Question about Brother Sewing Machines
Extra spool pin for Brother Super Ace Machine for twin sewing
  • Brother Master
  • 12,241 Answers
You can search for the part online:
Make Model spool pin
or, if you are creative, make your own. Some people put a small wooden dowel on a heavy base and just set it behind the machine. There are also stand-alone spool holders that you can purchase online.
Posted on Apr 30, 2017
Testimonial: "Thanks you. I have just ordered a stand-alone spool holder from China. You walk into the Brother shops here and they never have want you want always out of it. I prefer to buy on line but could not get a spool pin from China."
1250 embroidery machine how do you thread for a double needle?
Do you mean the Brother Innov-is 1250D embroidery machine? Insert your twin needle. Follow the normal directions for threading the upper thread and manually place this thread through the eye of the left-hand needle from front to back. For the right hand needle, insert the extra spool pin in the bobbin winder shaft. It gets put on perpendicular to the shaft. Swing down the spool pin so that it is horizontal, pointing towards the needle bar. Place another spool of thread on this spool pin and secure it with the appropriate-sized spool cap. The thread should come off the top front of the spool. Follow the threading directions for the upper thread from step 8 (the thread guide cover) through step 10. Do not run this second thread through the needle bar thread guide. Manually thread the right hand needle eye. Make sure to use the zig-zag foot with the twin needle.
The directions for threading the machine when the twin needle installed is on page 36-37 (pages 38-39 of the PDF) of the manual. The manual is available from Brother support on the product page: http://www.brother-usa.com/support/modelinfo.aspx?R3ModelID=NV1250D . The direct link to the manual is currently: http://www.brother-usa.com/VirData/Content/en-US/HAD/Consumer/UsersManual/UM_Innov_%c3%ads%201250D_EN_2825.PDF .
I hope this helps.
Apr 09, 2018 | Sewing Machines
I have a brother 6000i. How do I utilize the extra spool pin?? Where does it go ?
bAttach the extra spool pin.
Put the extra spool pin in the hole on the top of
the machine. Put the second spool of thread
onto the extra spool pin.
See page 25 in owners manual.
Feb 25, 2014 | Brother CS-6000i CS6000i 60-Stitch...
Twin needle
Hello
Install the second spool pin.
Place the two spools on the spools pins, one on each spool pin.Make sure that the spools are spinning toward each other.
Thread as for single needle.
Thread each needle from a different spool.
Caution: Make sure that the stitch width is not wide than the twin needle maximum swing. Check that the needles will not hit the throat plate as they swing from left to right and back again on stitches with width.
Happy twin needling
Sewingirl/
Jan 30, 2014 | Husqvarna Huskystar 207 Sewing Machine
Can you do a coverstitch on the Brother 634D serger
I don't think so, the D in your model name would denote that it has Differential feeding but is probably a 3/4 Marrowing stitch only. So this means it would do 3 thread overlock, 4 thread overlock and you can probably set it up for rolled hemming too.
Coverstitch is fairly new to home sergers and is available on some machines along with the 3 and 4 thread stitches, but changing between the regular overlock and a coverstitch takes a few minutes. The model number will usually have a "C" in the name. Also, during coverstitch the blades are disenaged and don't trim your fabric so you still need often to go back with blunt scissors and trim the raw edge.
And sewing coverstitch can be finicky, with skipped stitches a problem. Use high quality thread and XL (extra long) or SUX (stretch extra long) needles to avoid this.
However some manufacturers are now making dedicated coverstitch machines; if you are assembling a garment with your regular serger, you can then just move over to the coverstitch machine to sew the hems and necklines and not spend 20 mins changing over your machine's functions. Much more productive.
You may wish to check out the Brother 2340CV, this is their dedicated domestic coverstitch machine. Link to product info is http://www.brother-usa.com/homesewing/ModelDetail.aspx?ProductID=2340CV
In the meantime, best solution is a twin needle to stitch the hem from the right side of the garment on your regular sewing machine, looks much the same, and you can get twin needles with a 4mm or 2.2 mm gap and in stretch and sharp tips for less than $10 each. Just iron up the hem about 1.5cm deep, and thread up your sewing machine with the twin needle and two spools of same colour on top (I just wind an extra bobbin and use this plus the original thread spool rather than buy two spools).
Just sew really slow as the twin needle builds up a lot of heat and will break if you push it along. I use this finish on all my knit garments and it works just fine. Sometimes I'll iron in a 2cm strip of fusible web inside the hem to give it some firmness in a neckline, then twin needle stitch at about 1.7 from the folded edge.
Hope this answers your question.
Oct 23, 2011 | Janome MyLock 634D Mechanical Sewing...
Can't seem to thread the machine properly so's I can use twin needle and pin tuck foot. Keeps de-activating the machine, so obviously not threading it properly, but can't understand the instruction book.
when you insert the twin needles, & add the 2nd spool of thread,, you just thread the machine the same way as with a single needle,,
that's what I do & it works just fine
Nov 04, 2010 | Brother InnovIs 4000D Computerized Sewing...
Brothers sewing machine ls 1520 what all parts came with this machine.did it come with a button hole foot
I hope this is your machine, check it out
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1520_EN_270.PDF
ACCESSORIES
1 Buttonhole foot (1 pc.)
2 Zipper foot (1 pc.)
3 Button sewing Foot (1 pc.)
4 Needle set (regular single needle No. 14) (3 pcs.)
5 Twin needle (1 pc.)
6 Bobbins (3 pcs.)
7 Darning plate (1 pc.)
8 Screwdriver (1 pc.)
9 Extra spool pin (1 pc.)
Parts code for zigzag presser foot: 138135-051
Foot controller: X57319-051 (110/120V Area)
XA6422-021 (220/240V Area)
XA6412-021 (U.K.)
XA6414-021 (Australia, New Zealand)
The above accessories are stored in the accessory bag inside the
extension table. These accessories have been designed to help
complete most sewing tasks.
Aug 27, 2009 | Brother Sewing Machines
THREAD CARTRIDGE WONT LOCK IN PLACE
Hi - I'm sorry you have been waiting for an answer to your problem. Can you tell me whether this was first time you used the cartrige, or has it been working up until now? Unfortunately, the cartridges tend to break fairly easily.
To determine whether your cartridge is broken, take out the thread and thread it again. The cartridge won't lock-in unless your presser foot is up and your needle is raised to its hightest position (needle threaders are designed to prevent damage, so they often won't work if the parts of your machine are not positioned properly for threading).
If the cartidge still won't engage, check the page in your manual that describes the parts that came with your machine - you should see a picture of a spool pin. Although the spool pin is designed to accommodate spools of thread that don't fit in your cartrige, you can use the spool pin all the time. Your manual describes how to install the spool pin.
Fortunately, you can purchase spool pins and replacement cartridges from several online sources, including eBay, and some Babylock Dealers sell them (the Babylock and Brother cartidges are interchangeable). I have the same machine, and I always keep an extra cartridge around. I can thread the extra spool while the other is sewing. When the machine stops for a color change, I just insert the extra cartridge with the next color, then thread up the empty cartridge for the next color. Speeds up your embroidery alot.
On Google, type in Brother Thread Cassette - you'll get lots of hits, and you should be able to find a cartridge for about $10.00.
If you have and other readers have time to rate my answer (good or bad), your rating helps me determine whether I understand your problem.
If you have more details about your problem or have additional questions, please feel free to comment. I can send you the instructions for threading the cartridge and installing the spool pin if your manual is missing. Just submit a comment - and I'll help anyway I can.
Cheers, Ginny
Jan 18, 2009 | Brother Disney PE-400D Computerized Sewing...
Thread constantly wraps around spool pin
Cut a round curcle of fabric the size of the spool from a piece of felt. Put a hole in the middle and put it under the spool of thread. If this does not work you can purchase a small net that fits over the spool. It is designed to keep the thread from coming off the spool except for being pulled through naturally.
Hope this works.
Zelma
Jan 19, 2008 | Brother LS-2125 Mechanical Sewing Machine
Spool pin
Spool pin is usually on the top Right hand side of the machine. It is sometimes not clearly visible (it looks like a small metal rod protuding out, but not long enough to hold your thread). You will have to pull it up so that it extended and then you can use it.
Dec 27, 2007 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
