Question about Lands Phones
How do i register on line to check my hrs. - Lands Phones
    Top Expert:
  • 12,744 Answers
Wrong site this is fixya need to notify or go to company or agency's site and register with them
Posted on Apr 29, 2017
New cordless phone showing out of range
Check that it is registered with the base station and check the range coverage. If you are not out of area of coverage and handset is properly registered to base station then your handset may be faulty.
Dec 12, 2014 | Lands Phones
My sharp A-450s cash register has been in storage and worked for a few minutes when switched on , however now all that comes up on the display is a green flashing dot after the last digit. I've had it on...
contact the makers>?
or read their manual,? and do a system full reset.
most systems have this , way to do a reset.
storage for how long, 1 week, one decade? just a hint....
Oct 02, 2013 | Sharp ER-A450S Cash Register
The intex system light is green ,but when i test water no free chlorine is registered
I have an 18 X 33 X 48" oval pool (14000) gallons and I run my pump in the summer months at 10 to 12 hrs and chlorinator at 8 to 10 hrs of those pump hrs and hit a chlorine level at 2.0 to 2.5 ppm.. Green chlorine light means you are generating, it does not mean you have the correct level.. Increase your cycle time and check after 3 days... Please post a comment if this helps! Good luck,,
Aug 08, 2011 | Intex Automatic Salt Water System for ...
Going dim, POS NCR 7452 cash register 9" vga mono.
bcollier696, You did not state how many hours of use this small screen monitor has on it!! You may need to replace the CRT if it has been in use for a long time. Can you approximate the total "ON" time of said unit? Is it >10k hrs. Multiply hrs/day x 300 days x yrs of use. If u come up with 15k hrs or more replace the unit with an LCD if possible.
lmistyrel @ or louie12fix on fixya
Sep 16, 2009 | NCR Refurbished 9 MONOCHROME VGA MONITOR
Jeep runs for twenty minute and stall.
Hello now that I see this messages you making me to remember when this use to happen to me I was totally mad especially that I try everything even on my wedding Honey moon it was a disaster I took my truck to my Honey moon it was 12 hrs from home but it took me around 20 hrs once I get back home from my trip I decide to spend a full day trying to find out what was wrong with my truck I had a dodge ram 1500 1995 5.9 engine and the main problem was with the fuel pump it run fine for about 3 hrs and then it die and I had to wait around 20 minutes and then run another 2-3 hrs in low speed the higher the speed the less time it took to fail again how I found it was the pump well inside in the engine compartment there is a fuel line with a valve to check the fuel pump pressure I did run my truck hard until the fail occur then I install the pressure gauge try to turn the switch on and it was no pressure at the line problem solve the fuel pump was getting hot after couple of hrs running sometimes it only took about an hour to fail try this and see if you have the same problem it could be a different problem but it is good to know this
Apr 15, 2009 | 1994 Jeep Grand Cherokee
I bought a used Kenmore upright freezer, it's been on for over 24 hrs, and it freezeswell, BUT won't turn off. Runs alllll the time. Any suggestions??
Did you transport it STANDING or LYING down?
If Standing 4 possibilities:
1. The thermostat is hosed (replace)I had one like this and just put it on a $6.00 24hr time to turn on for 1hr every 5 hrs. (New Thermostat was $40.00)
2. The heat exchange fins on the back are dirty(clean with broom and air/vacuum cleaner)
3. The Door seals arent sealing and cold air is falling out the bottom, pulling hot air in the top (rehang door or replace seal) Note: a piece of paper 2" by 8" should be hard to pull out all the way around when closed. Like a cash register reciept. Cleaning with armor-All and then thinly coating with Vaseline may help
4. The Freon is shot and needs a recharge. (Costs $40-100.00)
If transported Lying down, there is now air in the lines and it needs to stand OFF for 24hrs. You may have hosed the pump with the air/freon mix, but let it stand so the air can surface and retry
Mar 26, 2009 | Freezers
Product states it can be registered on line.
You need to go to
and register yourself, then you can register the Sander.
Feb 10, 2009 | Black & Decker MS600B Detail...
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
