Question about Water Heaters
A.O. smith Promax. green and yellow lights won't go off in turn NO hot water.
  • 74 Answers
SOURCE: pilot light keeps going out
Change the thermo-couple.......$5-$10 at any home improvement store. It is a copper wire that is connected to the gas valve/control unit on the heater. Remove it by unscrewing it and bring it into the store with you to make picking it easier.
Posted on Apr 27, 2009
gary1121
  • 332 Answers
SOURCE: Water Heater Won't Fire up
does the fan come on? this has to happen before it will even try to start if it doesn't your problem goes farther into the unit,, normal pracess if the fan then the ignitor then the flame, It could be in the circuit board most people that have gone with the tankless don't clearly ask the question but that is normal, but if you could clearify the procedure of what it is doing to this point i could be more helpful to you---- e-mail me what is happeing diffrent then what it use to do gary1121@aol.com
Posted on Jun 11, 2009
SOURCE: I have an A. O. Smith Model FPSH 40-261 hot water
AO Smith uses the Honeywell ICON gas valve with green indicator light.
Some models use White Rodgers Intellivent with a row of indicator lights.
The gas control blinks the error code:
Open following links to identify gas control thermostat and read possible error codes:
http://waterheatertimer.org/pdf/Honeywell-Gas-Valve-LED-Codes-2000.pdf
http://waterheatertimer.org/BW.html#Temp
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Posted on Jul 18, 2011
Testimonial: "Thanks so much for your help. It's exactly what I needed."
SOURCE: To light the pilot on my OS Smith water heater, I
Thank you for providing clear description of product:
Your water heater has intellivent gas control thermostat.
There are always problems with water heaters. It is a huge field.
1) Open following link for AO Smith service manuals.
I do not see service manual specifically for the GP series.
http://www.hotwater.com/resources/product-literature/service-handbooks/
2) Open following link to identify gas valve and download typical service manual:
Some AO smith power vent models have intellivent gas valve, and some have smart valve gas vent. Older models might have knob-type gas valve.
3) More resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Posted on Sep 24, 2011
SOURCE: A.O. Smith promax electronic controller is not
Question is not clear.
Do you want instructions to replace valve or want a service manual to test out the parts?
Open following link to help identify gas valve and download possible service manual that applies to that gas valve.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
It is usually recommended that a professionally trained person replace the gas valve.
If you have the intellivent gas valve, then it usually has identifying marks on side of valve, or call AO Smith with the model and serial number from label on side of tank.
Turn off gas and disconnect gas line from side of valve.
The manifold tube and wires are disconnected.
The gas valve unscrews counterclockwise.
If you want more details as the project requires, add a comment with specifics and that sends email that I will answer.
Posted on Oct 08, 2011
Hot water heater
You need to change the elements out
Oct 01, 2016 | A.O. Smith GPVH-50 Residential Water...
Why would gas stop flowing to the water heater?
if thermocouple goes bad(pretty common) then pilot light goes out and gas stops flowing.
Aug 01, 2015 | A.O. Smith GCV-40 Promax Residential Water...
Leaks
The fitting at the top need to be looked at. Use tolit paper wipe around all the fittings and drain lines over head check the popoff valve next if you got a plastic drain valve. Replace it with a 3/4 nipple and cap or a ball valve full port and hose adapter turn gas valve off and use up the hot water I had a valve break during replasment cool water is better. Use pipedope on fitings
Apr 12, 2014 | AO Smith ECT-52 50 Gallon ProMax...
A.o. smith powerhouse powershot nat gas hot water heater 40000 btu the vent hasnt stopped running for 3 days and the water is luke warm at best
If the vent has been running for 3 days, is there fire in the hole? I suspect there is a lot more to this story. If there is fire in the hole, turn off gas and call someone before you get killed. Seriously.
Apr 02, 2014 | Water Heaters
Rust in water, ao smith promax
It may be what is called iron bacteria it will sometime grow in a water heater. It is present in some water and will actually thrive in water temps up to 120 degrees.if this is the case one solution is to increase the water tempurature of the heater to 130 -140 degrees this will kill the bacteria that is causing the rust problem.You Must install a tempering or mixing valve which will add cold water to temper or cool the water back to 120.
hope this helps.
Dec 02, 2013 | A.O. Smith GCV-40 Promax Residential Water...
To light the pilot on my OS Smith water heater, I follow the instructions in the label, but nothing happens, no hot water after one hour. Read that there is problems with water heaters, I have some...
3) More resources:
Sep 23, 2011 | Water Heaters
I have an A. O. Smith Model FPSH 40-261 hot water heater. It won't heat water. there is a green light on the control flashing. What does it mean?
Jul 18, 2011 | Water Heaters
Water Heaters Logo
42 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
