Question about Sangean Audio Players & Recorders
Sangean W-2 AMFM radio. AM Static bad. INT aerial not helping.Ext aerial available? Possible solution?
  • 13 Answers
SOURCE: radio just plays out static cant get a station and
check if tuner is not to 'local'
Posted on Jul 29, 2009
radiorob1
  • 17 Answers
SOURCE: Wiring schematic for Sangean ATS 818cs
Yes, go to:
www.thiecom.de/ftp/sangean/ats818/ats818acs-servicemanual.pdf
Posted on Aug 04, 2009
radiorob1
  • 17 Answers
SOURCE: Sangean ATS 808A-replacement aerial antenna
The antenna should be available from Sangean, or C.Crane.
To replace the entire antenna, about 6 screws from the back must be removed, and the back also removed.
Or you could replace it at the antenna's "elbow". However, this is almost impossible to do without loosing the 2 tiny washers. If you do loose the washers, the antenna will work, but will be loose, and not stand up and support itself.
jyackle5
  • 8197 Answers
SOURCE: manual for Sangean RCR-22 clock radio
You can get the manual on the link below.
http://www.thiecom.de/ftp/sangean/rcr22/rcr22-manual-e.pdf
Posted on Apr 28, 2010
Testimonial: "I know my clock radio is easy to set for time & stations but without my manual I was lost! Fixya got me a manual within a few hours."
  • 10865 Answers
SOURCE: I want to add an external antenna, is this product
Hello eab.... I would begin by looking at Radio Shack. Take the radio in with you. The prices cover a wide price range depending on the range and quality. Joe
Thanks for choosing Fixya!
Posted on Feb 26, 2011
Radio very noisy, been to 2 dealers and been told 2 different stories both with end result cannot be fixed. Does anyone else have this problem and any diy ideas
by noisy do you mean static, squeal on starting the car or what
if it is static it could be a bad aerial
squeal could be electrical interference from starter motor
dealers do not fix radios so you would be better off taking it to a radio shop ( where radios are installed ) for a qualified opinion and diagnosis
if you take it to several and you get the same opinion then get a quote to fix or replace
Oct 30, 2015 | Cars & Trucks
NO SIGNAL FROM EXT ANT JACK
This particular model is known to be prone to static electricity.
You may try first to reset the radio by taking all the power sources off, including AC power, the D batteries, and the AA batteries. Leave it without any power for a day (at least 12 hours, but 24 hours would be better).
This would cause a processor reset. Plug the power sources after 24 hours and check it out.
If that doesn't bring it back to life, then you may have to open it and do some more involved work (if you are handy with soldering and replacing electronic parts).
Usually the sensitive part that gets fried by static electricity and causes your issue is the Q1 transistor, which is a field effect transistor (FET).
Most likely your FET Q1 is a Sony product which maybe labeled as 2SK152. It's out of production, but you may find it at some major electronics outlets, such as Mouser Electronics.
There should be some equivalent FET out somewhere (RadioShack, perhaps?), if this particular one is not found.
Replacing the FET should be an easy job after you have opened the cover (5 screws), and unscrewed the board.
Just be careful not to cause further damage by static electricity from your body (wear a grounded static discharge strap), and be very careful handling the board.
Best of luck, and hopefully you will comment here if this has helped you resolve this issue.
Sep 14, 2014 | Audio Players & Recorders
Need replacement for Broken On/Off knob - Sangean WR-11 AM/FM rsdio
Best to search on old stores or service centers for the part which can be sourced easily.
Nov 02, 2011 | Sangean WR11 AMFM Table Top Radio AMFM
I want to add an external antenna, is this product available to be purchased, if so from what stores and approx. how much will it cost. My Radio is a Sangean ATS 808A. Also, is a 220 Volt power pack...
Feb 26, 2011 | Sangean ATS 808A AM/FM/SW Radio
We have a client with the Sangean PR-D8, the problem are that its keeps corrupting the file on the SD card when recording using the Timer setting it show that its record but when complete the MP3 file...
I have similar problem with this set - recordings are corrupted. Every few seconds a fraction of a second is cut off. Probably it's a problem with SD card. Someone reported this problem in amazon.com customer review for Kingston 4 GB Class 4 SDHC Flash Memory Card SD4/4GBET
Feb 09, 2011 | Sangean PRD8 AMFM Radio
Yes, go to:
Jan 01, 2009 | Sangean ATS 818 AM/FM/SW Radio
May 10, 2008 | Sangean ATS 808A AM/FM/SW Radio
24 people viewed this question
Top Sangean Audio Players & Recorders Experts
Mark Schmit
Mark Schmit
Gyula Lacz
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
