Question about Garden
How do i get to the fuse on lawn tractor 24hp 42" mower model number 917.275685
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
jbridger (John)
Posted on May 11, 2009
  • 513 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
  • 130 Answers
SOURCE: change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be you need a book i say take to shop.let me know
Posted on Jul 22, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
SOURCE: need owners manual
Posted on Jul 18, 2010
I changed the oil in my Craftsman Lawn Tractor 24HP Model No 917-288320 and the "change oil" message on the LED screen won't go away. Is there a reset button somewhere?
Below is excerpt from the owners manual:
Service reminder shows the total number
of hours the engine has run and flashes to
indicate that the engine or mower needs
servicing. When service is required, the
service reminder will flash for two hours.
To service engine and mower, see the
Maintenance section of this manual.
NOTE: Service reminder runs when the ignition
key is in any position but "STOP". For
accurate reading, be sure key remains in the
"STOP" position when engine is not running.
It should reset the 2 hours has expired
Jan 16, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Have gas in oil - will not start
Gas in oil is usually a symptom of flooding, caused by a stuck needle valve or damaged float in the carburetor. But 65 hours is awfully "young" for this problem.
Jul 16, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
What is the part no. of the blades on a 42 in. mower
You can go to Sears' website at and enter your model # (usually found under the seat) to view the diagrams for your model and locate your part #'s. Once you find the Sears #'s, you can find replacement blades for your mower at Partsbuggy's Sears page here - It also lists Sears' part numbers along with the blades and belts by deck size.
Jul 06, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
Battery discharges while running
My 24HP 42" did the same. If your model is like mine, there are two black wires with a yellow connector coming down the side of the engine. Unplug those wires, and with engine running, and a multimeter leads attached to them measure for 15 volts AC. If good reconnect yellow wires, and test the single red wire with multimeter red test lead connected and black test lead to any engine ground point. Measure for 15 volts DC. My problem was that square regulator that did not convert 15 VAC to 15 VDC. If your tractor is less than two years old, the warranty will cover labor and repair. Also if your tractor's wiring has different color wires, the test procedure may be different.
May 22, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
I need a battery for my lawn tractor what size do i need to get
just take your old one to the auto part store they will give you the right one.
Apr 21, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
The bracket that's in front of the deck for lowering is broken the tractor mower is a few years old i do not have the model or part numbers for it, the is gray in color from sears
the only bracket i can think of is welded onto the deck, so you'll either have to have it welded up or back on, or replace the deck - without the model number, it's difficult to give accurate advice
Aug 22, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
