Question about Hardware & Accessories
Hello, I have the power comb and marking L L N PG can you please advise where the 240 connects to? Which two terminals connect to?
huuum
  • 750 Answers
SOURCE: kenmore Model 94812 Electric laundry center
Hello handicapper,
Welcome to fixya.
You said, the above unit is new and has no separate power cord for the washer unit. Does the power come from one side of the 240 volt cord that attaches to the dryer connection?? Please advise,thank you.
Yes you are correct.
The on cord services both washer and dryer in your laundry center!
Do you have it running yet!
You should have no problem it comes with installation instructions.
If you need the user guide you can find it here online!
http://www.managemyhome.com/mmh/lis_pdf/INSTL/L0710024.pdf
If you have any more questions just ask.
Let me know that you are up and running.
Please remember to leave me the best rating.
Thank You Huuum
Posted on Oct 10, 2008
CarlGehrke
  • 169 Answers
SOURCE: Power Generator
You have a brushless generator and you've already checked the capacitor that does the voltage regulation (wiring is fine).
The next thing to look at are the diodes, movs, and wires in the rotor.
Carl
Posted on Dec 03, 2008
  • 30 Answers
SOURCE: need to connect 240 volt 60 amp breaker with 6.3 - 4 wire
Yes the red and black wires are both hot. As for the white and bare wire, they can both go on the neutral bus bar because ground and neutral are not separated. Actually you don't have to have the bare ground wire, but it is a good idea to connect it for inspection and code purposes. If you don't have a neutral bar in the subpanel, you can just connect the white and bare wires directly to the box and they will be ok.
Posted on Aug 13, 2009
  • 2468 Answers
SOURCE: I forgot to mark the wires that connect to the
it doesn't matter,it's a.c. current and theres only 2 wires on either the element or the fuse so it won't matter
Posted on Mar 04, 2011
  • 8404 Answers
SOURCE: How do I connect charger
Red attaches to the POS or the + termnal. The Black clamp can attach to the NEG or the - terminal on the battery ... or any part of the engine. Assure the charger is in the off position when you connect. Assure it is on the Charge position if you are charging the battery. If you are trying to start the car, put the charger on the START position and let it sit on the battery for 30 seconds before you try to start it. The best way to get your car going is allow the charger to charge the battery on CHARGE setting for an hour or more first.
Incidently, I have a charger exactly like yours ...
Thanks for your qeustion @ FixYa.com
Posted on Sep 19, 2011
Dryer won't start
Hello;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number, so I am going to have to advise in general.
If you have no power especially the light not coming on then you have a blown thermal fuse. Usually they are in the back. Sometimes the are internal.
Following are pictures of what you might have:
24082258-tf0pl124dzd5m1czyqgpxhkh-4-0.jpg 24082258-tf0pl124dzd5m1czyqgpxhkh-4-3.jpg 24082258-tf0pl124dzd5m1czyqgpxhkh-4-8.jpg
Apr 11, 2014 | Frigidaire Electric Dryer
Tip
How to wire Intermatic T103 and T104 timers
These instructions are for USA residential wiring only.
VERY IMPORTANT: Understand that in US residential wiring the WHITE wire is _NOT_ ALWAYS_ the neutral wire. Additionally, prior to 1999 the National Electric Code (NEC) did not require that these white wires be re-identified with black tape or similar means when used for purposes other than neutral. The white wire is sometimes used as a hot, especially when wiring Intermatic T103 and T104 timers.
Also understand that the WHITE neutral wire and the bare (or green) equipment grounding wire are connected together ONLY at the main electric power panel and must _never_be connected together _again_. Once those two wires leave the main electric panel, the WHITE neutral wire must _always_ remain insulated from the bare or green equipment grounding wire. This is very important for safety considerations.
If your wiring is very old and does not have a bare equipment grounding conductor, you _must_ protect the circuit with a GFCI (Ground Fault Circuit Interupter). GFCI wiring is not difficult but is beyond the scope of this post.
DETERMINE WHAT CABLE YOU HAVE:
Usually one will find one of the three following scenarios for the incoming supply cables when wiring a T103 or T104 Intermatic timer:
1...A 120 volt cable with 3 wires: black, white, and bare. The black is LINE (hot), white is neutral and bare is equipment grounding. Black to white is 120 volts. This scenario can be used with the T103, but not the T104.
2...A 240 volt cable with 3 wires: black, white, and bare. The black is LINE(hot), the WHITE is LINE (HOT), and the bare is equipment grounding. Black to white is 240 volts. This scenario is used with the T104 ONLY.
3...A 120/240 volt cable with 4 wires: Black, red, white, and bare. The black and red are (LINE) hot, white is neutral and bare is equipment grounding. Black to red is 240 volts. Black to white is 120 volts. Red to white is 120 volts. This scenario can be used with either the T103 or the T104.
The only difference between the T103 and the T104 is the timer motor voltage rating. The T103 uses a 120 volt timer motor and the T104 uses a 240 volt timer motor. The T103 timer motor is connected to terminal "A" and terminal #3 during manufacturing. The T104 timer motor is connected to terminal #1 and terminal 3# at the factory.
Also, when connecting the bare or green wires to the "GR" terminal, it is best to wirenut the wires together with a pigtail, then connect the pigtail to the "GR" (GRound) terminal, WHICH IS THE GREEN SCREW ON THE LOWER PART OF THE CASE.
WIRING THE TIMER:
The wiring diagram for the T103 is here:
http://www.progressive-growth.com/wiring/T103.pdf
___________________________________________________________________
WIRING THE T103 USING AN INCOMING 120/240 VOLT CABLE WITH 4 WIRES (scenario #3):
Incoming (LINE) wires from 240 volt circuit breaker:
Connect the black (LINE)(hot) wire to terminal #1. Connect the red (LINE) (hot) wire to terminal #3. Connect the white (neutral in this case) wire to terminal "A".
Connect the bare equipment grounding wire to the "GR" terminal, which is the green screw on the case.
Outgoing wires to 240 volt load:
Connect one (hot) wire to terminal #2 and the other (hot) wire to terminal #4. The bare or green wire goes to the "GR" terminal.
WIRING THE T103 USING AN INCOMING _120_ VOLT CABLE WITH 3 WIRES (scenario #1):
Incoming wires from 120 volt breaker or source:
Black (LINE) to terminal #3. White (neutral) to terminal "A". Bare to the "GR" terminal.
Terminals #1 and #2 are NOT used in this case.
Outgoing wires to 120 volt load(s):
Black(hot) to terminal #4. White(neutral) to terminal "A". Bare to the "GR" terminal.
The wiring diagram for the T104 is here:
http://www.progressive-growth.com/wiring/T104.pdf
WIRING THE T104 USING AN INCOMING 240 VOLT CABLE WITH 3 WIRES (scenario #2):
Incoming (LINE) wires from breaker:
Connect the black (LINE) (hot) wire to terminal #1. Connect the white (LINE) (hot in this case) to terminal #3. Connect the bare wire to the "GR" terminal.
The "A" terminal is _NOT_ used.
Outgoing wires to load:
Connect one (hot) wire to terminal #2 and the other (hot) wire to terminal #4. Connect the bare or green wire to terminal "GR".
WIRING THE T104 USING AN INCOMING 240 VOLT CABLE WITH 4 WIRES:
Same as above, except the white wire is not used. Just tape or wirenut it off.
on Dec 28, 2009 | Hardware & Accessories
1980 P-30 chevy wiring schematic for horn
Locate horn relay(under dash)
3 wire connection--terminals are marked 28, 29, and 240
28=Black Wire- to horn ring (colomn)
29= DK Green Wire- to horn(s)
240= ORANGE Wire- to B+
Dec 07, 2013 | Vehicle Parts & Accessories
How to wire 240/15/1
240 VAC single phase 15 amp. Newer code requires a 4 terminal plug. Ground is now seperate from the neutral/return. 12 gauge wire should be acceptable for up to 8 feet, 10 would be better and better for a bit longer run- reduces voltage drop and current draw slightly.
On the motor itself, it should have the terminal connections marked on the motor or on the cover plate.
in general the "hot" pair connect across the hot terminals of the motor. and the ground goes to frame of motor. There should be a terminal location for "white" which would be "floating" if the motor is convertible 120/240.
Black +Black or Black +Red depending how the space was wired, it in most cases does not matter which of the two motor connections the hots are connected to on single phase unless explicity denoted on motor. this is rare. Three phase it matters for direction.
Jan 22, 2012 | Air Tools & Compressors
How to wire GM40 timer to 240vac
This connection is for 240 volts ONLY on the Intermatic GM40.
The first thing you need to do is make sure the Input Voltage Dip Switch (IVDS) is set correctly for 240 volts. The IVDS switch is located to the left of the terminal strip and just slightly above it. 4 is set to OFF, 3 is set to ON, 2 is set to OFF, and 1 is set to ON.
The first wire of the incoming (LINE) 240 volt cable (pick one) is connected to "L1" (the 1st terminal screw on the left). Also jumper a wire from "L1" to COM (the 5th terminal screw from the left).
The second wire of the incoming 240 volts is connected to "L2/N" (the 2nd terminal screw from the left). Also connect one of the wires (pick one) from the outgoing (LOAD) 240 volt cable to the "L2/N" terminal.
Connect the second wire of the outgoing 240 volts to the "NO" terminal (the 4th terminal screw from the left).
If you not sure which cable is which, turn OFF the circuit breaker suppying the timer, separate all the wires, turn the circuit breaker back ON. The cable that is hot is the incoming (LINE). Turn breaker back OFF and wire as above.
Dec 01, 2011 | Intermatic GM40 - 24 Hour/7-Day Dial...
Hi expert: I am installing intermatic P1353me digital pool or spa mechanism and having trouble to figure out how to do this heater Firemen Switch connection. My existing pool timer is T104 and there were...
1) Fireman's switch automatically turns off heater few minutes before turning off pump.
Not all pool timers have fireman's switch.
If old timer did not have it, then don't worry about it.
P1353 has wires marked for fireman's switch, so simply don't use them if you don't want to.
http://waterheatertimer.org/pdf/Intermatic-P1353-manual.pdf
page 21 of manual shows wiring for fireman's switch.
2) T104 and P1353 comparison
Difference 1: T104 turns OFF both hot wires, while P1353 turns Off 1 hot wire.
http://waterheatertimer.org/Compare-120-and-240.html
Difference 2: T104 controls 1 240V load with 1 time schedule, while P1353 controls 3 different 240V loads, each with different time schedule.
Check that wire(s) coming from breaker can handle all 3 loads.
http://waterheatertimer.org/Color-codewire.html
3) 240Volt T104 is wired as follows:
http://waterheatertimer.org/images/T-104-240-Volt-400.jpg
Hot1 from breaker connects to T104 terminal 1
Hot2 from breaker connects to T104 terminal 3
There is constant power on terminals 1 and 3, each terminal has 120V when combined makes the 240V circuit.
Load1 wire connects to T104 terminal 2
Load2 wire connects to T104 terminal 4
Terminals 2 and 4 have power whenever timer turns ON
4) Definition:
In electric wiring, Line means power from breaker, and Load means wire going to light,fan, motor, pump.
5) Converting T104 to P1353
http://waterheatertimer.org/images/P1353-timer-350.jpg
http://waterheatertimer.org/images/P1353-terminals-566.jpg
Hot1 from breaker connects to P1353 terminal 1
Hot2 from breaker connects to P1353 terminal 2
This will power timer electronics and timer clock and switches.
Jumper wire is placed from Hot1 at terminal 1 to each Line terminals 3 5 and 7.
This will put power at the switch, and when switch turns ON, then power will flow from Line wires to Load wires and then on to the Load.
Load 1 connects to terminal 4, Load 2 connects to terminal 6, Load 3 connects to terminal 8
To complete each 240V circuit, Hot2 is connected directly to each Load.
6) You say 'salt' system connects to terminals 1 and 3 on T104, then those wires are carrying constant 240V to that device. So Salt system connects to terminals 1 and 2 on P1353
7) Get a second opinion:
I frequently contact Intermatic for various problems.
P1353 is fairly new product, and manual is long, and I might not fully understand your problem or wiring.
Intermatic answers their email.
http://www.intermatic.com/customer%20service.aspx
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 28, 2011 | Intermatic Digital 3-Circuit Timer...
Hi i replace 3 lg compressor 12000btu and i feel i did everything corrently but my compressor burnt ,and turns of the circuit breaker.i have check the voltage which is 240,current 5.6amp and psi 55...
dear sir
i think you did wrong connection with compressor please make sure first your connection is correct then install your compressor unit make vacuum in unit and then try to fill freon also use over load protectors in compressor for security .correct connection are giving you blow :
C : connect here wire which one is coming from main supply/thermostat /overload protectors
R :connect here wire which one is coming from capacitor ( C terminal).
S : connect here wire which one coming from H terminal of capacitor if capaciter/if capacitor is no mark then one wire i mean no require from H OR C terminal .
hope answer the question
thank you
please vote!
Oct 01, 2010 | Heating & Cooling
How do you wire a model GMXST-1-240-M Intermatic timer
There are many ways to wire the Intermatic GMXST-1-240-M timer. If it is not wired correctly you can permanently damage the timer.
For "regular" use, if all you want to do is turn a 240 volt load ON and OFF with the 7-day timer, and you are _very_ sure that you have a 240 volt timer (they can be 120 volt or 240 volt), here is how to wire it:
LINE connections:
The first incoming LINE (L1) 240 volt wire (pick one) is connected to terminal #1. A jumper (same wire size) is then installed from terminal #1 to terminal #3 [(COM) or (Common)].
The other incoming LINE (L2) 240 volt wire is connected to terminal #2.
LOAD connections:
The first outgoing (LOAD) 240 volt wire (pick one) is connected to terminal #2 _also_.
The other outgoing (LOAD) 240 volt wire is connected to terminal #4 [(NO) or (Normally Open)].
Again, while this is still just a basic timer there are at least 10 different ways to wire it depending on what kind of equipment is used, how one wants to control the equipment (using the Normally Open or Normally Closed contacts) or (HI or LOW speed for a 2 speed fan), the clock voltages (120v or 240v), and the load voltages (24 volt to 240 volt).
If you are not sure how to wire this timer after reading this post, I highly recommend posting back with very specific information or calling a _qualified_ electrician, as mis-wiring this timer can permanently damage the timer, connected equipment, and/or personnel (that means you).
Here is the wiring diagram:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/grasslin/gmxst-i-240%20-%20english.ashx
Feb 27, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
How to wire a T101 240 volt timer switch?
Hello. a timer is just a fancy switch. since this is 240 volts, you have two 120 volt legs [one black wire and one red wire]. Begin with the white wires, just twist them all together and wire nut them. If there is a bare, do the same with them and connect them to the metal box and the device[if there is a green ground screw for this purpose]. Then, since you are switching the hot wires only, connect the red and the black hot wires to the top side of the timer and the pairs of reds and blacks to feed the outlets to the lower side of the timer.
Sep 18, 2009 | Hardware & Accessories
Kenmore Model 94812 Electric laundry center
Hello handicapper,
Welcome to fixya.
Thank You Huuum
Oct 09, 2008 | Washing Machines
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
