Question about Dishwashers
Does the Magic Chef dish washer DU2000W have a reset button?
SOURCE: Kneading Blade for Magic Chef CBM 250-2
I found a compatible belt!!! It's a Dayco # 15260, which you can order from partstore.com!!
Posted on Nov 25, 2008
  • 5 Answers
SOURCE: MAgic Chef top loading washer will not spin or drain
you have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
Posted on Jan 03, 2009
Karthik316
  • 187 Answers
SOURCE: Magic Chef 20lbs hd won't agitate
Try these
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
pls rate my suggestion.......
Posted on Jul 23, 2009
iwillfixforu
  • 619 Answers
SOURCE: i have a magic chef compact refrigerator model
Sounds like defrost timer on back right corner has stopped in the defrost position. Located bottom left corner inside white plastic box if you are behind ref.
Posted on Feb 01, 2010
  • 129 Answers
SOURCE: MAGIC CHEF WASHER WONT SPIN OUT
underneath the washer is a pully assembly kit . remove the belt ,the c clip and replace the pully kit about $ 20.00 cost for parts.
Posted on Feb 02, 2010
Magic Chef Washer shut off and won't turn back on. The load may have been too heavy for it. Not sure how to fix it. I turned the breaker on and off, unplugged and replugged it back in.
Unplug your machine again. Remove items from washer ringing out items as you do so. I am thinking that your machine has jammed up at the bottom of agitator, and nothing can move because of this. Now if you don't have an agitator then you may have a reset button somewhere on machine. Good Luck Friend.
Oct 20, 2017 | Magic Chef Washing Machines
Water in the bottom dw smells.It's not from wet dishes dripping.It just appears every few days.Would my disposal have something to do with it?I don't know how to take it apart to find out.
try washing without dishes with a cup of vinegar or get a product at the store call dish washer cleaner that you use it in and empty dish washer to clean and remove smell.
also could be clogged strainer in the bottom of DW then need to be cleaned out!
Sep 04, 2016 | Magic Chef Dishwashers
No receptacle for rinse agent
U can buy a soap with rinse agent in it already. I think one brand that offers this Finish. I don't know anyway of adding a receptacle to an older washer.
Apr 23, 2014 | Magic Chef Dishwashers
Water does not go into the dish washer during the wash cyle. This is a new problem on an existing Magic chef dish washer.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 08, 2010 | Magic Chef Dishwashers
This is a magic chef, only a few years old. I use cascade detergent powder. the washer runs, gets water & drys but the dishes come out with a cloudy flim all over them, like the detergent is baked on
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Sep 04, 2010 | Magic Chef CDB1500AW 24 in Builtin...
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
