you have access to modify the settings do the following;
right click the IE7 (same for IE6) icon on your desktop select properties and select internet properties on the dropdown list.
left click the "Connections" tab
left click the LAN Settings button
deselect all of the ticks (most importantly the Proxy server part)
left click OK
left click OK
then open up IE normally and see if this has worked.
note of caution though; if as you suspect group policy is pushing the settings, next time you logon to the company LAN your changes may be lost and you will need to remove the ticks again.
also if you still get no joy try leaving the Automatically detect settings ticked with the proxy part unticked.
Posted on Nov 06, 2008
SOURCE: I can't dial out from my handsets
Monotary suggested the following and it seems to be working for now.
"Disconnect or unplug the power supply (the small black box that is plugged into the wall outlet) wait for 30 seconds and then plug it in again. Sometimes the power supply needs to reset itself."
Posted on Feb 11, 2009
  • 95 Answers
SOURCE: My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
Posted on Mar 28, 2009
No calls in or out. I have internet connection. Why not phone?
if you have a land line for the phone system the internet uses the same wire as the phone but at different frequencies
the modem picks up this different frequency and so works the internet
the problem will be in the cable, cable socket or phone itself
pick up the hand piece and if you do not get a dial tone the it indicates that the phone unit is not making a circuit with the land line or the exchange to which it is connected ( different connections to internet) Try a neighbours phone connected to the wall socket and if that doesn't get a dial tone on that phone then contact the service provide and lodge a fault report for your phone
if it does then the problem will be in your unit, cables or socket connection.
May 22, 2015 | Vtech Lands Phones
My Vtech cs5121 cordless phone has no dial tone
Vtech phones are junk! I have had many trouble calls for no dial tone,only to find out the Vtech phone is the only one they have,and it is defective.(It really DOES pain me to bill someone 91 dollars to tell them their 21 dollar phone is broken-always try another(preferably hard-wired) phone before calling the phone company!
Dec 30, 2012 | Vtech 5.8GHz Cordless Phone with Digital...
How to prgram the vtech 5.8 dial tone to touch tone
Since you declined to specify the model of your VTech 5.8GHz phone, I can only suggest that you enter it into the search box here to download a copy of the manual. The manual will describe how to switch between pulse and tone dialing.
Mar 05, 2012 | Vtech 5.8GHz Analog Cordless Phone
No dial tone! what do i do??
with your main base plugged in you should have lights on it, this means your getting power, now check if your phone wire is plugged into your base all the way. If you pick up your phone and hit the center button it should light up the phone and read connecting, then give a dial tone. if not i would try another phone in that same wall jack and try. If another phone works fine and all your connections are good try replacing phone cord to base and try it. If still no good check that phone in cradle is hs1. handset no. 1 and try. hope this works
Jan 12, 2010 | Vtech 5.8GHz Cordless Phone with Digital...
No dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Sep 04, 2009 | Vtech Lands Phones
Dialing out
it's not sending a signal to the phone service check your phone lines for proper connection
Jun 22, 2009 | Vtech CS5121 Cordless Phone
No dial tone
did you try unplugging the phone for 10 min. and try that
otherwise it could be on the outside box
Feb 07, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Here is something to try:
Disconnect or unplug the power supply (the small black box that is plugged into the wall outlet) wait for 30 seconds and then plug it in again. Sometimes the power supply needs to reset itself. It worked for me.
Nov 06, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Lands Phones Logo
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
