Black stuff coming out onto the wash even though filter has been cleaned and white vinegar has been flushed through the machine
SOURCE: Black stuff in washing machine
You need to clean the filter out (look in your machine - it's on the side of the tub) then run a wash with a cup of vinegar in it (or on soak with napisan or something like that in it). It's just gunk build up.
Posted on Feb 18, 2008
  • 261 Answers
SOURCE: excessive lint on clothes and smell
There is many solutions that work some. The best analogy I have seen is to reduce the wash time as the newer soaps are more efficient at removing dirt which also softens the fabric. Any excess in soap regardless of type in combination with water type will cause an odor, why is the contaminents in the water plus the junk on are clothes to be polite. It builds up under the basket and along the top water line in the tub plus creates a film from the tub through the hoses, pump and house drain. Lint is a product of excess washing and too much soap. Whirlpool stated for there front loaders no more than two TBL of liquid soap which is like 3/8 cup max for the old top loader. SearsTechToo
Posted on Oct 06, 2008
  • 720 Answers
SOURCE: I have a Samsung SW62ASP top load washing machine.
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution
Posted on Dec 03, 2009
  • 215 Answers
SOURCE: water coming out of drawer & door
Hi Gary,It sounds to me that you have a blockage within the pressure systemas this is a classic sign. If you take the top off the machine you will see a round switch with a few wires going to it.This is the pressure switch. at the bottom of this switch is a thin pipe,normally black or clear. there is a small spring clip holding this pipe to the switch, If you remove this pipe and gently blow down it you will probably find it is blocked. You will then need to follow this pipe to the bottom of your machine. At the bottom of the machine where this pipe is fitted you will see there is a chamber and it is this chamber likly to be blocked.Some times you may clear this with a small piece of wire by removing the small pipe and poke wire through, but best way is to see how this chamber is removed and remove it for cleaning.Ensure machine is off at mains. this chamber fills with water and causes air pressure within the switch at the top of machine, which in turn tells programe when machine is full and also when empty. If this fails then machine will not turn off water supply as long as it is on. there fore when you reconnect parts ensure they are tight and clips back in place. Good luck and hope this works. Failing this working you may need to call an engineer to check switch and possible fault on board.
Posted on Feb 13, 2010
  • 3463 Answers
SOURCE: Our Hotpoint WMA20 Washing machine
Filter is tbe found by removing lower rear cover of washer, and removing the large black hose fastened to bottom of drum, remove and clean plastic filter inside the hose.
Posted on Nov 29, 2010
Testimonial: "A service engineer dismantled the pump and found an elastic band entangled. It's useful for the future to know how to access the filter - many thanks."
We have a Franke Machine that has started running discolored/ foul smelling milk & water while making drinks. What can cause this?
needs the system cleaning, there are plenty of cleaners on the market or you can use a vinegar mix. this will clean out the system 3 parts vinegar to one part water and flush this though the system as you would normally use it, white vinegar would be best, leave for half an hour in the system and then flush out with water a few times till clear and no vinegar smell.
Dec 13, 2017 | Franke Coffee Makers & Espresso Machines
How do I clean the washer to eliminate the dark spots of lint and dirt on laundry?
Prevent lint from clinging to clothes by adding 1/2 cup white distilled vinegar to the wash cycle.
To remove soap residue that makes black clothes look dull use white distilled vinegar in your final rinse.Get stained white socks and dingy dishcloths white again. Add 1 cup white distilled vinegar to a large pot of water, bring it to a rolling boil and drop in the articles. Let soak overnight. Some stains on clothing and linens can be soaked out using equal parts milk and white distilled vinegar.Before washing a mustard stain, dab with white distilled vinegar.ttack spaghetti, barbecue, or ketchup stains with a white distilled vinegar and water solution.Remove perspiration odor and stains on clothing, as well as those left by deodorants, by spraying full-strength white distilled vinegar on underarm and collar areas before tossing them into the washing machine.Forgot that you left wet laundry in the machine and it now smells moldy? Pour a few cups of white distilled vinegar in the machine and wash the clothes in hot water. Then run a normal cycle with detergent.Remove smoky odors from clothes by filling the bathtub with very hot water and 1 cup white distilled vinegar. Hang the garments above the steaming water and shut the door so the steam can penetrate the fibers.Keep the steam iron clean and in good working order by getting rid of mineral deposits in steam vents and spray nozzles. Fill the water chamber with a solution of equal parts white distilled vinegar and distilled water. Set it in an upright position and let it steam for about 5 minutes. When the iron is cool, rinse the tank with water, refill and shake water through the vents onto an old cloth. Test before using.Remove scorch marks from an iron by rubbing it with a warmed-up solution of equal parts white distilled vinegar and salt. If that doesn't work, use a cloth dampened with full-strength white distilled vinegar.Remove musky smells from cotton clothes by sprinkling them lightly with white distilled vinegar and then pressing them.Get water and salt stains off shoes and boots by wiping them down with a solution of equal parts white distilled vinegar and water.Give patent leather shoes and bags a better shine by wiping them down with white distilled vinegar.Get cleaner laundry! Add about 1/4 cup white distilled vinegar to the last rinse. The acid in white distilled vinegar is too mild to harm fabrics, yet strong enough to dissolve the alkalies in soaps and detergents. Besides removing soap, white distilled vinegar prevents yellowing, acts as a fabric softener and static cling reducer, and attacks mold and mildew.Eliminate manufacturing chemicals from new clothes by adding 1/2 cup white distilled vinegar to the water.Remove soap **** and clean the hoses of your washing machine with white distilled vinegar. Periodically run the machine with only a cup of white distilled vinegar in it-nothing else added to the wash cycle.Bring out bright colors by adding 1/2 cup white distilled vinegar to the rinse cycle.Fluff up wool or acrylic sweaters (hand- or machine-washed) and rid them of soap smell with 1/2 cup white distilled vinegar in the last rinse water.
Get rid of the tiny holes left along the hemline when you take out the hem of any garment by moistening a cloth with white distilled vinegar, placing it under the fabric and ironing.
Oct 31, 2011 | Whirlpool Washing Machines
When I drain the pump filter, there are thin black flakes in the water, and sometimes the water is even black. The repairman says that this is normal and comes from the inside of the machine. I use...
No matter how clean you keep your machine, what you describe is totally normal. The colour and types of deposit will vary according to your own local water supply and the chemicals you use, as well as how often the machine is used and how soiled the loads are. Don't make the common mistake of attributing the colour of the deposits to dirt though, for example they could just as well be sulphate deposits from your use of acid (vinegar) or even a bacterial bio-film (very common, often black, pink or yellow) and the latter are not a sign of poor care.
As long as the laundry comes out clean and fresh then there is no problem at all.
Jun 30, 2011 | Washing Machines
I have a two month KEURIG Platinum 10 cup coffee maker. I used filtered water from my frig, soon discovered white flakes swimming in it. Today mysystem said De Scale, will notadmit water from...
Try passing a fine wire back up through the water inlet that punctures the K cups. Drain most of the water from the reservoir and add white vinegar. If necessary, add enough water to clear the low level light on the panel. Hit the start button, and collect a cup of whatever comes out. Either filter the water and re-use or dump out. Continue using the white vinegar, letting it work in the reservoir and internal pot for ~10 minutes between cycles (cups). It will take at least one hour to clean it out and flush it well. Once you are making a cup's worth of water at normal speed and time, dump the reservoir on the side, and refill with clean water. If the reservoir has a bit of a slimy feel inside it, wash it thoroughly before re-installing. (You should wash the reservoir probably weekly, or so, depending on you water).
Flush clean water through the system, dumping each cup produced, until all traces of the vinegar are removed.
Best regards,
Jan 17, 2011 | Keurig B100 Coffee Maker
Remove lowwer rrear panel. locate and remove the large black hose fastened to bottom of drum, there should be a plastic filter inside the hose, if not, then filter is located at bottom front right of washer behind cover.
Sep 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
GWL15 Model musty odor
You need to clean your filters and pump out, after which, you need to flush the system with white vinegar and water 50:50 make up a bucket of solution, and after cleaning all the lines pump, and filters, put the solution in the bowl, and run the short cycle to push the water through, this should help. You need to wash all parts in same type solution or bleach.
Jul 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
How do I clean the esprsso tank?
Commercial descalers like CLR are about the worst thing you can use on equipment used to prepare foods. I would suggest nothing but food grade white vinegar.
Put it through a brew several times with white vinegar and let it sit for several hours. Come back later and give it a good flush with filtered or distilled water.
Jan 22, 2010 | Krups Caffe Duomo 985-42 Espresso & Coffee...
Seems to be clogged.Is there anyway to flush or
Try putting white vinegar in it, and letting it soak. For more cleaning, you can recirculate the white vinegar back through the machine, but strain it through a coffee filter first to remove any sediment that you break free. Once you're satisfied with your cleaning, flush the tea maker with pots of fresh water, until no vinegar can be detected by taste or smell.
Best regards, --W/D--
Aug 04, 2009 | Bunn Iced Tea Maker 3 Gallon Tall w Ready...
Jan 28, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
