Question about Garden
What type of oil does a hydro transmission take
3 Suggested Answers
  • 4 Answers
SOURCE: what type of transmission does a John Deere Z820A use
look on the ******. the all have a Brand and Model # on them
Posted on Aug 04, 2012
normdoty
  • 36 Answers
SOURCE: can hydro oil be changed and what type oil on Swisher ZT2460 mower?
yes hydro oil can be changed and should be at regular intervals, the manual should tell you how often and the type of oil to use for best lifespan.
good luck.
Posted on Jun 29, 2014
What type of hydrostatic transmission fluid is needed
The fluid recommended for Hydro-Gear transmissions and pumps is a 20W-50 motor oil or 15W-50 synthetic motor oil.
May 26, 2016 | Garden
What kind oil do i use in hydro rearend on huskee
use Type F Automatic transmission oil
Jun 22, 2015 | Garden
Hydrostatic transmission wont move after it runs a while why not
Common symptoms of a hydro tranny gone bad.
  • Runs a while, 10-30 minutes then quits moving.
  • Won't pull a load.
  • Won't go very fast when you are mowing.
  • Won't climb a hill.
  • Makes loud whinny sounds.
  • Easy to push when engine is off and tranny lever is engaged.
The NOT SERVICEABLE UN-TRUTH.
The Huskvarna YTH150 uses Hydrogear transmission 319-0650, drive model 150071. One place to find parts and diagrams for most Huskvarnas is here: http://www.m-and-d.com/Hydro-Gear_parts.html
MTDs use Hydrogear trannys also. Go to the site and enter 618-0319 in the search box. It will bring up a selection of MTD transmissions.
Sears Craftsmen mowers also have trannys from Hydro-Gear.
The best lawn tractor Hydrostatic Transmission Fluid is actually 10W-50 synthetic motor oil (like Mobil 1). That's right MOTOR OIL. Do not use hydraulic fluid or transmission fluid.
Hydro static transmissions on most lawn tractors are very similar. Most of them are made by one or two manufacturers. Tuff Torq makes a lot of them, but not the Huskvarnas. They do make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, an untruth. All of the JD hydros, and most all others, are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. They have a lot of good general info for anyone rebuilding their tranny.
Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 5W-50 synthetic motor oil (like Mobil 1™). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black drain plug on the top or some type of threaded plug , if they do not have the add on reservoir. You have to remove the tranny from the mower (not a difficult things to do, it takes about 30 min). Pull that black plug (I used a 1" putty knife to pry mine out) and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out; clean it and replace it. It may fall out while the tranny is upside down.If anything else falls out, you have a broken tranny and will have to take it apart.
When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
http://tufftorq.com/products/lawn-garden/index.html
Tuff Torq Lawn Garden
Jun 15, 2015 | Garden
Oil type in hydro tranny
Owner's manual, no manual, try MFG website, or email their customer service, or try manualslib.com
Apr 14, 2015 | Garden
What type of fluid does the transaxles take?
Usually it is 20w50 Synthetic motor oil If your writing about Lawnmower hydrostatics.
Apr 07, 2015 | Garden
What can I use for transmission fluid for my Cub Cadet tractor?
If your unit is a Hydrostatic model, Universal transmission fluid should work just fine. The proper type oil type should be listed in your operators manual and the hydraulic oils you see on the shelf will have the viscosity ratings listed. Just match the ratings to your model and you will be fine. Best Wishes
Sep 01, 2014 | Garden
Can hydro oil be changed and what type oil on Swisher ZT2460 mower?
good luck.
Jun 28, 2014 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Where is the fill cap for the oil for hydro transmission and what type of oil do I use
The filler is on top of the transmission, it is not easy to get access. The transmission will use 20W50 full synthetic oil. fill to within 25-30mm to the top.
Jun 19, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Husqvarna transmission uses what type of oil
There are two different units used on there garden tractors, Hydro gear which uses a sae 20-50 motor oil, or a Tuff Torq unit that uses a sae 10-40 motor oil, they do not use hydraulic oil.
Apr 04, 2013 | Husqvarna Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
