Question about Garden
What direction to turn nut to remove blade from an HU625AWD LAWN MOWER
  • 954 Answers
Turn to Left. The blades on many brands of walk-behind mowers rotate to the right, the clockwise direction, when you are mowing. To remove the blade, you must turnthe blade's retaining bolt to the left, or counterclockwise. The important thing here is that you put a 2 x 4 or a block of wood to stop the blade from turning. If you have it, a blade lock is best. If you don't have it and the blade is sharp, you may want to wear some gloves.
I hope this helps you out!
Posted on Apr 30, 2017
    Top Expert:
  • Garden Master
  • 48,384 Answers
Normal right hand thread so counter clockwise to undo
How to replace plastic blades on a challenge mower
Dave, Remove plug wire, raise mower, or tilt on it's side to access blade. Remove center bolt holding blade on, noting the position so as not to install new blade upside down. Install new blade correctly and tighten blade bolt tight. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change Lawn Mower Blade
Lawn Mower Repair How to Remove Lawn Mower Blades
What Direction Do Turn the Nut to Change Mower Blade
Jul 28, 2016 | Garden
How to remove a stuck bolt on blades on riding mower.
The blade bolt can be very difficult to remove sometimes and will require an impact wrench. If that doesn't work, you will need to heat up the nut only with a Ox/Acetylene torch, then it will remove easily. Do not heat the nut too much or it will ruin the thread on the spindle when it comes off. Remember to heat the nut only.
Aug 06, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I cannot remove the blade from my B&D MM575 mulching mower. The manual says to block the blade, then loosen the nut. However, when I block the blade and turn the nut, the shaft continues to turn,...
You can use a pipe wrench on the shaft and a regular wrench on the nut. Disconnect your spark plug and tip the mower onto it's left side. You will have to use your left hand to go down through the mower shoot to hold the pipe wrench and your right hand to unbolt the the blade attaching bolt, it should come off immediately.
Remember you may have to purchase a new blade holder, since your problem shouldn't occur if your blade holder was OK. GOOD LUCK.
Jul 28, 2011 | Black & Decker Black and Decker Mm575 18"...
What holds mulching blade to lawnmower?
A nut.
Unplug the spark plug.Lift the mower.Under the mower you will see the blade.It is held on buy the nut in the center of the blade.Wear a leather glove(or something similar)to hold the blade and turn the wrench(socket&ratchet)with the other hand.
Jul 12, 2011 | Arnold Corporation Arnold 21-Inch...
To remove the blade, does the bolt turn clockwise or counterclockwise?
As viewed from beneath, the bolt is loosened by turning it counterclockwise. They are generally pretty darn tight. Use a block of wood to hold the blade from rotating. A rubber mallet to encourage the wrench usually helps too. By the way, the rule for which way to loosen a bolt or nut that holds a blade by it's center is that loosening is in the same direction as the blade normally turns. This is because the work (the grass in this case) tries to resist the blade and therefore pushes against the direction the blade is turning - and that MUST be the direction that the blade would be tightened (otherwise it would be loosened in the course of using it!). This applies to lawn mowers, edgers, circular saws, grinders, etc. I have never found an exception to this rule. Good luck, Al K
Apr 12, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Shaft turns while trying to remove blade on B&D MM875 elec. mower
Here's the scoop on the MM875: it has a plastic piece called a "blade insulator" (part # 241381-01) that "locks" the shaft to the blade, so that you can remove the nut by stopping or blocking the blade. If it has been damaged or stripped out, then stopping the blade won't do anything. However, the metal spacer directly under the nut IS still locked to the shaft (because of its shape), so you can use a pipe wrench or something to hold that in place and unscrew the nut. You might even be able to get someone in a home improvement store to do this for you. But you will still need to replace the insulator, which is only a few dollars.
Jul 22, 2010 | Black & Decker 19" Electric Lawnhog...
Which direction do you turn the bolt holding lawn mower blades on?
Clockwise to tighten. Remove the spark plug wire before working under there! Use a piece of wood to jam the blade against the housing so it will not turn.
May 21, 2010 | Toro Lawn Mower With Toro Power Tools
Replace blade on electric lawn mower
If you have a work bench, place your mower on the bench on its side or upside down where you can see what you are doing. If no bench, the floor of your garage or your driveway will work too.
Get a small 2 x4 block, a C-Clamp or some other device to keep the blade from spinning.
Get a ratchet or breaker bar and socket to fit the bolt in the center of the blade.
After you are sure the blade is blocked from spinning, turn the socket and ratchet to the RIGHT (clockwise) to loosen the nut until you can completely remove it.
When you install the new blade, look at it to see if it is marked "grass side" if it is not marked, the sharpened area on the blade should have the "beveled" edge toward the housing and remember the nut will turn to the left (counter-clockwise) to install and tighten. (Electric mowers have LEFT HAND THREADS due to the rotation direction of the motor.)
Oct 08, 2009 | Black & Decker 18", 6.5a Electric Mower
Remove cutting blade
take the blade disc off the mower, you should have the nuts on the top of the disc for the blades, put the disc on the ground and remove the nuts on the blades.
Replace the blades with the new ones and fit the disc back under the mower
Apr 05, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
