Question about Dyson Vacuums
Dyson ball MG9 not switching vac to hose when upright
Is not vac floor much either. Can't find anything stuck in hose.
  • 5 Answers
SOURCE: dyson 18 losing suction
Check the HEPA filter if it has one. This bit of foam gets clogged over time and significantly reduces the suction especially if you've been vacuuming a lot of very dusty areas i.e. dust from building work etc. Just wash the filter with lots of water and leave to dry before reinserting.
Posted on Aug 12, 2009
SOURCE: After hoovering yesterday my dyson ball wont stand up right.
solved this today by folding the upright part back as far as it would go, and wiggling it a little. It clicked back into place.
Posted on Nov 01, 2009
SOURCE: dyson 28 handle is stuck in the locked and upright
how do you remove the air duct (plastic sliding piece) that is making the vacuum stay in locked upright p[position?
Posted on Mar 09, 2010
SOURCE: Dyson DC 25 Ball - no power to motor
Same problem here. We noticed a loss of suction for about 5 minutes and the suction stopped. Beater bar still rotates but ZERO suction.
Posted on Apr 18, 2010
Dysonteam
  • 167 Answers
SOURCE: My Dyson Ball DC25 Animal will not stand upright?
Hi its Darran at Dyson.
Its possible that the stabiliser pedal has popped out of place. For help on how to resolve this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
How can I reattach handle so I can vac?
Hi Tess, it's Jack at Dyson.
This issue sounds unusual - DC24's reversible wand should simply reattach to the machine in the same way it was removed. The red clip at the front holds it in place.
In order to help you resolve this issue, we'd need to take some additional details about the particular issue you're experiencing. When you have your DC24 to hand, please contact the Dyson Customer Helpline for further assistance. You can reach our experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 12, 2015 | Dyson DC24 Ball All-Floors Upright Vacuum...
My Dyson DC24 will not pick up despite the rollers are spinning.(i have cleaned the rollers) All the filters have been changed. When usng the hose after a second a loud hiss can be heard and then no ...
I have the feeling you have something stuck somewhere at the hose. carefully use a clothe hanger and clean inside the hose. use a flashlight to see the object.
Feb 09, 2011 | Dyson DC15 All Floors - The Ball Bagless...
My Dyson turns on and is not sucking. It makes a
I have the dyson dc 27. On the bottom left back side of mine there is a circle, and ball inside of it. I turned it on and pushed the ball and it started working again. Sometimes it doesn't cover the whole and stops sucking air through it.
May 18, 2010 | Dyson DC07i Bagless Upright Vacuum
Cant separate my hose from the hoover, seems
http://www.espares.co.uk/datastore/ProductManuals/350256.pdf
Check the above manual to see if it clarifies how to separate the hose.
You can also try calling their helpline at 866-MyDyson for further help
May 13, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Hi my dyson dc18 has great suction from wand but when you got to use the vac for floors little suction but wand still got suction even while vacuming floors is it suposed to stop suction from wand
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Apr 03, 2010 | Dyson DC18 all floors Bagless Upright...
Dont sunction when using.
The number to the Dyson company is behind your dirt canister. They should be able to help you over the phone.
Mar 16, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Toy stuck in hose
Generally, this is a job for patience!  First, remove the hose from the unit.  Try a broom handle to push the toy out...you will not damage the hose.  If that doesn't work, you can use a piece of stiff wire fed through the hose with hooked end.  An electrician's fishtape...a snake...is often useful.
Nov 15, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Vacuums Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
