Question about Ovens
New gas oven. Does not go beyond preheat mode. Trying to cook dinner for last hour. Oven is not to temp. Help.
    Top Expert:
  • Ovens Master
  • 79,865 Answers
Call for warranty service.
Posted on Apr 30, 2017
Oven takes forever to preheat
check to see if both broil and bake elements/gas works
May 25, 2010 | Maytag CWG3100A Gas Single Oven
Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
some units will need to be adjusted if you live in a high altitude above 3000ft.
Dec 10, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Gas oven temp problem
HI thanks for your question. there is a oven sensor , located in the oven, top left corner. replace this part. thanks the appliance doc. please rate my answer. thanks
Oct 11, 2008 | Frigidaire Ovens
Oven works intermittently
well i had a service call like this one time almost drove me crazy lol so to try to help im going to tell you about it every thing checked out but oven would not cook right finnaly i took the gasline loose from the regulator and rust and trash had built up so heavy on the regulator screen it was restictin the flow of gas so when the contol demanded more gas it couldnt get it but it wouldnt set a fault code because nothing were wrong with the conterols
Dec 11, 2007 | KitchenAid Architect Series KEBC107KSS...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
