Question about Maytag Washing Machines
I have a maytag dishwasher wu202. Do I have to remove the pump to install the dishwasher pump to tank gasket?
I removed everything inside to clear a clog and the gasket came out. I purchase another but see no logical way to install it from inside the tub. Where and how does it exactly connect. Thank you
  • Whirlpool
    Whirlpool Jun 16, 2017
    Hi KMS, we'd be happy to help you arrange service as we are not trained technicians and would be unable to instruct on the removal of the pump to tank gasket. If you still need assistance, please provide your name, the name of the site you were contacted on (fixya.com), your user ID name (K M S), your phone number, your address, the full model and serial number, and email the requested information to Maytag_Digital@Maytag.com. We would be happy to review your concerns further.
    Top Expert:
  • Maytag Master
  • 77,169 Answers
Yes of course.
Posted on Apr 30, 2017
How do I replace a dishwasher sump pump gasket?
Would love to help but need manufacture and model #
Jan 28, 2015 | Dishwashers
F21 code still flashes after i've unclogged line - reset?
if you cleaned out the pump by removing the center part of it and it still shows f21,either you didn't clear everything out of the pump,after you pull out the center piece stick your finger inside where the impellar is to see if you feel anything rapped around it,if it's clear and still won't drain then you need to buy a new pump and remove the old pump and install the new pump part number 280187 and it's around 120 dollars http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MFW9700SB1/3048/0153200/W0705107/00006?blt=06&prst=&shdMod=
Dec 10, 2011 | Maytag EPIC MFW9700S Front Load Washer
Fuel pump replacement
Fuel Pump - Multi-Port Fuel Injection models REMOVAL & INSTALLATION 1984-95 Models Fig. 1: Loosen the hose clamps and tag the fuel hoses before disconnecting them . . . 91075p07.jpg
Fig. 2: . . . then detach the hoses from the fuel pump module/sending unit 91075p06.jpg
Fig. 3: Disengage the fuel pump module/sending unit wiring harness connector 91075p05.jpg
  1. Disconnect the negative battery cable.
  2. Remove the fuel tank filler cap.
  3. Relieve the fuel system pressure as outlined in this section.
  4. Drain the fuel from the fuel tank.
  5. Raise and support the rear end on jackstands.
  6. Remove the fuel inlet and outlet hoses from the sending unit. Be ready to catch any spilled fuel.
  7. Disengage the sending unit wires. Fig. 4: The fuel pump module/sending unit retaining ring must be rotated counterclockwise for removal 91075p01.jpg
  8. Using a brass punch and hammer, remove the sending unit retaining lockring by tapping it counterclockwise. Fig. 5: Carefully pull the fuel pump module/sending unit out of the fuel tank - step shown with the fuel tank mounted on the vehicle 91075p03.jpg
    Fig. 6: Remove and discard the fuel pump module O-ring gasket 91075p02.jpg
  9. Remove the sending unit, which incorporates the electric fuel pump, along with the O-ring seal from the fuel tank. Discard the O-ring.
  10. Remove and discard the pump inlet filter.
  11. Disengage the fuel pump terminal wires.
  12. Remove the pump outlet hose and clamp.
  13. Unfasten the pump top mounting bracket nut and remove the pump. To install:
  14. Install a new inlet filter on the pump. Fig. 7: This is the proper positioning of the fuel pump module assembly inside the fuel tank 86745g55.gif
  15. Assemble the pump and bracket. Connect the hose and wiring.
  16. Install the unit and new O-ring in the tank. The rubber stopper on the end of the fuel return tube must be inserted into the cup in the fuel tank reservoir.
  17. Install the lockring. Carefully tap it into place until it seats against the stop on the tank.
  18. Connect the hoses.
  19. Engage the wiring.
  20. Lower the vehicle, fill the tank, run the engine and check for leaks.
1996-98 Models Fig. 8: Fuel pump module location - 1996 model shown 86745g52.gif
  1. Drain and remove the fuel tank as outlined in this section.
  2. Using tool 6856 or its equivalent, remove the module locknut which is threaded onto the fuel tank. The module will spring up when the nut is removed.
  3. Remove the module. To install:
  4. Install a new gasket and place the module into the opening in the fuel tank.
  5. Position a new locknut on top of the module and tighten the nut using tool 6856 or its equivalent to 40 ft. lbs. (54 Nm).
  6. Install the fuel tank as outlined in this section. Fig. 9: Locknut removal using tool 6856 or its equivalent 86745g56.gif
    Fig. 10: Install a new gasket on the fuel tank opening 86745g57.gif
Jan 19, 2011 | 1993 Jeep Grand Cherokee
How to rplace the fuel pump+
Check this procedure to REMOVAL & INSTALLATION
(see Figures 1, 2 and 3 / click over pics for zoom)
Fig. 1: Remove the nuts retaining the access cover in the trunk
Fig. 2: Once the cover is removed, access to the pump is obtained
Fig. 3: Note the alignment marks must be met to install the pump correctly
An electric fuel pump is used with fuel injection systems in order to provide higher and more uniform fuel pressures. It is located in the tank. To perform the testing or servicing, you will need a DRB III or equivalent scan tool.
  1. Release the fuel system pressure.
  2. Disconnect the negative battery cable.
  3. Open the trunk lid, then remove the trunk liner.
  4. Remove the access panel fasteners.
  5. Remove the access panel and gasket. Inspect the gasket for damage. If necessary, replace the gasket.
  6. Disconnect the electrical wiring from the top of the pump module.
  7. Disconnect the fuel supply and return tubes from the fuel pump module.
  8. Disconnect the hose from the pressure relief/rollover valve.
  9. A band clamp fastens the pump module to the tank. The module rises up from the tank after loosening the clamp.
  10. Loosen the band clamp until the pump module rises up from the tank.
WARNING The pump reservoir may contain fuel. Do not spill fuel while removing the module.
  1. To absorb any possible spillage, place a shop towel around the access opening. Without removing the modular, tip it backwards to allow fuel in the reservoir to run down the side and back into the tank.
  2. The float arm of the sensor catches on the inside of the tank while removing the module. Tilt the module to the one side when removing it from the tank.
  3. Remove the pump module and gasket from the tank.
  4. Drain the remainder of fuel from the reservoir before servicing the pump module.
To install:
The fuel pump module and tank have alignment marks. The tank has two molded lines at the ten o'clock position. The fuel pump has a triangular alignment mark. Align the marks to correctly position the pump.
  1. With a new gasket, insert the pump straight into the tank to set the float on the bottom. Align the marks on the pump and tank.
  2. Seat the pump to tank by pushing the top downward. Make sure the gasket does not slip over the outside or inside edge of the tank lip. While holding the pump in the seated position, place the band clamp over the lip of the tank and edge of the pump. Tighten the band clamp to 31 inch lbs. (4 Nm). Do not over tighten.
  3. Install the fuel tubes over the return and supply nipples on the module.
  4. Connect the vent line to the pressure relief/rollover valve.
  5. Attach the electrical wiring to the pump.
  6. Using a DRB III or equivalent scan tool, pressurize the fuel system.
  7. Check for leaks.
  8. Install the access cover and gasket. Tighten the fasteners.
  9. Install the trunk liner.
  10. Connect the negative battery cable.
Hope this hellps (remeber to rate this answer).
Dec 17, 2010 | 1997 Dodge Intrepid
Is the fuel pump located outside the gas tank or inside the gas tank?
HI. This vehicle has a fuel pump access cover located inside the trunk, under the carpet overlay. Once you have removed the carpet; the cover can be seen in the center section of the trunk bed. There are 4 retaining nuts that are holding the cover on the access hole. Remove the nuts retaining the access cover in the trunk and lift up the cover. Once the cover is removed, the fuel pump will be exposed for maintenance or replacement.
The complete fuel pump module assembly in located inside your tank under the cover.
Aug 09, 2010 | 1994 Chrysler Concorde
Change fuel pump
Chrysler Concorde/Intrepid/LHS/New Yorker/Vision 1993-1997
Electric Fuel Pump - REMOVAL & INSTALLATION
(see Figures 1, 2 and 3)
To install:
  7. Check for leaks.
Hope this help to solve your problem (remember rated and comment this).
Mar 23, 2010 | 1996 Dodge Intrepid
Maytag dishwasher that won't drain when finished
HI, usually, if the dishwasher dose not drain properly, it will be the fault of a defective or, malfunctioning pump. i will list several problem areas to check. Inspect each area properly and, replace any component that is faulty or fouled.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jun 22, 2009 | Maytag MDB6000 Dishwasher
I need to replace the fuel pump in my 1985 Chevy S10 pickup, need all help. What is the procedures?
EXACT PROCEDURE ! Please Rate Me Fairly for this!! Thank you And Good Luck !!
ELECTRIC PUMP
REMOVAL
  1. Before servicing the fuel pump the fuel system pressure must be relieved. See: Fuel Pressure Release
  3. Raise the car on a hoist.
  4. Remove the fuel tank. See Fuel Tank / Service and Repair.
  5. Remove the fuel tank sending unit and pump assembly by turning the cam lock ring counterclockwise. Lift assembly from the fuel tank.
  6. Pull the fuel pump up into the attaching hose while pulling outward away from the bottom support. Take care to prevent damage to the rubber insulator and strainer during removal. After the pump assembly is clear of the bottom support, pull the pump assembly out of the rubber connector for removal. NOTE: Inspect the fuel pump attaching hose for any signs of deterioration. Also check the rubber sound insulator at the bottom of the pump. Replace damaged or deteriorated parts.
INSTALLATION
  1. Push the fuel pump assembly into the attaching hose.
  2. Position the fuel tank sending unit and pump assembly into the fuel tank. Use a new "O" ring seal. NOTE: Care should be taken not to fold over or twist the strainer when installing the sending unit as this will restrict the flow of fuel. Also, verify that the strainer does not block the full travel of the float arm.
  3. Install cam lock over the assembly and lock by turning clockwise.
  4. Reinstall fuel tank.
MECHANICAL PUMP
REMOVAL and INSTALLATION
NOTE: To ease pump installation, rotate the camshaft so the camshaft eccentric is out of the way of the fuel pump rocker arm.
  1. Disconnect fuel lines from fuel pump.
  2. Remove fuel pump mounting bolts and the fuel pump.
  3. Remove all gasket material from the pump and block gasket surfaces. Apply sealer to both sides of new gasket.
  4. Position gasket on pump flange and hold pump in position against its mounting surface. Make sure rocker arm is riding on camshaft eccentric.
  5. Press pump tight against its mounting. Install retaining screws and tighten them alternately.
  6. Connect fuel lines. Then operate engine and check for leaks.
Mar 22, 2009 | 1985 Chevrolet S-10
Dishwasher does not cycle
Yes, you'll need to replace the motor. Though you may not need to remove the machine from under the counter.
Feb 09, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Jun 05, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Washing Machines Logo
51 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
