Question about Garden
What's the type of oil used for a wheel horse hydro stat tranmission
4 Suggested Answers
SOURCE: what weight oil is used in a Wheel Horse 418 A
Manual says:
< 30 degrees F - 5w30
> 30 degrees F - 30W
Posted on Jun 16, 2010
SOURCE: What kind of oil do I use in a Wheel Horse lawn tractor?
Your Onan engine will do excellent with Mobil One 0w40, Mobile One 5w30.
DO NOT use hydraulic oil in the transmission/transaxle, you will destroy it. Your tractor uses an Eaton 11 Hydrostatic transmission pump with the oil resevour being the cast iron transaxle. The WheelHorse transaxle is as rugged as they come. It uses a solid cast iron housing, case hardened intermediate gears and forged differential gears with an eight pinion differential.
Your transaxle requires 10w40 synthetic or conventional oil as well as a wix 51410 filter or the OEM wheelHorse filter. It should be changed every 100 hours with conventional oil or 250 hours with synthetic. DO NOT use hydraulic oil!
Posted on May 31, 2012
normdoty
  • 36 Answers
SOURCE: can hydro oil be changed and what type oil on Swisher ZT2460 mower?
yes hydro oil can be changed and should be at regular intervals, the manual should tell you how often and the type of oil to use for best lifespan.
good luck.
Posted on Jun 29, 2014
I need a manual for toro wheel horse 268 hydro model 72107 serial no.210000417
Go to TORO.com and look for manuals. They are available for download
Jan 23, 2017 | Toro Garden
Not getting gas to carb. changed fuel pump, bypassed filter. hold gas line below tank and fuel comes out. but not being sucked through pump it appears. help
It has a pressure differential fuel pump, just put a little fuel in the carb. and it should start it may stall but do it 1 more time and then it will stay running as it uses the crank pressure to actuate the fuel pump
May 08, 2015 | Toro Garden
Can hydro oil be changed and what type oil on Swisher ZT2460 mower?
good luck.
Jun 28, 2014 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Hydro-tranmission want engage
i have seen many times when the wheel was removed you lost the square key that locks the wheel to the axle and is covered by the clip that holds the wheel on the axle
Sep 01, 2012 | John Deere Garden
Gt 245 lawn tractor won't go forward or backward
Check the drive belts first. and make sure the hydro release lever is in the correct position. If it is not- you can push the lawn tractor and have the rear wheels turn. It sometimes doubles as a "Forward" "Neutral" "Reverse" lever on other brands of lawn tractor.
The belts should be in their guides and pulley grooves- check to make sure it does not have a hidden break by having the engine off, and pulling on the belt.
Lastly, check to make sure the hydro itself is not out of oil or low on oil. It uses low viscosity "HyGard" oil. Capacity if you drain the old oil out and refill is 4.6 quarts. Look for a leak if the level is low.
If it still does not move, make sure the levers are set so you are in forward motion positions, and push- if the rear wheels move there is a problem in the hydro unit.
Apr 07, 2012 | Garden
My brakes and power-steering are not working. The brake pedal is hard, but the brakes will not engage. The power steering was not working at the same time. It has brake fluid, but when I took the power...
Yes, your brakes are boosted by the power steering pump rather than by vacuum. I don't think it's air in the system. More likely your pump has failed, but you can try bleeding the pump. Here is a procedure from autozone.com:
Observe the following:
Use clean, new power steering fluid type only Hoses touching the frame, body or engine may cause system noise. Verify that the hoses do not touch any other part of the vehicle. Loose connections may not leak, but could allow air into the steering system. Verify that all hose connections are tight.
NOTE Power steering fluid level must be maintained throughout bleed procedure.
  1. Fill pump reservoir with fluid to minimum system level, FULL COLD level, or middle of hash mark on cap stick fluid level indicator.
    NOTE With hydro-boost only, the oil level will appear falsely high if the hydro-boost accumulator is not fully charged. Do not apply the brake pedal with the engine OFF . This will discharge the hydro-boost accumulator.
  2. If equipped with hydro-boost, fully charge the hydro-boost accumulator using the following procedure:
    1. Start the engine.
    2. Firmly apply the brake pedal 10-15 times.
    3. Turn the engine OFF
  3. Raise the vehicle until the front wheels are off the ground.
  4. With key in the ON position and the engine OFF , turn the steering wheel from stop to stop 12 times. Vehicles equipped with hydro-boost systems or longer length power steering hoses may require turns up to 15 to 20 stop to stops.
  5. Verify power steering fluid level per operating specification.
  6. Start the engine. Rotate steering wheel from left to right. Check for sign of cavitation or fluid aeration (pump noise/whining).
  7. Verify the fluid level. Repeat the bleed procedure if necessary.
Oct 24, 2010 | 2005 Chevrolet Silverado
What are the propper oils and lubes for the model 127 cub cadet?
Well, personally, i use a normal engine oil; what ever your preferance. i use pennzoil. for the engine, the weight that they call for at cub cadet in those days is winter-5w20-summer 10w30. they call for a low ash oil, you can get it at any cub cadet or internation harvestor dealership. the rear end, if its a hydro stat takes hy-tran fluid, also sold at the dealer. you cant use anything else in a hydro, theyre real touchy. if its gear differential, any 80-100w gear oil will work. hopefully this helps, ive been dealing with old cub cadets for a close to 20 or more years. good luck!
Aug 14, 2010 | Cub Cadet Model 18611862 Parts Operators...
Jun 24, 2009 | Garden
Craftsman LT1000 Parts manual
find every part you need on amazon here Amazon com Craftsman LT1000 Parts . take a look and enjoy
May 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Runs greeat but moves forward very slowly
Is this a gear drive or hydro ? If its hydro may need oil change and filter(tranmission) If not its most likely the belt.
Apr 11, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
