Need manual for vx7021
Need to set unit up
How do I access hidden menu or bypass brake dvd warning on Jensen VX7021?
http://www.uneeksupply.com/Jensen-VX7021-Radio-Parking-Brake-Bypass-to-watch-video-in-motion-_p_41815.html
this is what you need to bypass the sfety feature. Note this is for off road or show purposes only. Having video playing within view of the driver is ******* in moststates and is dangerous.
Aug 28, 2016 | Jensen Car Audio & Video
Can not set this up as a repeater
one thing that might not be apparent is that you need to tell unit what router in its range you want to extend , and hence that router needs to allow the extender to connect to it as well , so set up on both units will need be done , see this page from manual for more info:
http://www.manualslib.com/manual/355070/Asus-Rt-N12.html?page=16#manual
Feb 23, 2016 | ASUS RT-N12 Wireless Router
I USE MY GPS TO HUNT I NEED TO KNOW HOW TO SET MY GPS AND DOG COLLAR TO LAST FOR36 HOURS.
Which GPS and Dog collar do you have?
If this is the Garmin Astro and DC units, the manuals are available here:
https://buy.garmin.com/support/manuals/manuals.htm?partNo=010-00596-01
Page 4 explains how to set the backlit on the Astro
Page 13 explains how to set the update rate for the dog collar
Page 44 explains how to set the unit for battery saver mode
Sep 17, 2011 | BoxWave Corporation BoxWave Garminfone...
My remote control unit will not work and I can not find my manual to figure out how to make adjustments to settings. The unit seems to be in auto and set at around 76 degrees and shuts down quite...
Apparently this unit is no longer made-
But here is a link for a company that supplies older remotes.
(I have neve used them, I just found them in a seach for your Modem:
http://remotes.com/
Aug 08, 2011 | Haier CPRB09XC7 Portable Air Conditioner
How do I reset the clock for the one hour time switch? This was the first DST switch since broadcasting went digital. The loss of the TV guide is no big deal but cannot I cannot change the clock. The...
The Panasonic DMR-EH50 can be reset like it was brand new. I assume the DMR-EH55 can be also. The up and down channel buttons are located on the front of the unit behind the small door in the center. With the unit on press and hold these two buttons for atleast 10 seconds. This will restore the unit like it was new and you will need to go thru set up procedure. The above action will put the unit in the off position. When you turn it on it will guide you thru the set up procedure. Once this is complete you can press the setup button and manually set the clock, however, the unit will need to be shut down for 24 hours to allow the tv stations line-up to be restored.
Nov 02, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Installation manual required for teco split aircondtioner. Reverse cycle LS0909Y. I have operation manual but not sure how to install and wire up. Many thanks.
Is the unit an AC only or a heat pump?
Wiring to the units should in the manual or online.
Both units proper house voltage to inside unit and outside unit.There will also be a two wire low voltage cable between thr two.This is so the inside unit can turn on the higher current draw of the compressor in the outside condenser unit thru it's relay.If you have a heat pump there will also be a set of two wires to the 4 way gas valve in the condenser unit to change from heating to cooling mode,a set of two wires to control the on/off function of the fan in the condenser unit when it needs to defrost and mayby a two wire set to a themal sensor in the condenser to sense if it is frosting up when system is in heat mode.
Try to get a wiring diagram and if you can't get to the point where you understand how to wire the unit don't guess! Call someone who knows wiring or call a pro, he can you money over the cost of replacing parts if unit is miswired.
Oct 06, 2009 | Heating & Cooling
How to set the clock on vcr/dvd.
Make sure the antenna//cable TV connections are correct. Channels are set. If this unit is connected to a cable/satellite box, select the local PBS station on them to set the clock automatically.
There's an Auto Clock Setting. "This Unit can set the time and date automatically by reffering to a PBS station.". But I never had to do that, I just went to Setup and it already knew what the date and time was.
"Note: The clock may set itself automatically after you connect the antenna/cable signal and plug in the power cord. Only the analog PBS channel signal is effective for auto clock setting. The unit receives the clock data at 12:00 A.M./P.M. from the PBS channel when the power is off.
1 Press [SETUP] and use the up and down arrows to select "General Setting", then press OK.
"General Setting" menu will appear.
2. Use up and down arrows to select "Clock" then press OK.
"Clock" menu will appear.
3. Use up and down arrows to select "Auto Clock Setting", then press OK.
4. Use up and down arrows to select "Auto" then press OK.
5 Press SETUP to exit.
6. Press STANDBY-ON to turn off the unit.
This unit will search for the time only when the power is off. Leave it off for several minutes to give this unit time to set the clock.
If the unit chooses an incorrect PBS channel, set the PBS channel manually by following the steps below:
1. Select "Manual" at step 4, then press OK.
2. Use [the number buttons] or up and down arrows to enter your PBS channel number, then press OK.
3. Press SETUP and turn off the unit.
If this doesn't work, let me know and I'll type up the instructions for what to do if you need to actually set the clock manually.
Mathis...
Feb 17, 2009 | Philips Magnavox DVD/VCR Dual Player
Sanyo KHS0922 HVAC unit won't stay on
Dave did you ever have the problem amended? I have the same unit and teh same problem. It will run through one cycle once the temperature on the remote is adjusted, but then it seems to quit, sometimes even keeping the fan on low without the heater coils on. It is annoying to wake up in the morning to a house that is 60 degrees!!
Dec 22, 2008 | Sanyo 18KS52 Air Conditioner
Manually resetting my Alvarion breeze access indoor units
sorry mate trying to make heads or tails of what you have written, to get the IP address of the device you need to do this. connect to the device, then click start button, then click run, type CMD and press enter a black screen appears ie dos prompt. type IPCONFIG /ALL then press enter you will get the IP Adress of the device. dont matter if you connect wirelessly or through cable you will get the ipadress.. Hope this is what you mean All the best John
Mar 08, 2007 | Alvarion (835108) Wireless Bridge
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
