Question about Building Materials
Lift master garage door opener won't open door motor runs no access to inside of garage. Suggestions?
  • 3,828 Answers
Manual release has been triggered
just lift up the garage door manually
will take effort
if motor drive engages as you lift and you cant get the door up any more
try the remote
Lift master garage door opener won't open door mot - index-534lvbbiedo0ovj13canlnto-4-0_0.jpg
Posted on Apr 30, 2017
My Lift Master garage door will not close. It makes the closing noise but the door does not slide down. Whcan I talk to to fix this?
Sounds like you have a chain drive garage door opener and you hear a humming sound when you push the wall console. The motor is running but the chain does not move. You need to replace the gear & sprocket assembly.
Jul 06, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
I need a new remote for lift master garage door opener with part number 41A3627 and cert # K710 FCC ID HBW1D3605
Those numbers won't help. The model number is on the opposite end of the opener from where you found those.
Oct 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
My nephew kept opening and closing my garage door, now the door won't open with the opener and I can lift it by hand. I tried pulling the cord to move it back to electric but it won't work... any...
The motor has a thermal protector that will cause the motor to quit when it gets hot. If you let it cool off it will automatically reset and should work again.
Jun 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
I installed the belt of the lift master garage door opener, but it looks like it has a lock and it does not open and close correctly. How can I re-set it?
The position of the belt and the limit assembly must be synchronized to operate properly. You need to loosen the belt enough to lift it from the pulley on top of the motor and then run the motor until it runs in the clockwise direction and stops. Now with the belt connected to the door and the door closed put the belt back on the pulley and tighten. Should do it.
Apr 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlane Lift Master Professional I went to open it yesterday and it would not open. When the button is pushed the unit just clicks and the controller light is blinking 5 times then pauses and...
The code it is flashing is "RPM sensor or motor overload." It is not a door sensor problem. The RPM sensor is a small circuit board just in front of the motor.
Mar 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
The motor makes a noise but seems locked up. 2265R Chamberlain lift master professional 1/2 hp
Make sure the door is running well with out the openers help first of all. If it is making this sound then look inside the unit with the unit unplugged for white shavings. If so you will need to replace the gears. Thanks BB
Mar 30, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage Opener Model 3255 Chamberlain Lift Master
The most common cause of this problem is a bad wall control the wiring going to it. You can eliminate both temporarily by removing the wire at terminal 1 on the back of the motor unit. The wiring sometimes is shorted by the staples the installer uses. The wall control gets used a lot.
Jun 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift-master 1265 Garage Door opener
Open case, & see if white shavings from gear stripped out are laying on bottom of case.
Dec 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
48 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
