Question about Panasonic Televison & Video
What was the last year that the 260 panasonic gunslinger was made?
H98 error code
H98 is an error code related to a problem in the high voltage section. I would think that you should be able to get an estimate over the phone locally to determine if you want to proceed with repair or replacement.
Oct 20, 2013 | Panasonic Microwave Ovens
I need lamp for panasonic model no.
bigspareswarehouse have a full range and they are a bit dearer then others but it will last for a couple of years as the cheaper ones last about a year if that, hope this helped
Apr 27, 2010 | Televison & Video
I have a Panasonic ET-LAE700 Replacement Lamp with Blue Haze
It should last longer than a few months, contact the manufacture
Jan 06, 2018 | Panasonic Televison & Video
Trying to find a picture of a gun so i can make a
Hop onto GOOGLE and type in whatever picture of the gun you require and it will come up. I hope this helps.
Oct 27, 2009 | Jasman Wild West Gunslinger Target...
My dell optiplex GX 260 suddenly restarted on its own a few times then it does not start anymore. The power indicator on motherboard doesnot light up. Power box burnt?
Possibly, there was a serious problems with capactiors that affected all major manufacturers a fre years back whereby the caps didnt last more than 2 to 3 years. SOme lasted longer before blowing. Dell could help you establish if yours was affected. It does sound like the power supply, see if the fan is spinning on it. If not they are easy to replace and can be purchased on ebay. Mail me if you need the part number and ill see if i can help you. m.g.woodruff@googlemail.com
Aug 17, 2009 | Dell OptiPlex GX260 PC Desktop
Panasonic television set will not turn on
check the wall plug with another applyance to make sure that hasent failed . Dont laugh but sometimes only half of the wall plug gos bad. If not this you may have a fuse blown out on the inside of the unit. Or the switch may have failed. If its the power supply then you may want to consider a new unit. all tho Panasonic last and last for yrs.
Apr 11, 2009 | Panasonic Televison & Video
I bought my Panasonic 44lcx65 2 years ago and over the last year 4 green spots have appeared and one orange one. Today I turned it on and I have no picture at all just sound, but I do have a picture if I...
the spots can be helped with an eeprom update. call your AUTHORIZED Panasonic repair man. If you have picture with DVD then your problem is with your source input. Double check all your connections.
Dec 21, 2008 | Panasonic PT-52LCX65 44" HDTV
Rca converter box need 3 digit code
Samsung 005 013 079 080 145 177 195 202 213 216 227 255 256 260 266 274 275 282 295
RCA 001 005 072 073 074 075 076 077 078 135 138 140 144 150 156 159 162 163 169 171 178 229 246 249 260 274 275 293 302
Panasonic 040 045 125 179 187 254 257 288 299 301
Jun 30, 2008 | Televison & Video
Ballast problem on PT-40LC12
Sent me the serial number, and I can check for any re-call ...
my e-mail is <ultraman_s@yahoo.com>
Feb 01, 2008 | Panasonic PT-40LC12 40" Rear Projection...
60IN ZENITH LCD
I would look to see it this set has a bulb, common problem when set's won't turn on on rear projection lcd.
How old is the set, most bulb should last 2000 hrs, depending how often you have turn the set on and off. Most set's dont' have this problem they have slow turn on bulb, I love panasonic I feel there one of the top brands and have excelent picture.
But keep in mind new technology has there problem, more gagit more problem just like vehicule, and panasonic ten to push this to the max. Panasonic also then not to help when ask question , they just don't want to help technician.
Most tv's this day's has a life expentasy of about 7 years, the best one's would last over 12 years and the cheaper brand I keep seeing or made in china, lucky if you get 2 years.
Regards
bob
Jan 19, 2008 | Panasonic PT-56WX53 53" Rear Projection...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
