Question about Campbell Hausfeld Air Tools & Compressors
Bought a used 2300, will not come on! Replaced the fuse, still won't come on. Battery light green, so what is the problem?
Honda Accord keeps blowing fuse and won't start
Recently we had to put a new fuse in the starter ???????????? What fuse ? location , size . A fuse blowing means a electrical short to ground .
May 29, 2017 | 1998 Honda Accord
2008 Honda civicv ex won't start green key light
I think you may have a immobilisor problem try the spare key first
Jan 24, 2013 | Cars & Trucks
I replaced the ignition switch in my 1995 ford ranger now the alarm won't stop
95 Ford Ranger Auto Alarm Wiring Diagram.
You need to re-check your ignition wiring. Here is the wiring for the alarm.
Battery Constant 12v+ Positive Wire (+): Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Red/Light Blue
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Light Green/Purple
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Light Green
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Gray/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): White/Black Or Brown
Parking Light Positive Wire Location: At Headlight Switch Or Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Pink/Yellow (Type B)
Power Door Lock Negative Wire Location: In Either Kick Panel
Power Door Unlock Negative Wire (-): Pink/Light Green (Type B)
Power Door Unlock Negative Wire Location: In Either Kick Panel
Door Trigger Positive Wire (+): Black/Light Blue
Door Trigger Positive Wire Location: In Drivers Kick Panel
Domelight Supervision Wire: Use Door Trigger (Requires Relay)
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Yellow/Light Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Any Wire With A Tan Stripe Or A Yellow Stripe
Tachometer Wire Negative Wire Location: At Ignition Coil
Brake Light Positive Wire (+): Light Green
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Dark Green/Purple
Factory Alarm Disarm Wire Location: Low In Drivers Kick Panel
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 16, 2011 | 1995 Ford Ranger Supercab
Gauge cluster lights won;t light - replaced cluster, dimmer switch - did put new stereo in car? Fuses, bulbs all good. What could be the problem?
When you put the stereo in, what did you do with the red wire with a green stripe? The aftermarket radios don't always use these, so you have to wrap the ends, depending on whether or not you used a wiring harness. If that wire is shorted on the chassis, it will blow the dimmer fuse.
1995 Honda Accord Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/White
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Red/Green
Car Stereo Antenna Trigger Wire: Yellow/White
Car Stereo Amp Trigger Wire: Violet/Red
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: 6 1/2?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Nov 28, 2010 | 1995 Honda Accord
Green and yellow light on charger; Battery does not charge.
check the terminals or wirings if it has detached,or its fuse,if after doing it you find out that your fuse is good,then your battery battery needs to be replaced
Oct 22, 2009 | Drills
Camera won't turn on
Are you sure you are using the correct battery specified in the manual of the camera?
Jul 22, 2009 | Samsung Digimax D53 Digital Camera
Honeywoo HZ-2300
The "diode"is a thermal fuse device.It is a thermal protection device which has to be replaced once it is blown or open.
Dec 16, 2008 | Honeywell HZ-2300 Compact Heater
Air Tools & Compressors Logo
159 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
