Question about Toshiba Televison & Video
Toshiba DVD Video Player SD-2705 won't open. Need to get my disc out
  • 39 Answers
To get the disc out, you must remove the cover to the machine. There are screws around the outside case and usually on the back holding the case in place. Once these screws are removed, the cover can be removed by lifting from the back. After the cover is off, you can see your DVD and lift it out. To return the cover to the machine, start installing it from the front as the front edge usually slips into some grooves to hold it in place.
Posted on Apr 29, 2017
  • Lora Schultz
    Lora Schultz Apr 29, 2017
    Thank you very much, I appreciated your help. I will try that
Toshiba SD-K740SU player won't play dvd
Clean the optical pickup unit, by inserting a lens cleaning disc in to the system. If it do not help you, the optical pickup unit should be replaced. Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Pull up older posts. You can gather all details. Sometimes, click open the adverts' by the side and bottom of each post might give you more details.
May 26, 2012 | Toshiba SD-5980 DVD Player
I have a toshiba dvd player model sd-k600, i need change of zone 1 to mutiregion o zone 4, can you tellme how te change, tahnks
Press Open button on your remote control to open the drive tray
and remove any disc
Press 2403960
Press Enter button on your remote control
Press 9 for multi-region playback
Press Open button on your remote control to close the drive tray
Power OFF the DVD player
Power ON the DVD player
Jul 16, 2011 | Toshiba SD-K600 DVD Player
I own a Toshiba SD-3980SU2 DVD Video Player. I keep getting an Incorrect Disc comment, and bad comment. I an using DVD-RW discs. I have tried disconnecting and reconnecting the player.
You are probably using incorrect disc formats in this DVD player; try DVD+RW if you must use re-writables, or DVD-R (finalised in a recorder or burned on a PC). I doubt this model supports DVD-RW, so the problem wouldn't be with the player; it would be the formats of the discs you use.
Don't use DVD-RW discs in this player if it does not support that format.
Apr 22, 2011 | Toshiba SD-3980 DVD Player
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
Sound no picture with dvd player
Exchanged AmEx Rewards points for 3 Toshiba Model DS-4000KU DVD players in 2007. All stopped working. Two a year ago, one this week. Errors - can't read disc, bad disc, etc.
Warranty period is up. So I decided to open one up tonight since they were going in the garbage anyway.
Put on rubber gloves and took off the case. Unscrewed the player unit, lifted it carefully, and untaped lines from the botton of the unit.
Plugged the unit in and powered it on. Did not blow up! :>)
Jiggled some of the lines and connections. Put a disc in and it read it!
Attached it to the tv without putting the case back on. Received video. Yay! But no sound. Boo!
Jiggled the lines some more and tried it again. Working fine now.
Will put the case back on later and see if it still works.
Dec 09, 2009 | Toshiba SD-4000
Sd-v392 claims incorrect disc on most dvd`s
I removed the cover,the dvd unit and cleaned the laser lens with alcohal. The two back screws were loose on the dvd unit. It`s working like new again.
Sep 18, 2009 | Toshiba SD-V392 DVD Player/VCR
I can't seem to get the menu button to display any menu. I only use the player for CD/s in a church sound system (connected to a Kenwood Audio Video Reveiver). Also, I can't get the disc player to play...
You will need to the remote to perform these functions. if you have it that's great, if not you willneed to contac Toshiba for a replacement. I ahve a manual for you to print out and keep with the unit. It shows you how to access the menu and to activate random mode..
http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/DVD/sd2705.pdf
Sep 16, 2009 | Toshiba SD-2705 Multi-disc DVD Player
DVD PLAYER WILL NOT OPEN
I found the answer on your site. Unplug, wait a minute and plug it back it in, then press Play followed by Eject.
Mar 28, 2009 | Toshiba SD-2109 DVD Player
Dvd player shuts off during movie
Look at the power supply capacitors to see id any have a bulged top. Those need to be replaced.
Sep 03, 2017 | Toshiba SD-2705 Multi-disc DVD Player
Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
Nov 17, 2007 | Toshiba SD-3980 DVD Player
Televison & Video Logo
139 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
