Question about Health & Beauty
Need a manual for a lark 1 scooter. have to remove 2 batteries, and there is 1 red wire and 3 black need to know how to hook up both batteries with 1 red wire and 3 black wires
    Top Expert:
  • Health & Beauty Master
  • 38,003 Answers
Try Googling (lark)(1)(manual) without parens.
Posted on Apr 30, 2017
Lark 3. Where can I get a wiring diagram?
hi , you won't get a lark 3 diagram sadly
If you tell me the controller used or better a picture (black box located at the rear ) i can help , sometimes it hard wired by a switch from batteries or the controller outputs a voltage to the lift motor ,
I have repaired many Larks...
Regards
Rob
www.gewizrepairs.co.uk
Jun 08, 2015 | Health & Beauty
Charging schematic for pride scooter
red + goes to pin 1, black - goes to pin 2 and jumps to pin 3
Dec 29, 2013 | Pride Rally 3 Wheel Scooter
I needed to replace the pull switch, but in doing so the capacitor was disconnected and I do not know where the wires go. It's a five wire, 2 gray,1 green, 1 red, one brown. It's marked 10mfd/5mfd/250vac....
1 - gray
2 - brown
3 - green
L - should be black
The other gray should be connected by wire nut to the other grey to reversing switch.
Also, you should have two wires, white & black w/ white stripe, at bottom of fan to hook up light if needed.
Oct 08, 2013 | Hunter Dryers
Our Liteway scooter has been unused for a couple of years. We purchased a new battery and charged it up but it won't run. The freewheel device is in place and we've done all the troubleshooting we know per...
terry, did you replace both batteries? If you did check your wiring connections on the batteries. Make sure that the polarity of the wiring is correct( red to positive and black to negative) and if you replaced just one battery then you have to replace the other one also. Once you have 2 new batteries installed and have made sure the wiring is correct. Turn on the scooter and see if you still get the flashing lights look at your manual and see that the 3 flashes mean a short between the batteries and the motor. If you continue to get the error you will have to contact your local provider or a service company to check the scooter.. Hope this helps
Sep 28, 2010 | Golden Technologies Health & Beauty
I have a pride go go elite traveller 4 and need some new batteries, but what batteries and connection am i looking for?
Rachel you need 2 12/12AH batteries that are located in the battery pack under the seat. Simply pull the battery pack from the scooter and with a standard phillips screwdriver remove the many screws attaching the battery pack together (simply turn the pack over to get to the screws) There will be two wire on each battery and also a heat sensor attached to the side of one battery remove the wires from each battery and carefully reove the heat sensor. You can bring one of the batterys to your local battery warehouse type store or a provider and purchase 2 new ones reinstall like you removed attaching red wire to red terminals and black to black terminals and reattach the heat sensor to the side of one battery (you can use packaging tape to reattach). replace all the screws to put the case back together and reinstall in your scooter. Charge the batteries with you charger until the charge light is green then happy riding HOPE THIS HELPS
Aug 20, 2010 | Pride Mobility Products Go-Go Elite...
I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Jul 05, 2010 | Electric Mobility Power Electric Scooter...
Model# RR100 MFG Code 27046B, got 2nd had with no manual. How do I hook up the new batteries? So many terminals to choose from?
Hi.The best idea if you are not to sure, is to get help. If you want to do it your self, be careful, batteries can be dangerous if shorted out.
Each battery has a positive ( red ) terminal, and a negative ( black ) terminal.
Change one battery at a time, make sure the scooter is turned off and /or unplug the battery leads.
The red wire will go to the red terminal ( positive ) onthe battery, the black wire to the black terminal.
Each battery should have 1 black wire and 1 red wire to it.
Remember, be careful.Neil.
May 30, 2010 | Pride Mobility Victory 3 Wheel Electric...
I need a wiring diagram hook up for a Jenn air 201595D Range top & also for a GE Double oven JKP36G0D1B0
Cook top manuals and installation.
http://www.jennair.com/catalog/product.jsp?parentCat=2&cat=12&prod=1457&tabOption=specs#info
Could not find installation manual on oven but did find manual. If you are just trying to wire to the house wiring you need to conect this way. Yo uwill have 3- 4 wires from the house. 1 white, 2 black or 1 black and 1 red. From range hook white to white Black to black or red they both are the hot line. and the other black or red to black or red from the house. If you have bare wires that is the ground There is 2 ways to do the hook up on the ground. 1st way is if you have ground in box from house wire them together. 2nd way is if there is no groung just wire it up with the white wire that is the netural line. It will be fine that way. If you can see in you main braker box the netural and the ground go to the same bus bar.
http://genet.geappliances.com/DocSearch/pdf/49-4751.PDF
Good Luck and If you have any more ? fill free to ask befor you rate.
Jan 16, 2009 | Jenn-Air JED8430 Electric Cooktop
Health & Beauty Logo
51 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
