Domestic rm 8501 refrigerator gas pilot lights but won't stay lit after spark ignite stops.
SOURCE: Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Posted on Dec 06, 2007
  • 13 Answers
SOURCE: Pilot light won't stay lit
Look for dust and lint. Look for them in places where gas should be freely flowing. I had a similar problem with an Empire Corcho wall-mounted propane ceramic catalyst heater. First it was the pilot light, then the #2 ceramic mantle. After horsing around with the gas lines and pressure regulators and trying to re-aim the pilot, it all turned out to be dust and lint in the gas passages. A little dust bunny in the brass pilot tube gave me a pilot light the shape and color of a banana. One puff of compressed air, and I got back my razor-sharp pilot. And some dust in the chimney of the #2 burner kept it burning blue/yellow and blistering paint off the upper surfaces of the heater. A bit of cleaning with a shop-vac put that right. "Passive" heaters are very much prone to this sort of problem because they rely on convection currents (i.e. LOW velocity) to get the job done. Convection currents are notorious dust collectors, as in COBWEB CITY.
Posted on Feb 28, 2009
john224
  • 1378 Answers
SOURCE: Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Posted on Dec 17, 2009
SOURCE: warm morning propane heater. new thermal couple.
There are basically three things that can go wrong with the Warm Morning .
Sensor shut off. There is a sensor button on the back of the unit with a wire going from it to the thermocouple. This sensor turns the heater off if the flue is blocked, however it will also shut the heater off if the wire contacts are dirty, or if the sensor has gone bad.
You can test this by bypassing the sensor. Disconnect the two wires from the sensor and reconnect them directly together. If the pilot stays on, your problem is here. Try cleaning the wire contacts first.
Pilot orifice. If the pilot flame is small and doesnt look healthy, the pilot orifice may need cleaning. The hole is very small and can get dirty. Disconnect the silver tube and clean with electrical parts cleaner. Never try to clean the hole with an object like a pin, you may damage it. You may have to slide out the burner unit to get at the silver tube. (Always shut off gas before disconnecting lines and after you reassemble, spray joints with soapywater and look for small bubbles which may indicate a gas leak. Dont use parts cleaner around an open flame.)
Thermocouple can go bad but this is not as common as the first two problems.
Posted on Jan 28, 2010
  • 15 Answers
SOURCE: norcold refrigerator burner will not stay lit
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Posted on Jan 29, 2010
Pilot light wont light
Rita, Check the attached links,instruction and guides to trouble shoot pilot light, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gas Heater Pilot Light Troubleshooting
What to Do if Gas Furnace Pilot Light Won Stay Lit DoItYourself com
Furnace Won Ignite Why and What to Do
Aug 03, 2016 | Heating & Cooling
When I try to use my Thermolaire model SU402E, the pilot lights( and stays lit), but the main burner will NOT ignite.. any suggestions as to what could cause this if the pilot stays lit?
Bad igniter? When you 1st try it the gas valve will give enough gas that you would get the burner lit if the igniter was glowing red. If you're desperate you can light the igniter area w/ an aim n flame, but you definitely want to do that w/ caution and crank up your t-stat so the furnace stays on awhile Cuz you'll have to do it again for heat or buy an igniter($40 or so)
Jan 14, 2015 | Heating & Cooling
My rv fridge will lite but goes out as soon as the ignition cycle stops
You didn't state the Brand or Model of your refrigerator but it sounds like your flame sensor isn't working.
rv refrigerator won stay lit YouTube
Oct 14, 2014 | Heating & Cooling
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
Pilot won't stay on
Burners don't have anything to do with the problem of pilot not lighting. Is the problem that flame will not 'stay' lit? Or you can't even get a flame to ignite? If former: possible bad pilot generator or bad gas valve. If latter, possible bad gas valve or no fuel to ignite.
Dec 23, 2012 | Hayward H Series Pool & Spa Heater 400k...
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
DOMETIC RM 7651l HAVE POWER AND GAS TO THE FRIDGE BUT WONT START (TWO MONTHS OLD)
Igniting a Dometic gas fridge
    Electronic Ignition
    1. Open gas cylinder or pressure regulating valve
    2. Turn on Electronic ignitor switch
    3. Turn gas control knob to the MAX position, press and hold down
    4. After ignition, hold down knob for a further 15 seconds before releasing. The neon light will stop flashing
    Piezo Ignition
    2. Turn gas control knob to the MAX position, press and hold down
    3. After approximately 10-15 seconds
      press Piezo knob several times until pilot light a lit
  1. Check the Pilot light is alight
  2. The flame can be controlled by aperture ©
    Should no ignition occur, repeat the ignition process after 1 minute
    (This could take longer than 10 seconds if the unit has been out of operation for a prolonged period or after replacing the gas cylinder. (Cause: air in the lines)
  3. Once sufficient refrigeration has been obtained in the cooling tank at the MAX position, the control knob should be turned to the MIN position by low outside temperatures or when the refrigerator is only lightly loaded respectively the ambient temperature is below +18c in order to avoid over freezing the contents.
I hope this helps you...
Regards
Wouter...
Sep 30, 2008 | Refrigerators
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
