Question about Dryers
There isn't any sound when the timer turns off. It is an FX1000 model.
2 Suggested Answers
emissionwiz
  • 80417 Answers
SOURCE: There is no sound when the timer turns off on our new Tefal FX1000 air fryer.
Take it back for warranty.
Posted on Apr 30, 2017
Cassette Door open and close but tape won't go down into deck
The loader motor turns a belt to draw the tape out of the cassette. Probably needs replacing.
Jan 13, 2015 | Sony HDR-FX1000 Mini DV Camcorder
I have a kitchenaid side by side refrigerator model #KSSC42MFS05 and the freezer isn't getting cold enough to freeze ice cream and the ice maker isn't working.
Look at the rear wall of the freezer for a layer of frost building on the outside of that panel. If yes the refrigerator may be missing defrost. That would explain why the feezer temperatures are warming. If the ice maker is above 5 degrees F it will not be able to make ice. Things to check are the=> 2162044 Defrost Timer
The=> 2000631 Defrost Heater
and the=> 4387499 Defrost Thermostat
I would like you to locate the defrost timer and turn the center with a flathead screwdriver slowly clockwise until compressor and fans turn off. Leave like this up to 30 minutes. This will cause the defrost to begin. If timer does not restart the compressor an fans after 30 minutes simply turn the timer again slowly clockwise until the compressor and fans restart. If the timer need to be turned like this then this would indicate that the defrost timer is defective and will need replaced. Let me know if you have questions Thanks Sea Breeze
Sep 25, 2012 | KitchenAid Refrigerators
So my intermetic time is broken, the gears dont turn, and the on/ off override isnt working. I need my pool heater, what do i do?
Sounds like you lost power to the timer. Look in your electric panel for a tripped breaker. Turn it OFF then back ON.
Aug 20, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Washer works but does not run through the spin cycle. it will if i go to it with the timer switch. but not with the timer. when washer gets to the off pos. still has water in it. sat and watched it on...
Sounds like the timer isn't advancing does'nt it.
See if there is power getting to timer motor, but sounds more like timer getting stuck ,especially if older model .replace timer if out of warranty
good luck
Aug 15, 2011 | Maytag Washing Machines
Does not heat and the timer does not shut the dryer off
Most dryers have two circuits. It sounds like one of these has a blown fuse. Check the breaker/fuse box and make sure the breaker isn't tripped or the fuse isn't blown.
Jul 24, 2011 | Dryers
Timer switch mode is inoperable. no lights in timer setting, the lg ld450eal model operates continously. please advise how to program the 2 hour or 4 hour timer
With the Dehumidifier switch on, pressing the Timer Button should changed between 2hr and 4hr mode.
If this is what you're doing and it isn't lighting the LED nextto the 2hr and 4hr can you confirm what setting you have for the humidity?
Jun 25, 2011 | LG LHD45EL Dehumidifier
Driver for fx1000 printer
Epson Fx-1000 driver is included in XP.
Nov 15, 2007 | Epson FX 2180 Matrix Printer
Dryers Logo
24 people viewed this question
Top Dryers Experts
