Question about Dell Inspiron 1525 Notebook
Battery wont change
Same prob it says o% available plugged in ,not charging ...now what should i do ? is it an adaptar problem or a battery one ?
  • Dell Master
  • 5,660 Answers
A problem is just like a mountain. You don't jump over the mountain, you climb it in steps, one step at a time.
1.How old is the battery? 1 to 2 years old, you can expect it to be at the end of it's Life Cycle. Batteries are rated in so many hours of usage.
Best bet is to let the battery charge 24 hours, then try it.
Would be nice if you someone else that has an Inspiron 1525, and they would try to charge your battery. If it doesn't charge up, you would know it's the battery. If it does charge up you can move on down the charging system, to try to find the problem.
2.AC adapter, (Charger) If you have a multimeter, set it to the 50 volt DC scale.
Laptop and desktop computers use DC current. (Direct Current) Your house, for example, uses AC current, (Alternating Current)
AC is converted to DC by the AC adapter, (Charger)
An example of DC current are flashlight batteries, and your laptop battery.
DC current has a Positive pole, and a Negative pole.
The center pin of the plug of your AC adapter is the Positive pole. Any of the four outside pins on the plug, are Negative.
The Red, (Positive), probe of the multimeter goes to the center pin. The Black, (Negative), probe goes to any of the outside four pins on that plug.
Example of a DC Power Jack, for the Dell Inspiron 1500 Series of laptops, 1525 and 1526, (This is the jack inside your laptop, where you plug the AC adapter into),
http://www.megaemarket.com/dc-power-jack-for-dell-inspiron-150150015011505.html
3.It may be that DC Power Jack itself is bad, or one of the solder connections is cracked. It's hard to see it clearly on the link I provided, (So I Right-clicked on it, Save Image As, and put it right in my My Pictures folder. Then I magnified it), but in the photo you will see some metal pins sticking out of the rectangular body.
The metal pins are sticking up. In reality those pins go down, when the jack is mounted on the motherboard. They go through the motherboard, via holes, and are soldered on the other side.
It is these solder joints that may crack, is what I'm referring to.
Solution to 1?
Obviously buy a new battery.
Solution to 2?
If your multimeter findings show lower voltage than needed, it's time to buy a new AC adapter. They have generic ones that can be used on a variety of laptops. The voltage will be stated on the top of the AC adapter.
Example: 19.2V-1.0A
That's 19.2 Volts at 1 AMP.
It may just be the plug end on the AC adapter itself. The plug end that goes into the DC Power Jack, on your Inspiron laptop.
Solution to 3?
Unless you are a skilled Electronics Technician, and have Excellent de-soldering/soldering skills, I advise taking it to a computer repair shop. It may not just be cracked solder joints. The DC Power Jack may need to be replaced. Maybe the motherboard is one of a bad design, and where the DC Power Jack attaches to it, has cracked.
Posted on Jul 25, 2009
  • 33 Answers
Its a battery problem, try fully discharging the battery & recharging it if it still works
Panasonic KX-TG6700 Phone
test the adaptar if working try it in another phone
2) sure the the line cord is plugged firmly in the phone base
3) unplugged the phone base . Wait from 30 seconds, and plug it again. Allow up to one minute for the cordless handset and phone base to synchronize.
4) charge the batteries by 16 hours aprox.
5) if the batteries is completely dead can take 30 minutes before low battery appears on the screen.if doestnot work replace battery by new ones.
try agan.
Oct 03, 2012 | Panasonic KX-TG6700 Phone
Diescribe your Pavilion dv7-1245dx PC Notebook. just recently i purchased a new battery and i returned it because it was not charging correctly so i got another one and i,m still having the same problem, i...
It is normal for the adapter to run warm, but it shouldn't feel so hot you can't touch it. Since you have tried a couple of replacement batteries and still have the same trouble, it's safe to assume that either your adapter is bad or that there's something wrong on the computer system board. New adapters are easy to find and not very expensive (here's one seller on eBay), so that would be the next thing to try.
If the motherboard is the trouble (something wrong with the charging circuit), that's replaceable as well but it's not a cheap or simple repair. A replacement board may cost $100 to $200 for a used and tested part, and over $300 for a new one from an HP-authorized part seller, and installing the replacement can be very tedious. It might be more economical to replace the computer if the motherboard is bad. Try a new charger first.
Sep 11, 2011 | HP Pavilion dv7-1245dx Notebook
I have an nv5468u with Part Number LXWDG02030. My laptop wont charge the battery, I can still turn it on using the ac adapter but it wont charge the battery, the battery light indicator just alternates...
Hi there. Your problem seems to be the battery. Usually when the battery is at the end of its life the indicator stays at 0%. If you are still unsure you can go to download.com and get free battery testing software. Good luck...
Mar 30, 2011 | Gateway NV5468u Notebook
Lenovo x 60 tablet battery shows 0% available , not charging. its a new battery i bought.
If the laptop works fine while plugged in but stops working while unplugged, It's likely that either your laptop battery is broken or your laptop battery is not charging properly. Below steps can help you identify the cause of this kinda problem
1. Leave Power plug in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
2. Remove and Reinsert Battery
In some situations the battery can become loose. Removing it and then put it back into the laptop.
3. There is Some Software
Use battery utility to determine the total capacity of the battery. For example, Battery Care Software is a free software utility capable of doing this.
4. Refreshing Battery
Some laptop manufacturers allow for batteries to be refreshed through the CMOS setup.
If problem still there. try Replacing Battery or Power Adaptar.
still the problem persist take the laptop to Service Center
best of luck..
Jan 29, 2011 | IBM Lenovo ThinkPad X60 Motherboard -...
My battery died and i charged it but it wont come on
that's not the battery prob bro...check ur mob charging pins...i have the same prob with my MDA but when i squeeze my pins of MDA its working...so do the same...i hope this work...and also check ur friend battery on ur mob with charger..
Mar 04, 2009 | LG KU990 Viewty
Electrical
may i please ask? is this problem related to the battery failing to start engine? ie turns slow ? or not turn over? suspect battery? changed battery still same prob ? changed alternator suspect not charging ? still prob exists ?? so you have eliminated these?and drive belt is tight ? when ?i assume you have to start? do you use jump leads? and starter works ? if so using this method advise you check the earth/ground lead from battery to where it connects to engine? and ensure clean/secure ? also there may be another earth lead from engine to chassis ? if these are not good condition as above then intermittant sarting problems occure especially from initial cold start giving suspect battery of failing to charge battery indicated by poor starter operation if you could give any info as to what happens that suspect not charge would assist on exactly is happening to your vehicle best wishes from uk
Nov 05, 2008 | 1989 Toyota Pickup SR5
Wont go on
Dumb question, is it plugged in? Can you verify the lappy is getting DC juice from the power adapter?
If electricity is available from the charger, when plugged into the lappy can you see a charging icon either on the battery or some sort of display near a on, wireless, power, battery display? If no symbol shows charging, you either have a bad jack in the lappy or a bad battery.
If DC is not available from the charger, then it's bad.
Hope that helps;)
Dec 24, 2007 | Computers & Internet
Dell Inspiron 1525 Notebook Logo
491 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
