Plug was unplugged from unit
Cameras not working dvd was unplugged
I have a Panasonic surround sound DVD player and the remote has stopped working, I've replaced batteries and tried resetting unit.
Did you fully shut down the player including unplugging. Did you contact mfr customer service or warranty claims for instructions on resetting the remote code in the unit?
Jan 13, 2015 | Panasonic Televison & Video
Panasonic dvd /vhs recorder
unplug it again.. plug it back in and take any dvd/tape out of it..go to the setup menu and let it reprogram any channels..it should start working once that part is done.. if not go find another unit at a resale shop..
Jan 20, 2014 | Televison & Video
MY MEMOREX DVD PLAYER suddenly WONT TURN ON?
Unplug power cord, wait 30 sec. Plug back in. Worked 4 me
Mar 20, 2011 | Memorex MVD2042 DVD Player
Can't switch to TV. I removed a DVD that was stucked in it. I continues to ask for DVD or sd card Model is dtv-263-d
Did you remove the DVD without opening the tray? If so unplug the unit and let it unplugged overnight. When you plug it back in it should work unless you damaged something removing the DVD. Let me know how it works out.
hardrocko
Jan 31, 2010 | Mintek DTV-233 23 in. TV/DVD Combo
Just like everyone...came home all of a sudden the unit won't turn on ???? standby light is on but nothing..
In addition to just unplugging the unit, another method that worked for me when unplugging it did not was to unplug the HDMI cable from the TV and then unplug and replug.
Jan 03, 2010 | Philips SoundBar DVD Home Theater with...
My little colby dvd player wont open or close and it wont turn off. if it would open, i would try to reset the remote..yes, i have plugged and unplugged and have it plugged directly into tv???
I assume you've tried plugging into a wall socket instead of TV?
Probably won't work, but push and hold power button on unit 10 seconds then release, for that matter try all buttons. Not uncommon problem, usually you have to UNPLUG unit, disassemble to remove DVD and discard unit if cheap enough.
Sep 26, 2009 | Televison & Video
F60 Error message on DMR-ES40V unit
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
Jan 05, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Built in dvd player will not let me insert dvd
The LCD/DVD may need a reset. Unplug the unit for 10 sec then plug back in. Instead of power button, push eject button. The blue DVD screen should appear. This worked on my unit which I had for only 2 months. If not call customer service.
Oct 23, 2008 | LG 32LG40 32 in. LCD HDTV
Stuck dvd in dvd player
This is what LG customer service will instruct you to do. I have a LG LDA-511:
1. Unplug your unit.
2. After unplugging, wait a few seconds then press and hold the power button (yes, while the unit is unplugged). This resets the unit.
3. Plug in your unit.
4. Press the eject button.
If the disc does not come out, then you need service from an authorized service representative.
Feb 21, 2008 | LG LDA511 DVD Player
Televison & Video Logo
Top Televison & Video Experts
