Question about Vizio P2 42 in. HD-Ready Plasma Television
Television screen will not come in but I have sound
My tv was working fine. I left to run an errand and when i got home the tv will turn on with sound but the screen stays black. It is a Sanyo. I have tried turning it off and on and plugging it into another outlet. Can anyone help?
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Sound no picture
If you replaced TV lamp recently then check lamp cover and make sure to seat it properly.
Need further info, let me know.
Jul 02, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Rainbow vertical lines going up and down the screen, no picture
thanks no further assistance needed from you--ta ta.
Jan 28, 2009 | Televison & Video
Lg 32lcd2d (tv won't turn on)
It is most likely the power supply. If you see domed caps change them using a higher voltage cap. If it's 1000uf at 15vdc put in a 1000uf at 25 or 35 vdc. If this helps let me know.
Sep 27, 2008 | LG 32LX1D 32 in. LCD Television
LG 32lcd2d
Sounds like your cable is off or your not on chan 3 . Can you go to setup and find cable , air ect ? And see if that does anything ? Check all your coaz and hdmi and make sure they are tight as well
Jun 25, 2017 | LG 32LX1D 32 in. LCD Television
No Picture
Do your on screen display work when you push menu?
Jun 29, 2008 | Philips 51PW9363 51" Rear Projection...
Sony KV-27S42 Television won't turn on
NO -the tube will be fine . The TV is in 'protect mode' . THis means that it has shutdown because of an internal fault condition. THis TV needs a technician's love..
Sep 17, 2007 | Sony KV-27S42 27" TV
Vizio P2 42 in. HD-Ready Plasma Television Logo
298 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
